OCCRA
Go to Post Find what your team is good at, and use it in any way you can. - karomata [more]
Unread 07-17-2018, 07:34 AM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
CAN Debug Tools
Anyone have recommendations on good CAN debug tools for FRC?
I've used Kvaser and Vector products professionally and I know they work well, but were a bit pricy.
I also recently purchased this $25 module from SEEED Studios. Will try to play with it a bit tonight.... but, before I chase my tail too much, anyone have experience working with this yet?
Unread 07-17-2018, 12:27 PM
solomondg's Avatar
solomondg solomondg is offline
AKA: Solomon
FRC #2898 (Flying Hedgehogs)
Team Role: Leadership
Rookie Year: 2016
solomondg has a brilliant futuresolomondg has a brilliant futuresolomondg has a brilliant futuresolomondg has a brilliant futuresolomondg has a brilliant futuresolomondg has a brilliant futuresolomondg has a brilliant futuresolomondg has a brilliant futuresolomondg has a brilliant futuresolomondg has a brilliant futuresolomondg has a brilliant future
Re: CAN Debug Tools
Personally, I'm a huge fan of the CANable.
Unread 07-17-2018, 12:32 PM
marshall's Avatar
marshall marshall is offline
Online Stripe & Drape Sales
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Re: CAN Debug Tools
You can't buy them at the moment. There are some clones that exist though that are available.
The candlelight firmware based/compatible devices do seem to be the way to go though.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Clarke's Laws
Unread 07-17-2018, 01:08 PM
couvillion couvillion is offline
FRC #1818
Rookie Year: 2011
couvillion is an unknown quantity at this point
Re: CAN Debug Tools
Does anyone have any experience with SparkFun AST-CAN485 Dev Board?
Unread 07-17-2018, 01:49 PM
gerthworm's Avatar
Rookie Year: 2015
Re: CAN Debug Tools
https://github.com/HubertD/candleLight_fw
Yowza, this is super slick. I suddenly regret my $25 purchase. I'll see where it gets us, but this really seems like the better answer.
Unfortunately, no experience with the sparkfun device yet .
Unread 07-18-2018, 09:58 PM
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
Rookie Year: 2007
kylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to beholdkylelanman is a splendid one to behold
Re: CAN Debug Tools
I'm curious what type of problems and things are you wanting to debug? Given the CAN bus is almost entirely managed by CTRE and just works I've not had a reason other than curiosity to sniff it.
Personally:
From a hardware perspective I use https://www.peak-system.com/PCAN-USB.199.0.html?&L=1 They are relatively cheap when it comes to CAN tools. As other have pointed out there are much cheaper options. I've recently learned about canable and would like to switch to it. I use PCAN's because they are the tool we have standardized on at work so I have access to them.
From a software perspective I use Jupyter (IPython) Notebooks with Matplotlib and Pandas. This combination allows one to easily explore CAN traces and visualize different signals.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 07-19-2018, 06:29 AM
gerthworm's Avatar
Rookie Year: 2015
Re: CAN Debug Tools
We got our hands on a piece of non-FRC hardware that we're looking to interface to the RIO over CAN. Experimentation work so far, just barely starting the software work now. The thought was that, at some point, we were going to need to watch the packets going back and forth.
Unread 07-20-2018, 03:17 PM
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Rookie Year: 2011
Clayton Yocom has a spectacular aura aboutClayton Yocom has a spectacular aura about
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
Re: CAN Debug Tools
When we were first playing around with some CAN stuff at work we used one of the 5$ obd-ii "elm-compatible" devices and telnetting into it to get the data we want.
They are basically just CAN to Serial interpreters that have some processing overtop for common diagnostic frameworks, but you can disable all that and process the raw CAN frames -- albeit not at blazing speeds.
Member of FRC Team 45 TechnoKats : 2011 - 2016
Member of FRC Team 27 Team RUSH : 2017 - Present
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
