OCCRA
Go to Post Most of our old robots have been scrapped for parts. Our Chairman submissions are still read every year by the whole team. - N7UJJ [more]
Unread 11-14-2017, 08:54 AM
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a reputation beyond reputeBpk9p4 has a reputation beyond reputeBpk9p4 has a reputation beyond reputeBpk9p4 has a reputation beyond reputeBpk9p4 has a reputation beyond reputeBpk9p4 has a reputation beyond reputeBpk9p4 has a reputation beyond reputeBpk9p4 has a reputation beyond reputeBpk9p4 has a reputation beyond reputeBpk9p4 has a reputation beyond reputeBpk9p4 has a reputation beyond repute
Talon SRX Stand Alone?
Is there any tool that allows you to run a Talon SRX by itself. Similar to how you can run a PWM motor controller with http://www.andymark.com/product-p/am-2671.htm. This would be really nice if you could and still access all the controller nice motor controller feature the Talon SRX has.
2016 Tesla Division Finalist
2016 Central Illinois Regional Finalist
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 11-14-2017, 09:12 AM
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Talon SRX Stand Alone?
That product is using an Arduino controller to send the pwm to the motor controller, in a nice package. CTRE sells the Hero controller, to talk CAN to the SRX in much the same manner.
http://www.ctr-electronics.com/control-system/hro.html
You need to come up with the nice packaging, and the potentiometer.
The sooner we get behind schedule, the more time we have to catch up.
- Archimedes - Thanks 1058, 67, & 1640
- 6th Alliance Captain
- 3rd Alliance Captain - Finalist
- 4th Alliance Captain
- RANK 29
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie)
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
You could either use the Motor Meter connected to the SRX, if you use it in PWM mode, OR you can use the CTRE Hero which has CANTalon support built in. Alternatively you could use any other CAN-enabled microcontroller development board, but you'd probably have to make a library.
edit: sniped
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Captain, Programming Lead, Driver, 2017 Dean's List Finalist
2017-: FTC 13471 (Minnetonka) - Mentor
2017-: FIRST Volunteer - 2017 North Champs Student Ambassador
Unread 11-14-2017, 09:15 AM
firecrafty's Avatar
firecrafty firecrafty is offline
AKA: Ryan Blue
FRC #1018 (Pike RoboDevils)
Rookie Year: 2016
firecrafty will become famous soon enoughfirecrafty will become famous soon enough
There is not a way to run a TalonSRX over CAN (with control loops, voltage ramping, etc.) without a RoboRIO or CTRE's own Hero board. However, you can still use the SRX in PWM mode using the product you mentioned.
edit: sniped so hard
"Programming is a science. Writing beautiful code is an art."
Any views I express are my own and do not necessarily reflect those of my team.
Unread 11-14-2017, 09:16 AM
brian5115's Avatar
brian5115 brian5115 is offline
FRC #5115 (Knight Riders)
Rookie Year: 2015
brian5115 is on a distinguished road
My question would be what exact features you need, and in what situation is it too much work to do with a RoboRIO?
We use a Thrifty Throttle mainly to test prototypes, and in those cases we're not trying to do any kind of closed feedback, voltage compensation, etc. that we do on the finished mechanism. It's possible to wire a Talon SRX to take a PWM signal, but I wouldn't dedicate such an expensive part to something that a Spark or Victor can do the same.
If you want to avoid writing code, you can do some stuff with the Talons through the RoboRIO web interface (I haven't looked into this very much beyond "blink LED" to make sure I have the right id's). But it sounds to me like you want to cut out most of the control system entirely. I don't think there's any easy way to do that.
District Event Winner - Northern Maryland
Excellence in Engineering - Northern Maryland
2017:
District Event Winner - Central Maryland
Unread 11-14-2017, 09:26 AM
Bpk9p4's Avatar
FRC #1756
what i would like to do i have a setup so we could tune a PID controller really fast for prototypes using the web interface without having to write any code. Since we do not have many Roborio around. This could also be a easy way to teach students how PID work
Unread 11-14-2017, 10:15 AM
firecrafty's Avatar
AKA: Ryan Blue
Rookie Year: 2016
You can't tune PID with the web interface, it does require code to work. To teach PID you could use an Arduino, but that requires some overhead. I would recommend setting up a test bench type setup with a few motors and sensors and a RoboRIO and using PID to control the motors (set to a certain position, hold at a set speed).
Unread 11-14-2017, 11:19 AM
Bpk9p4's Avatar
FRC #1756
Good to know. We currently do the test setup with the roborio just would be nice to get a cheap version so we could have a more 1 to 1 robot to student ratio
Unread 11-14-2017, 11:29 AM
phurley67's Avatar
phurley67 phurley67 is offline
Programming Mentor
AKA: Patrick Hurley
phurley67 will become famous soon enough
As mentioned the HERO board, which has a number of modules including a screen, can be had pretty cheap (especially relative to the price of a RoboRIO), but the packaging and the code for a nice interface (the HERO programs in C#) is on you.
Having a code/rio free method to tune PIDs on the talon would be nice. I bet by the time I get around to it, CTR will have their own version better than the one I will throw together.
Lightning Robotics -- Give me an Aaaaa
Unread 11-14-2017, 01:22 PM
Bpk9p4's Avatar
FRC #1756
yea i am thinking about doing something on the HERO. Could be a fun project
Unread 11-14-2017, 01:54 PM
AdamHeard's Avatar
Lead Mentor
Hero + logitech F710
Unread 11-14-2017, 03:36 PM
phurley67's Avatar
Programming Mentor
AKA: Patrick Hurley
Hero + GADGETEER WIFI MODULE and just connect with your phone.
Unread 11-14-2017, 04:37 PM
Bpk9p4's Avatar
FRC #1756
now that would be cool
Unread 11-14-2017, 06:00 PM
asid61's Avatar
asid61 asid61 is offline
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
I would do HERO + display + controller. Display to display your selections and the controller to modify PID constants. Altogether around $100 but it can control your whole robot.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016
