Go to Post It's really quite amazing what people will find time to talk about in the month before kickoff. - Ekcrbe [more]
Unread 01-11-2018, 10:00 AM
Marston Marston is offline
FRC #5870 (League of Logic)
Rookie Year: 2015
Marston is an unknown quantity at this point
What size drive train is your team making?
Hi all! I was wondering which style of drive train is your team planning on doing or have done. Is your team going to fit the maximum size restraints? Which way will you orient your drive train? Will you be doing long bot, wide bot, square bot, or something different?
Thanks!
Unread 01-11-2018, 10:53 AM
I_AM_Clayton's Avatar
I_AM_Clayton I_AM_Clayton is offline
Jr./Build Captain
AKA: Clayton Miller
FRC #3397 (Robolions)
Team Role: Driver
I_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond reputeI_AM_Clayton has a reputation beyond repute
Re: What size drive train is your team making?
Thanks!
3397 is looking into creating a small robot (smaller than the size restraints) using a mecanum drive, medium height. Not finalized though
2014 Gateway Robotics Challenge Winners with 1985 and 2481
Unread 01-11-2018, 11:30 AM
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
A longer wheelbase is a stabilizing factor for tall robots (arm or elevator). A small footprint will be useful for getting two or three robots to climb on the dinky little RUNG, or for being able to drive onto the unpredictable ramps that others will definitely be deploying. So, it's really a tradeoff; do you want increased stability, or decreased footprint?
http://www.angelbotics.com
Remember why you're doing this.
Unread 01-11-2018, 11:33 AM
mrnoble's Avatar
teacher/coach
I'd also recommend avoiding the boundaries of your size constraints. At the very least, please design your robot to be 1" smaller than the max in every dimension. You will not regret it!
Unread 01-11-2018, 11:50 AM
GeeTwo's Avatar
GeeTwo GeeTwo is online now
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We're going tall to put cubes in the scale, and be able to climb from the rung. 99% sure we're building the kit chassis in long configuration (32.3") x 27.5" wide.
Unread 01-11-2018, 01:56 PM
ClayTownR's Avatar
ClayTownR ClayTownR is offline
AKA: Clayton
FRC #0100 (WildHats)
Team Role: CAD
Rookie Year: 2015
ClayTownR is just really niceClayTownR is just really niceClayTownR is just really niceClayTownR is just really nice
Were going with 27.5 wide by 32.5 long. Were not quite yet sure how tall wed be but its probably going to be close to the limit.
FTC 4800, 2015-
FRC 100, 2016-
Unread 01-11-2018, 02:16 PM
rlance's Avatar
rlance rlance is offline
FRC #5550
rlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond reputerlance has a reputation beyond repute
I think we are doing 33 wide and 28 long. We need the width because of how we are pulling the power cubes into our robot. Keeping our weight at the bottom of our robot will be crucial to avoid tipping over since we are planning on doing the climb and scale.
Unread 01-11-2018, 02:42 PM
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Don't do wide. We did last year and it was awful. The cubes are 13 inches wide. You can go much narrower. The field is not very good for wide robots. There are fairly narrow points between the ramp and switch, and also the null zone.
Unread 01-11-2018, 02:50 PM
rlance's Avatar
FRC #5550
The NULL Territory is a safe zone and a little more than twice the width of our robot, so I'm not sure the team will see that as an issue.
The area between the switch and ramp would be more of our problem, depending on our strategy.
Thanks for the heads up. I'll mention the issue to my team tonight.
Unread 01-12-2018, 01:07 AM
Cvlad23 Cvlad23 is offline
FRC #0226
Cvlad23 is an unknown quantity at this point
Hey, we are making a 21.75 by 32.75. we do not know our height yet, still have not decided. Also, a 6 cim west coast.
Unread 01-12-2018, 01:08 AM
FRC #0226
Hey, we are making a 21.75in. by 32.75in. we do not know our height yet, still have not decided. Also, a 6 cim west coast.
Unread 01-12-2018, 09:52 PM
ChopinWood ChopinWood is offline
AKA: Paul Braun
FRC #0068 (Truck Town Thunder)
ChopinWood is an unknown quantity at this point
We had originally decided long strategically, but during the initial design review, all of the design subteams revealed their wish that wide would be better to implement our functional requirements. So that was kind of nice and painless. We always do tank drive. 4" wheels were agreed upon for a better approach angle.
Unfortunately now we're split on 4 traction vs 4 traction + 2 omni.
Any opinions on maneuverability?
Unread 01-12-2018, 09:54 PM
SwissArmy4057's Avatar
SwissArmy4057 SwissArmy4057 is offline
FRC #4057 (STEAMPUNK Robotics)
SwissArmy4057 is an unknown quantity at this point
Kit bot in the long orientation. 6-wheel drop center, west coast. Estimated 32x27 or so, but I might still shave another inch off the width.
Originally toyed with the idea of making either a very narrow or generally small bot, but after doing some tests with two 2x4 boards bolted to example square frames stability for reaching the scale or climbing bar is going to be paramount.
Unread 01-13-2018, 09:29 PM
GeeTwo's Avatar
AKA: Gus Michel II
If you want to bring cubes into the frame perimeter through a gap in the bumpers, 25" is the minimum chassis width - which has the cubes scraping both bumpers on the way in. A wide chassis is also good for stability with a high CoG in a turn. That said, there's certainly validity in having a small fast robot along the same lines as some of the tiny off season STEAMworks bots that can only score via the switch and exchange and is easy for another robot to lift through a ramp or buddy climb and can zip through those tight spaces.
Unread 01-13-2018, 09:47 PM
mrnoble's Avatar
teacher/coach
We eventually settled on a size bigger than I had hoped for, but which suits our team's goals for this game: 29.5" long, 26" wide. Good luck, everyone!
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
