OCCRA
Go to Post Bottom line is I love FIRST and what it stand for. Hold nationals in a corn field on old crates and I'll support it! If the FIRST staff is reading, Thank you for all the hard work you do! - Gene F [more]
Unread 09-12-2018, 03:39 PM
risho900 risho900 is online now
FRC #6897 (Astraea Robotics)
Rookie Year: 2015
risho900 will become famous soon enough
Encoders
My teams want to start using encoders for our autonomous so any recommendations for an encoder we can get working in about a month and a half?
Unread 09-12-2018, 03:44 PM
arduinokid55's Avatar
arduinokid55 arduinokid55 is offline
FRC #5275 (TIME Bots)
Team Role: Mechanical
Rookie Year: 2013
arduinokid55 is an unknown quantity at this point
Re: Encoders
CTR encoders work really well if you are using Talon SRX's for your drive motor controllers. There is lots of documentation available.
Unread 09-12-2018, 03:50 PM
Rookie Year: 2015
Re: Encoders
Currently, our drive train is controlled with Sparks
Unread 09-12-2018, 04:48 PM
CEF CEF is online now
FRC #5607
CEF has a reputation beyond reputeCEF has a reputation beyond reputeCEF has a reputation beyond reputeCEF has a reputation beyond reputeCEF has a reputation beyond reputeCEF has a reputation beyond reputeCEF has a reputation beyond reputeCEF has a reputation beyond reputeCEF has a reputation beyond reputeCEF has a reputation beyond reputeCEF has a reputation beyond repute
Re: Encoders
You might try this one
https://www.mouser.com/ProductDetail...6?r=706-63R256
Teams commonly connect those to shafts using a short length of surgical tubing, but you'll see people suggest stiffer tubing.
This gives 2 channels of 256 pulses. Each pulse has two transitions, so you get 1024 transitions per revolution.
It's about $55 at Mouser. I don't know why lower-resolution encoders are more expensive.
Unread 09-12-2018, 04:51 PM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: Encoders
CTRE magnetic encoders (also sold here and here) will give you the best bang for your buck. They're relatively inexpensive, multi-purpose, easy to use, and relatively fault tolerant. If you aren't using SRX's on your robot you'll need to use mag encoder breakout boards (sold by CTRE, AM, Vex, etc), but even that doesn't break the bank compared to some other options. They would be my recommendation.
Other popular encoders include:
Greyhill encoders (models 61R, 63K, and 63R). They are sturdy and reliable, but usually very expensive.
USDigital E4T encoders. These can mount directly to the kit chassis, but they're pretty delicate and finicky. I've personally broken a few just trying to install them.
CIMcoders. They are even more delicate and finicky than the E4Ts, but very easy to mount. My team has actually used them successfully, but most people recommend against them.
AMT103-V kits. These have been available from FIRST Choice for the past few years, and they work decently. They aren't particularly easy to mount, but they're definitely worth 20 credits if you have them to spare.
AM Mag encoders. These seem to be a copy of the SRX mag encoder, but I have never used them or heard any reviews so I can't really comment.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 09-12-2018, 04:54 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
In Transition
AKA: Gus Michel II
Rookie Year: 2013
Re: Encoders
In that case, you will have to connect the encoders to DIO ports.
Which encoders to get is mostly a function of what gearbox you're using; get something that fits the gearbox, and life will be simpler. If your gearboxes have magnetic shaft ends, you can still use the SRX encoders, using one of the COTS breakouts. AndyMark carries their own and the one from CTRE.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Unread 09-12-2018, 07:28 PM
Prateek M's Avatar
Prateek M Prateek M is offline
Kotlin Master Race
FRC #5190 (Green Hope Falcons)
Rookie Year: 2018
Prateek M is on a distinguished road
Re: Encoders
No matter what encoder you get, I would recommend mounting it to the output shaft instead of in the gearbox so that you can measure actual wheel rotation. Otherwise, your values may be affected by gear backlash.
Unread 09-12-2018, 09:48 PM
Owen Busler's Avatar
Owen Busler Owen Busler is offline
no team (Volunteer)
Rookie Year: 2014
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Re: Encoders
These from us digital are very robust
https://www.usdigital.com/products/e...otary/shaft/H1
However they are expensive. When you call to place an order inform them you are an FRC team and they will give you the next pricing bracket on your order.
