OCCRA
Go to Post Aww, but I ENJOY getting all up in arms about something that's ultimately inconsequential! - Cothron Theiss [more]
CD-Media
Unread 11-14-2018, 02:56 PM
FTC Team 14934 FTC Team 14934 is offline
FTC #14934
FTC Team 14934 is an unknown quantity at this point
Rover Ruckus Rules on Detaching Parts
In section G15 in the 2nd part of the manual, it says:
"Tethered components that move independent of the main Robot
are considered a detached component and are illegal."
By move independent does this mean something that can be controlled? Would it be against the rules to have a hook that detaches on the lander and uses a winch to pull the robot up?
Unread 11-14-2018, 02:58 PM
Nate Johansen's Avatar
Nate Johansen Nate Johansen is offline
Strategy 'n Stuff
FTC #15096 (The Holland BioHazards)
Nate Johansen has much to be proud ofNate Johansen has much to be proud ofNate Johansen has much to be proud ofNate Johansen has much to be proud ofNate Johansen has much to be proud ofNate Johansen has much to be proud ofNate Johansen has much to be proud ofNate Johansen has much to be proud ofNate Johansen has much to be proud ofNate Johansen has much to be proud of
Re: Rover Ruckus Rules on Detaching Parts
From what I understand that would be legal, as long as the hook can't be controlled and doesn't move independently from the rest of the bot
2013-2017 - Student, FRC 74 - Team C.H.A.O.S.
2014 FRC Champions - 254, 469, 2848, 74
2017-Present - Student, Kettering University - BSME '22
2018-Present - Mentor, FTC 15096 - The Holland BioHazards
Unread 11-14-2018, 05:17 PM
GeeTwo GeeTwo is offline
Somebody Else
AKA: Gus Michel II
<Usual caveat that Chief Delphi in general is not and I in particular am not an official source>
As I read it, the key item here is the last sentence of G15, shown in bold:
Originally Posted by 2018-2019 FTC Game Manual
<G15> Robots Deliberately Detaching Parts – Parts may not be deliberately detached from Robots during a Match or leave mechanisms on the Playing Field unless permitted by a Game Specific Rule. The consequence of deliberately detaching a part is a Minor Penalty if it does not Block an opposing Alliance Robot, Alliance-specific Scoring Element or Scoring Area. If a deliberately-detached component or mechanism affects game play by any Robot, the offending Robot will receive a Major Penalty and will be issued a Yellow Card. Robot parts that are released but remain connected by a tether are considered detached for the purposes of this rule.
Originally Posted by Orange Box
Tethered components that move independent of the main Robot are considered a detached component and are illegal.
A hook is clearly a "robot part". Intentionally detaching it on a string or similar not-even-close-to-rigid tether is against the rules "unless permitted by a Game Specific Rule". Remember, the boxes are intended to clarify the actual rules - in this case the rule answers the question directly, and the box is apparently for emphasis.
If that hook were on, say, a telescoping antenna or tool handle which was at least nominally rigid? I'd guess it was legal, but would definitely check Q&A or have a plan B to put in place at competition were I planning to do it.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
