OCCRA
Go to Post Kudos to you IFI, for your continued support of FIRST and its stated ideals - Racer26 [more]
CD-Media
Unread 11-13-2017, 09:31 PM
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
The tools you can't get through FRC build season without?
What are the tools you can't get through FRC build season without (or wouldn't want to)?
I asked another question on Facebook and here are the answers. I tried my best to compile the best bits of the conversation and remove duplicates, etc but I probably missed some stuff.
Allen Gregory
K. Verdeyen
B. Simons
A. Spears
E. Morrison
  • We use a Dewalt DW328 with a stand from Swag Offroad, been our best tool since 2016
  • Clecos! I'm always amazed how many people don't know what they are. We don't do sheetmetal but we use a TON of versaframe and they're great for that too.
C. Cash
V. Pham
  • Something simple, but gets very handy: a rubber mallet. Could never build a robot without one.
N. Coussens
  • Clevis and air rivet gun cannot be stressed enough. Also never enough Allen key sets for when students inevitably use them. Quality diagonal cutters. Also just a brass cylinder is super useful whenever you need to bang on something but don't want a mallet. Put a counterbore into one end of the brass cylinder and it's really nice for when you need to tap on the outer race of a bearing or something.
B. Leverette
R. Stockton
J. Zondag
P. Francis
J. Chong
J. Killian
I. Rife
R. Oakley
Unread 11-13-2017, 10:09 PM
Mike Marandola's Avatar
Mike Marandola Mike Marandola is offline
Trust the Process
AKA: Mike Marandola
FRC #0316 (LUNATECS)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: The tools you can't get through FRC build season without?
A few of the non obvious tools:
-RAGE4 chop saw - Much faster and cleaner cuts than a bandsaw. I wouldn't use this without changing to a blade made for aluminum.
-Bessey 90 degree clamp - Great for quickly fastening corners. Worth $20
-A quality label maker
-1-2-3 blocks - Use them for mill setups, holding small parts, and much more. They are too cheap to not have.
-Swivel deburring tool - Use for deburring long straights and inside curves of metal and plastic. I prefer Noga
-Automatic center punches - Husky is ok because of the warranty but you can easily get Starrett punches on eBay for under $20 shipped.
-Self adjusting wire stripper
LUNATECS.org
FRC 316 Student 2007 - 2011
FRC 316 Mentor 2012 - 2017
FRC 316 Lead Technical Mentor 2018 - ?
Unread 11-13-2017, 10:39 PM
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond reputeInFlight has a reputation beyond repute
Cold Saw for nice accurate cuts.
Lathe with Quick Change tool post (BXA)
+1 on correct grooving tool
Klein off set 3/8 & 7/16 reversible box wrench ( covers both #10 and 1/2 inch nuts)
6 inch calipers, 1 inch micrometer, 6 inch 16R rule
Unread 11-13-2017, 10:47 PM
Brian M's Avatar
Brian M Brian M is offline
Design Lead
FRC #1360 (Orbit Robotics)
Team Role: CAD
Brian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond repute
Think ya meant 1/4"
Now that im here ill add some:
These are great for when you drop E-clips, shaft collars and just about anything other than plastic or aluminum inside your robot or boxtube - http://www.canadiantire.ca/en/pdp/te...-0586833p.html
For welding or just holding a piece to something when you dont have a vice, vice grips work really well - http://www.irwin.com/tools/brands/vise-grip
Lastly, these are basically the only wrenches we use, they are small, and really good for basically anything, since the ends are capped you dont have to worry about aligning the wrench on the nut - https://www.homedepot.ca/en/home/p.1...iABEgKljvD_BwE
2016 - Rah Cha Cha Ruckus Winners (3015 & 4039)
2017 - Industrial Design (Durham), Entrepreneurship (McMaster), Quality Award (Ontario DCMPS)
2018 - Georgian District Winner (1305 & 6864) + Innovation in Control, York District Winner (1325 & 6140) + Chairmans Award, Ont DCMP Excellence in Engineering
Unread 11-13-2017, 10:53 PM
tjf tjf is offline
AKA: Tim Flynn
FRC #1257 (Parallel Universe), #1228 (RoboTribe)
Rookie Year: 2016
tjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond reputetjf has a reputation beyond repute
I've sworn by these snips, they were very good in d̶e̶s̶t̶r̶o̶y̶i̶n̶g̶ tearing down field zip ties at our local offseason.
https://www.amazon.com/CHP-170-Stand.../dp/B076M3ZHBV
They're also sold by Adafruit and probably some other vendors fairly cheaply.
