OCCRA
Go to Post Gearboxes and 2x balls and pull up bars, oh my! - Marc P. [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 10-27-2017, 04:55 PM
Aleyhan Aleyhan is offline
FRC #6874
Aleyhan is an unknown quantity at this point
New SRX green-yellow can wiring
Hi;
We are new at FRC and we are trying to understand SRX and we connected like this https://i.hizliresim.com/vJJBW6.jpg is it true ? we didn't use pwm ports.Sorry for bad english.
Thanks
Unread 10-27-2017, 05:01 PM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: New SRX green-yellow can wiring
For CAN, the SRXs should be connected green to green and yellow to yellow, with the roborio on one end and the PDP on the other. You can have the PDP in the middle, but will you need to set the PDP termination jumper to "off" and put a 120 ohm resistor on the end of the chain between the yellow and green wires.
Without actually seeing your wiring, we can't tell you that you did it correctly. But if you followed that diagram, you should be okay.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 10-27-2017, 05:37 PM
FRC #6874
Thanks for your help.
There is a picture of wiring https://i.hizliresim.com/5GGj2q.jpg picture is bad but I wish you will understand .Thanks again and I am waiting your Message.
Unread 10-27-2017, 11:36 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Not all of the wire-to-wire connections are clear, but if they are all green to green and yellow to yellow (as many of them appear though some are uncertain), and the jumper on the PDP is in the ON position (this one is not clear at all), that's it!
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
