Go to Post Nerds do whatever they want to do, and they do it with style. - EricVanWyk [more]
Unread 06-08-2018, 07:31 PM
backflippingcat backflippingcat is offline
AKA: Sidney
FRC #6898 (The Undergraduate School of Carrots)
Team Role: Leadership
Rookie Year: 2013
backflippingcat will become famous soon enough
Pivots?
What are some light/effective/elegant/long-term solutions for pivot points? For example, the pivots or points of rotation on teams' cube intakes this year (especially those with a left/right wheeled intake with some sort of spring/pneumatic system to grip the cube) -- any recommendations for how to execute those well? Thanks in advance for the help!
Unread 06-08-2018, 08:13 PM
rklopp's Avatar
rklopp rklopp is offline
FRC #0100 (Wildhats)
Rookie Year: 2016
rklopp is an unknown quantity at this point
T100 did our pivots with typical 1/2 hex x 1-1/8 flange bearings on hex shaft, because the pivots were both pivots and shafts for timing belt pulleys driving the intake wheels.
Sent from my iPhone using Tapatalk
Unread 06-08-2018, 08:21 PM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Minnetonka)
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
Re: Pivots?
We originally used hex shafts in standard 1.125" OD bearings, since we were planning to use them to drive the intake wheels as well. We ended up putting motors on the arms of the intake, so we switched over to 1/2" bolts inside bronze bushings, since the bushings seemed to support the sides a bit better (they had less play compared to the ball bearings). Plus, it was only a ~1/4 rotation movement, so the bearings weren't really necessary.
My posts constitute my opinions, and mine alone, and are not representative of the views held by my team.
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Engineering Captain, fmr. Programming Lead, 2017&2018 Dean's List Finalist
2017-: FTC 13471 (Minnetonka) - Founding Mentor
Unread 06-08-2018, 08:22 PM
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Pivots?
Bearings or bushings for high load, speed and/or duty cycle.
You can get away with bolts as pivots for lighter duty things or for systems that adjust only a few degrees (like a 2013 shooter deck being asjusted by pneumatic cylinders 3*)
Get your cascade elevators and PowerCube claws!
2x1 and 2x2 1/16" wall tubing for sale!
Need help? Check out 973 Remote Assistance and Mentorship Program.
Like our Robots? Check out the CAD files of MOST of our robots!
2017 "World Champions"
2014 Galileo Champions
2011 World Champions
Unread 06-08-2018, 08:33 PM
bstew's Avatar
bstew bstew is offline
FRC #3928 (Team Neutrino)
Team Role: CAD
Rookie Year: 2015
bstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to behold
Re: Pivots?
3928 likes to use Oil-Embedded Flanged Sleeve Bearings. Just press them in and put your pivot on a round shaft or shoulder bolt.
Unread 06-08-2018, 09:55 PM
Type's Avatar
Type Type is offline
AKA: AJ
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud of
Re: Pivots?
We used 1/2" round for our intake pivot side to side this year, one being just a 1/2" hole and the other being where the bearings are, then 5/16" shoulder bolts for the rotation point at the start of the match to drop the intake.
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
Unread 06-09-2018, 12:02 AM
johncooper johncooper is offline
FRC #6072 (Triton Tech Robotics)
Rookie Year: 2016
johncooper is an unknown quantity at this point
Re: Pivots?
This. Compared to a bearing, less space, less cost and easier installation. Worked flawlessly.
Unread 06-09-2018, 12:14 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Pivots?
We've gotten away with using bolts for pivots for a whole bunch of things...
one trick is to use a long bolt, with two nuts, one nut on either side of the part that the pivot is attached to. Then tighten the nuts against each other, and the part that pivots can be on the bolt, retained loosely by the head of the bolt. hard to describe, and even harder for students to figure out which things to tighten...but it works pretty well, and don't cost much, or take much machining. Just drill a few holes.
Unread 06-09-2018, 03:51 AM
mman1506 mman1506 is offline
Reversible bumpers are my trigger
AKA: Marcus Quintilian
FRC #5406 (Celt-X)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Re: Pivots?
That is none of those.
2012-2015: 865 Warp7 Team Captain
2016/17: Free Agent Mentor
2018: 5406 Celt-X
Unread 06-09-2018, 08:18 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Mentor
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Pivots?
We've done this - a lot lighter and simpler and more robust than idle hex shafts in hex bearings! For lighter duty pivots, including our off-season robot's arm to raise a cube about 20" and to 45 degrees so we can launch it into a switch, we use hinges - sometimes riveted, sometimes bolted depending on the forces. For 2017 STEAMworks, we had spring hinges on two doors and a popup gear intake ramp.
Unread 06-09-2018, 09:31 AM
MrForbes's Avatar
AKA: Jim
Re: Pivots?
I guess you have a different conception of these principles, than I do.
That's ok.
Unread 06-09-2018, 11:53 AM
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Re: Pivots?
