Go to Post Its just going to be a dirt game. We are going to be using shovel bots to dig for gold. Anyone who strikes oil gets the 100 point bonus! - Uberbots [more]
Unread 02-13-2018, 05:18 PM
jinggeorge jinggeorge is offline
FRC #0128
jinggeorge is an unknown quantity at this point
red to black wire
Ok so this is probably obvious to everyone else but can someone just confirm that we can reverse our wiring for a motor (red to black/black to red) from the motor connecting to the talon
Unread 02-13-2018, 05:26 PM
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: red to black wire
On the output side, yes. Be very careful not to reverse the input side instead or you'll have a good chance of frying the Talon.
I should also note that it's generally considered better to reverse the direction in code rather than reverse the wiring.
2017 FIRST Championship Daly Division | 2017 Seven Rivers Regional Chairman's Award | 2017 Wisconsin Regional Dean's List Finalist (Grace Fanson)
Unread 02-13-2018, 05:35 PM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
^What he said.
Just to be clear, your motor wires connect to the Talon's output (Green and White) wires.
As for whether you want to reverse direction using code or by connecting the motor in the opposite polarity, there are good reasons each way. Sometimes a motor is stronger in one polarity than in the other, so switching polarity in hardware helps the robot drive straight.
Richard Wallace
since 2003
Unread 02-14-2018, 07:10 PM
garyk garyk is offline
Programming Mentor, 972 and 2643
FRC #2643 (Dark Matter)
garyk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant futuregaryk has a brilliant future
I suggest to my teams that they wire the green & white wires, to the motorís black and red wires, all the same. Itís not an electrical issue; if we have to change a motor controller at competition we donít have to remember how it was wired because they are all the same. If we have to change the direction of the motor we do it in software.
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 02-18-2018, 12:08 AM
Chief Robot Inspector
The rule that you are thinking of is this...
R61. All non-SIGNAL LEVEL wiring with a constant polarity (i.e., except for outputs of relay modules, motor controllers, or sensors) shall be color-coded along their entire length from the manufacturer as follows:
A. Red, yellow, white, brown, or black-with-stripe on the positive (e.g. +24VDC, +12VDC, +5VDC, etc.) connections
B. Black or blue for the common or negative side (-) of the connections.
The output side of any speed controller is not considered to be constant polarity. The easiest way to get your robot to move forward is to flip the polarity of the motor wiring on one side of the robot. If you don't do this (either by wire swap or software) your robot will drive around in circles.
Knowledge is power. Power UP!
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
