OCCRA
Go to Post If you're sore over the vigorous defense teams play, get over it. It happens and will continue to, as the majority of people hope. - AmyPrib [more]
Unread 07-15-2018, 04:23 PM
CodeNinja CodeNinja is offline
FRC #3997 (Screaming Chickens)
Rookie Year: 2017
CodeNinja is an unknown quantity at this point
Parameters in Command
Is it possible to pass in subsystems as parameters, instead of requiring them?
This is an example of what I want to do that did not work:
Code:
package org.usfirst.frc.team3997.robot.auto.actions;
import org.usfirst.frc.team3997.robot.MasterController;
import org.usfirst.frc.team3997.robot.controllers.ArmController;
import edu.wpi.first.wpilibj.command.Command;
public class ScaleAction extends Command {
	private ArmController arm;
	private Boolean setpointReached;
	public ScaleAction(MasterController controllers) {
		arm = controllers.getArmController();
		this.setpointReached = false;
	protected boolean isFinished() {
		// TODO Auto-generated method stub
		return setpointReached;
	protected void execute() {
		if(arm.armPIDController.onTarget()) {
			setpointReached = true;
		} else {
	protected void end() {
		arm.armPIDController.disable();
	protected void intialize() {
		arm.goToScalePosition();
	protected void interrupt() {
		end();
Unread 07-15-2018, 04:26 PM
Mitch Stokes's Avatar
Mitch Stokes Mitch Stokes is offline
Berkeley Engineering
AKA: Mitchel Stokes
Rookie Year: 2014
Mitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond reputeMitch Stokes has a reputation beyond repute
Re: Parameters in Command
Code:
		} else {
		end();
The point of requiring is to prevent multiple commands from using the same subsystem at the same time. In what way did this not work, i.e. did the code crash, did the arm not move?
5817: 2016-2017
5817 Mentor: 2018
Betts Company Engineering Intern: Summer 2018
"Criticism is easier to take when you realize that the only people who aren't criticized
are those who don't take risks."
Unread 07-15-2018, 04:27 PM
Rookie Year: 2017
By the way, Master Controller is just a container class for all the other subsystems.
Here is github link: https://github.com/codeNinjaDev/FRC-...basedprototype
I am trying to integrate existing architecture with command, but I am not sure if it is possible.
Unread 07-15-2018, 04:30 PM
Rookie Year: 2017
Sorry, I meant this file:
[code]package org.usfirst.frc.team3997.robot.auto.actions;
import org.usfirst.frc.team3997.robot.controllers.ArmCont roller;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboar d;
public class SwitchAction extends Command {
public SwitchAction(MasterController controllers) {
@Override
@Override
} else {
arm.goToSwitchPosition();
SmartDashboard.putString("PID Switch", "RUnning");
end();
[\CODE}
But, yeah nothing moved.
I used this command in this file: https://github.com/codeNinjaDev/FRC-2018/blob/feat/commandbasedprototype/src/org/usfirst/frc/team3997/robot/auto/routines/OneCubeCenterAutoRoutine.java
And then I set the autonomous in AutoSelector and robotInit.
Thanks for the quick response
Unread 07-15-2018, 04:32 PM
Rookie Year: 2017
Sorry, here is the correct formatting:
Code:
	@Override
	@Override
		} else {
		end();
Unread 07-15-2018, 04:35 PM
Maxcr1's Avatar
Maxcr1 Maxcr1 is offline
AKA: Max D "Code Boy"
FRC #2169 (KING TeC)
Rookie Year: 2016
Maxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant future
Could you please expand on that? We really don't have any way to help you unless we know where the error is coming from. Is the DriverStation printing out any stacktraces? How about the RIOLog inside of Eclipse? Is everything ported correctly? Are your Talons addressed correctly? Does the system work with other code? In order to help you properly we need more information.
Max DeVos | Programmer | KING TeC 2169
Unread 07-15-2018, 04:44 PM
Rookie Year: 2017
Sorry for the confusion,
There were no errors, but the robot did not physically move.
Unread 07-15-2018, 04:45 PM
Rookie Year: 2017
And Teleop works (not using command)
Unread 07-15-2018, 04:46 PM
Rookie Year: 2017
Basically, autonomous is not working, but everything else is
Unread 07-15-2018, 04:53 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Do other commands work? In Robot.java, the scheduler isn't called, so I wouldn't expect any commands to work.
I'm struggling with why you want to structure your code like this. Passing in a subsystem doesn't seem to add any abstraction or increase the flexibility of your code.
Unread 07-15-2018, 05:06 PM
Rookie Year: 2017
No, other commands don't work.
I think I call Scheduler on line 153. I'm not very experience with command based.
I just have an irrational dislike of static objects, but I do use them sometimes. A lot like camel case vs underscores. I just want to know if we can pass them in, it is not a deal breaker.
Unread 07-15-2018, 05:44 PM
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Yes, it is possible to do this. What you are describing is a design pattern called dependency injection, and it is by far the best way (in my opinion) to add flexibility and reusability to the Command-Based paradigm.
It is still good practice to require the subsystem, and you can easily do this by just calling requires() on the passed-in subsystem.
Note that your example code seems to be passing in a much bigger object than what you're actually using. This is okay in some cases, but is generally inadvisable. You should pass in (or "inject") only what you need, unless you have a very good reason to do otherwise.
It most certainly does - you simply have to take advantage of some sort of polymorphism in your subsystems (I recommend interfaces, but inheritance can work too). One can use the same "open claw" command on many different types of claws, for example, rather than tediously and messily writing a bunch of nearly-identical commands.
It also, as the OP noted, removes the need for global state, which is basically always a good idea.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
FRC Drivetrain Characterization
Unread 07-15-2018, 05:53 PM
Rookie Year: 1997
But the OPs code doesn't do this, which is what prompted the question.
Unread 07-15-2018, 06:05 PM
Rookie Year: 2017
Yeah, the reason I used Master controller was to simplify the competition code. Before master controller, I had to pass in 7 params per command plus our architecture was redundant. I just changed the structure to command as an offseason project. But I might individualize the params, now that it is much less redundant.
Thanks your advice
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