I'll give you that it isn't elegant, but it is certainly light, effective, and capable of lasting more than a season.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 06-09-2018, 12:27 PM
Inconel-oh-el Inconel-oh-el is offline
FRC #3936 (RoboBlitz)
Rookie Year: 2013
Inconel-oh-el is on a distinguished road
Re: Pivots?
That's ok.
Solutions like these honestly work acceptably if working under a deadline or at a competition, but should never be designed into the robot from the start if you try to follow best practices. Standard bolts are soft and make for terrible shafts/bearing surfaces, the threads of them make for even worse. Higher contact pressures at the crests of the threads will quickly wear away the bearing material, or vice-versa, especially if just drilled through alu. frame members. Even for stationary loads, avoid any shear forces on the threads as excess stress risers in the root will lead to decreased fatigue life/increased risk of failure. Ideally, only the shank (unthreaded portion) of the bolt is loaded in double shear (supported on both ends) and the threads/lock-nut simply retains and tensions the fastener.
More to the OP's question: For rotating joints, Shoulder Bolts work well as they are made from harder steel and ground for precise bearing surfaces and fits They also can greatly simplify an assembly over steel shaft and collars. The stationary portion of your mechanism should support the shank at both ends. The bolt does not rotate in this arrangement- all sliding interactions should happen between the ground shank of the bolt and the inner surface of the bearing. Press fit the bearing into the rotating portion of your mechanism. Oil-Embedded Flanged Sleeve Bushings work well for low speed mechanisms or incomplete rotations. Needle-Roller Bearings work well for higher speeds or when low-friction is required of the joint. Really only use them on hardened steel shafts, they will chew through aluminum pretty easily, but you can get shaft liners for larger IDs. Keep in mind any axial forces in the joint as well, as needle roller bearings will not support these. I like Nylon Thrust Washers for lighter loads as you can also stack or custom turn them to remove axial play if need be. There are other types of thrust bearings as well though, and put one on each side against the stationary faces to keep the joint from seizing when you tighten the lock-nut. Good surface finish helps. Also pay attention to any bending moments applied to the joint. Use two bearings on both sides of the rotating mechanism, and try to minimize the space in between the bearing and the inner faces of the joint, to keep the shear force on the bolt closer to ideal shear.
This is engineering "best practice" for single DOF joints with high strength, and low backlash requirements. For race teams, a common use case is the suspension rocker arms. They redirect the motion of the push/pull arms into the shocks/dampers and experience extremely high and repeated load, so fatigue is a large factor. The joints must have no play as that will translate into suspension compliance, giving the driver a poor and unpredictable feel for the car. They also must be low friction as to minimize the joints damping effect. The actual dampers should handle all damping, as that can be tuned when setting up the car, and the telemetry will more closely match the predicted model. Stiff joints will also wear quicker, bad all around, so from a maintainability standpoint these components can be replaced instead of the whole frame.
I hope this helps you OP, and I can answer some questions in regards to FRC design/manufacturability as we employed this method on the wrist joint of our intake this year, and several other places.
(full disclosure: after a revision to the carriage before the second competition, I neglected to order a new shoulder bolt for the rear pivot of the pneumatic piston that lifted the intake. We used a bolt through to Detroit. The threads bore directly on the bronze bushing we had, and the load was applied FAR from ideal shear. As expected, it quickly wore into the bushing, despite us actuating the piston a few times a match. I can't say I'm proud, but that was far from the example of "worst engineering practice". Your robot won't fall apart from a joint like that. Race cars would though)
Unread 06-09-2018, 12:36 PM
MrForbes's Avatar
AKA: Jim
Re: Pivots?
I thought we were designing robots, for a competition season. I don't use this design on my race car!
My idea of "elegant" includes figuring out what the requirements are, and designing to meet those requirements with the least cost and effort. Simplicity is good.
I guess next year's design will include the requirement to get into deep space, so we'll have to step up our game. Or maybe it will still just be a high school robotics competition?
edit: oops! I forgot...I actually did use this design on my race car, to hold the hood prop. It works great.
  #15   Spotlight this post!
Unread 06-09-2018, 01:18 PM
Rookie Year: 2013
Re: Pivots?
Simplicity is a great thing, I completely agree. On critical and non-critical mechanisms, I never want to have to worry about them failing or replacing parts on them or having to fiddle with bolt tension or ten shaft collars spaced out across the shaft- I want them to just work! Well designed joints are simple in this regard. Often lots of thought goes towards simplifying the manufacturing, and less so the reliability or maintainability.
The second half to my post was addressed at the OP who asked for examples, I know that you know how to build race cars . Its just an example use case that others can add to their repertoire, and hopefully I explained the design requirements and intent behind it well enough in my post that they would know when to use methods like this.... For me, FSAE was a natural step from FRC. Judges there will tear cars apart in design reviews if they see stuff like this. So I want my students to put that much thought into even "simple" systems like a high-school robotics competition. And it won't be next year, but eventually they will be required to get to deep space!
Disgusting. I bet it's in single shear as well, you monster. That's going to break. GTB!
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