1257 (2016) - Student
1257 (2017-Present) - Overactive Alumnus | 1228 (2017-Present) - I do stuff
KD2KRT
Papers: Encyclopedia Robotica v2 | An FRC Anthology
Unread 11-13-2017, 11:24 PM
s_forbes's Avatar
s_forbes s_forbes is offline
plz give me red dots
FRC #0842 (Falcon Robotics)
A bench vise that's bolted to a workbench.
Unread 11-13-2017, 11:29 PM
Engineering Coach
I bought this one about 4 years ago, it's still working well.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
We've also used these sometimes as well. Come in handy at events.
https://www.amazon.com/Grizzly-H3245-6-Inch-Vise-Brake/dp/B0000DD4UW/ref=sr_1_1?ie=UTF8&qid=1510633890&sr=8-1&keywords=vise+break
Unread 11-14-2017, 12:09 AM
RobotsQ's Avatar
RobotsQ RobotsQ is offline
I break stuff. Usually intentional.
AKA: Quinn
FRC #1155 (Sciborgs)
RobotsQ is a jewel in the roughRobotsQ is a jewel in the roughRobotsQ is a jewel in the rough
Maybe I'm taking this question too literally and not revealing some hidden gem, but narrow Vice Grip/locking pliers are maybe the most used gripping tool in our shop.
https://m.lowes.com/pd/IRWIN-6-in-Lo...iABEgJC-PD_BwE
Sent from my iPhone using Tapatalk
We use thousands of dollars worth of machines to turn one piece of metal into two pieces of metal.
I do not represent my team, views and statements are my own.
Unread 11-14-2017, 01:01 AM
artdutra04's Avatar
VEX Robotics Engineer
AKA: Arthur Dutra IV
FRC #0148 (Robowranglers)
High Torque Allen Keys:
https://www.mcmaster.com/#high-torque-hex-keys/
These have a modified hex profile that makes them incredibly resistant to stripping - even on tiny sizes of ball end versions. I've been using these almost 10 years now, and have yet to strip one. I'll never buy regular hex keys again after using these.
Art Dutra IV
Senior Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Unread 11-14-2017, 01:42 AM
bobbysq bobbysq is online now
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond repute
This horizontal bandsaw. It cuts down long metal tubes and has been for the past 5 years.
Unread 11-14-2017, 02:06 AM
connor.worley connor.worley is offline
FRC #5499
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
My computer (13" rMBP)
Team 5499 (2015-present)
Past Teams: Team 973 (2016-2017) / Team 254 (2014-2015) / Team 1538 (2011-2014)
日本語副専攻です!話しましょう!
I work for Yelp on the Core Services team. Looking for a referral? Send me a message.
Unread 11-14-2017, 06:56 AM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
+1 for Allenís arbor press.
We use an ammeter (50A) frequently, to find friction so we can fix it.
Richard Wallace
since 2003
Unread 11-14-2017, 08:27 AM
Nate Laverdure's Avatar
Cynicism isn't wisdom
FRC #2363
Originally Posted by AllenGregoryIV View Post
We got this Arbor Press over the summer for around $200 with one of the MSC free shipping and 30% off coupons.
It's the cheapest press I could find that will do 1/2" Hex broaching in one stroke. https://www.mscdirect.com/product/details/00231290
Originally Posted by Richard Wallace View Post
+1 for Allen’s arbor press.
Does this work well in practice? Seems like the 1/2" hex broach is nearly as long as the "max working height" of the press, which would only let you broach thin stuff.
Unread 11-14-2017, 11:03 AM
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell has much to be proud ofdroswell has much to be proud ofdroswell has much to be proud ofdroswell has much to be proud ofdroswell has much to be proud ofdroswell has much to be proud ofdroswell has much to be proud ofdroswell has much to be proud ofdroswell has much to be proud of
Powerpole Crimper:
https://powerwerx.com/tricrimp-power...-crimping-tool
Powerpole terminals and ends:
https://powerwerx.com/anderson-power...-sb-connectors
Ferrule Crimper & Ferrules:
https://www.amazon.com/Crimping-Erno...+crimper&psc=1
Unread 11-14-2017, 12:07 PM
Engineering Coach
So far yes, the first inch or two of the broach goes into a half inch hole with only light pressure. You could start it in a lathe with no real danger to your bearings or for quick stuff you can start it by hand then press the rest of the way on the press. We drilled a hole in our workbench to allow the broach to fall through.
I've also heard heard of team's boring the press to allow the broach to fit inside it for a an inch or two and keep the broach straight. We haven't done this yet though.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
