OCCRA
Go to Post FIRST inspired me to become a pain in the patootie or something. :) - Madison [more]
Unread 12-06-2017, 10:33 AM
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
rod@3711 is an unknown quantity at this point
Can't download via wifi if om5p at 5ghz
We are required to reconfigured our 9m5p radios for 5ghz only for an upcoming off-season event.
After reconfiguration, we can still communicate via Wifi with Driver Station and Smart Dashboard, but we cannot deploy code from Eclipse. We have to use the USB cable between PC and RoboRio to deploy.
Same story on 3 systems, 2 with OM5P-AC and one with OM5P-AN.
We code in C++.
This is not a show-stopper, but it is annoying.
Unread 12-06-2017, 10:34 AM
marshall's Avatar
marshall marshall is offline
Discerning and exacting individual
FRC #0900 (The Zebracorns)
Re: Can't download via wifi if om5p at 5ghz
We code in C++.
Does the laptop support 5ghz wifi?
Clarke's Laws
Unread 12-06-2017, 10:46 AM
Try this with the older OM5P-AN model:
When you use the Radio Config Tool
either uncheck BW Limit
or add a WPA key
There is also a reported problem with a 2.4GHz setting blocking the port Eclipse uses, but you shouldn't be running into that.
2018 Beta Testing Results
Unread 12-06-2017, 11:48 AM
AKA: rod nelson
This worked on OM5P-AN. uncheck BW Limit.
I will try the OM5P-AC this evening.
Thanks
Unread 12-06-2017, 11:57 AM
Beta testing has confirmed that this problem is fixed in the 2018 radio config tool, soon to be released.
Unread 12-06-2017, 02:11 PM
AKA: rod nelson
Removing the check on BW Limit when configuring radios for 5ghz, worked on both OM5P-AN and OM5P-AC
Thanks