Unread 09-12-2018, 10:31 PM
Type's Avatar
Type Type is offline
AKA: AJ
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud of
Re: Encoders
+1 for CTRE Encoders.
We've used them in multiple cases between drivetrains, shooters other mechanisms (VexPro Versaplanetary encoder). Very nice all around encoders, and nice to have spares that all are interchangeable across the robot.
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
Unread 09-13-2018, 02:24 AM
Nick.kremer's Avatar
Nick.kremer Nick.kremer is offline
FRC #3512 (Spartatroniks)
Rookie Year: 2011
Nick.kremer is a jewel in the roughNick.kremer is a jewel in the roughNick.kremer is a jewel in the rough
Re: Encoders
I can vouch for the AMT103's. We used them this year on our drive train and they worked flawlessly. Once you figure out the mounting they are actually super easy to install.
Edit: We bought ours on digikey.
Team 3512 : 2013 - Present : Mentor & Co-Drive Coach
Check out Team 3512's Website!
Like us on Facebook!
Unread 09-13-2018, 05:58 AM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
Re: Encoders
Do you folks have a strategy for how you want to control the robot using encoders yet?
Unread 09-13-2018, 07:07 AM
Rookie Year: 2015
Re: Encoders
Not exactly. Suggestions?
Unread 09-13-2018, 07:43 AM
gerthworm's Avatar
Rookie Year: 2015
Re: Encoders
Here'd be my (long-term) pecking order of things to get working:
1) Read distance traveled in ft from each side of the drivetrain. Verify with a measuring tape that the measured distance in software matches the actual distance traveled.
2) Write an autonomous routine that runs the motors until a certain distance is reached, then turns them off.
3) Write an autonomous mode that slowly ramps up and down the speed near the endpoints of travel. This should give you a super robust "drive forward" auto that stops exactly at the programmed distance.
The next steps would involve reading the speed off of the encoder, and starting some closed-loop algorithms to control the speed to a setpoint. From there you can move on to motion profiling or more complex auto movement.
Unread 09-13-2018, 09:27 AM
GeeTwo's Avatar
In Transition
AKA: Gus Michel II
Rookie Year: 2013
Re: Encoders
Most AndyMark drive train gearboxes (in particular toughbox series and EVO series, among others) provide an encoder shaft stub which is physically part of the output shaft, just on the other side of the gearbox. Most single speed gearboxes, and shifters where the shifting shaft is not the output shaft could be similarly modified by boring a shallow* hole on the back of the drive shaft and glueing in an SRX encoder magnet.
OBTW, if you don't have a lathe or other device to find the center of your shaft, you can adapt this drill press technique to hit the center.
* shallow enough so as not to weaken the shaft significantly, deep enough to hold the magnet square. I'm thinking about 1/8" to 3/16" deep.
  #15   Spotlight this post!
Unread 09-13-2018, 10:14 AM
BCR-Jim BCR-Jim is online now
FRC #6886 (Synthesizers)
Team Role: Coach
Rookie Year: 2015
BCR-Jim has much to be proud ofBCR-Jim has much to be proud ofBCR-Jim has much to be proud ofBCR-Jim has much to be proud ofBCR-Jim has much to be proud ofBCR-Jim has much to be proud ofBCR-Jim has much to be proud ofBCR-Jim has much to be proud ofBCR-Jim has much to be proud of
Re: Encoders
How did you keep the shaft from spinning inside the plastic adapter cup? Ours worked great for until about 1/2 way through our 2nd competition. We believe the adapter cup was spinning on shaft, which led to inconsistent results. We tried a dab of superglue inside the adapter cap which helped on short-term, but superglue apparently caused the adapter cap to deteriorate and break. Any suggestions would be appreciated as they seemed to work quite well.
________________
6886 -- Mentor
2018 Rookie All-star -- Heartland
2018 Highest Rookie Seed -- Heartland
2018 Highest Rookie Seed -- Greater Kansas City
2018 Highest Rookie Seed -- Galileo Division
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
