OCCRA
Go to Post When you start thinking of FIRST as a robotic building contest you have left the pavement and you are in deep weeds. - KenWittlief [more]
CD-Media
Unread 09-13-2018, 08:04 AM
cpapplefamily's Avatar
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to behold
1/2" hex through shaft encoders
The thread Encoders got me thinking. We are currently building our first WCD type chassis with shifting gear boxes. There seems to be some discussion on the negative to putting the encoders on one of the intermediate stages of the gearbox with the mounting locations supplied. Has anyone considered mounting an encoder similar to a CIMcoder or AMT103-V kits on the axle? It would be a nightmare to work on but if your not using the inside of the tube for chain there is a <1" of unused shaft there to use a hollow shaft encoder. Or build it right into this thing.
Even Beyond WCD Chassis there would be uses to encode mid shaft vs all ways finding ways to mound at the end.
It makes sense in my mind.
Unread 09-13-2018, 08:45 AM
AriMB's Avatar
AriMB AriMB is online now
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: 1/2" hex through shaft encoders
This is the closest thing I've seen, thanks to team 5406. AFAIK there is no COTS encoder with a hex bore.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 09-13-2018, 09:12 AM
Chris is me's Avatar
on a break
AKA: Pinecone
no team (formerly FRC 3929, 228, 2791)
There's not really any appreciable advantage to putting the encoder on the output of the gearbox vs mounting it on one of the other wheel shafts, as many teams do. It's a lot easier to do (can just drill a .25" hole) and to maintain / access.
Sort-of looking for a new team in or near Chicago; PM me if you have a lead.
Mentor: 3929 (2018)
Mentor / Drive Coach: 228 (2016-17) - 2016 RIDE Winner &
Consultant: 2170 (2017)
College Mentor: 2791 (2010-15) Build Photos - 2013 WPI Finalists, 2012 BAE Finalists
Student: 1714 (2009) - 2009 MN 10K Lakes Winners
Unread 09-13-2018, 09:26 AM
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
We did our first WCD chassis last year, and ended up mounting some Grayhill encoders on one of the non-gearbox shafts. It was pretty straight forward to build a mount to hold the encoder approx in line with the shaft, and connect it to the shaft with some surgical tubing (accounts for any misalignment). We are always looking for better ways, though!
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016-2018; Iowa 2017; Northern Lights 2018; Great Northern 2018-2019
Division LRI: Galileo 2016; Tesla 2017; Archimedes 2018
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 09-13-2018, 10:30 AM
Rookie Year: 2015
I really like this solution.
Its true there are solutions to put the encoder on one of the other driven axles with current hardware.
Unread 09-13-2018, 10:45 AM
Nick.kremer's Avatar
Nick.kremer Nick.kremer is offline
FRC #3512 (Spartatroniks)
Rookie Year: 2011
Nick.kremer is a splendid one to beholdNick.kremer is a splendid one to beholdNick.kremer is a splendid one to beholdNick.kremer is a splendid one to beholdNick.kremer is a splendid one to beholdNick.kremer is a splendid one to beholdNick.kremer is a splendid one to behold
Vex makes the VersaPlanetary Universal Female Output Shaft Kit, which makes integrating a VP Encoder into a drive train that much easier, no custom hex adapter required!
Now, the only thing you need to make custom is a bracket to hold the VP encoder onto the end of the shaft.
Edit: I'm wrong and didn't read the thread title, please ignore me.
Team 3512 : 2013 - Present : CAD/Design Mentor & Co-Drive Coach
Check out Team 3512's Website!
Like us on Facebook!
Unread 09-13-2018, 10:54 AM
Rookie Year: 2015
I'm looking for through shaft encoders. These adapters look like it would only get you end of shaft coupling. Still a interesting way to use products you may already have for a use not originally intended.
Unread 09-13-2018, 11:23 AM
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
I've fantasized about a through shaft hex bore encoder for a long time. We'd use the heck out of it.
Modifying the versaplanet is too expensive and heavy for my liking.
I'd also like it fully supported on its own small bearings so that it can be placed floating on a shaft, and literally tapes,glued or zip tied to something rigid.
Would be game changing for a lot of teams.
Please take the GreyT Products survey here!
2x1 and 2x2 1/16" wall tubing for sale!
Need help? Check out 973 Remote Assistance and Mentorship Program.
2017 "World Champions"
2014 Galileo Champions
2011 World Champions
Unread 09-13-2018, 11:33 AM
Rookie Year: 2011
Talking Re: 1/2" hex through shaft encoders
Huh, I guess it would help to actually read the thread title. Whoops.
Unread 09-13-2018, 12:01 PM
marshall's Avatar
marshall marshall is offline
Online Stripe & Drape Sales
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Paging CTRE, Vex, and AM (or others). We'd probably jump in line for this too provided it is more closely related to the CTRE Mag encoder than to to the CIMCoder.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Clarke's Laws
Unread 09-13-2018, 12:10 PM
Rookie Year: 2011
I can definitely see the appeal of a product like this. Something that's basically plug and play, no ulta precise positioning required would be a huge benefit. Heck, you could even match drill the mounting holes in place with a hand drill if you felt zip ties or tape wasn't robust enough.
There's definitely been a lot of progress on the front of making encoders more accessible what with gearboxes coming standard with encoder mounting options, and of course the VP encoder, but neither of those is appropriate for all applications in FRC.
Unread 09-13-2018, 12:44 PM
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
Rookie Year: 2010
feverittm has a spectacular aura aboutfeverittm has a spectacular aura aboutfeverittm has a spectacular aura about
With regard to the OP's original question about encoders on a WCD chassis, I would have to agree with previous comments that it is far easier to mount the encoder on the other wheel shafts. We have done this for the past few years and it works well. We mount a CTRE Mag encoder on a 3D printed mount that spaces the encoder properly and machine our wheel shafts to accept the magnet for the encoder (similar to how it is shown in the user guide).
Personally I have always felt that every robot needs a minimum of wheel encoders and a gyro to enable basic autonomous. While there are other ways to measure distance, encoders are simple and relatively cheap.
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 09-13-2018, 02:13 PM
Rookie Year: 2015
I just finished probing the web for multi poll ring magnets to maybe try and create a solution. I found Phoenix American Magnetic Encoder solutions. Turns out they make the CIMCoder already.
Unread 09-13-2018, 02:23 PM
AdamHeard's Avatar
Lead Mentor
Bogen encoder has a few options that are very workable, but would require some redesign and custom integration for the magnet.
  #15   Spotlight this post!
Unread 09-13-2018, 02:50 PM
OwenD's Avatar
OwenD OwenD is offline
AKA: Owen Dray
FRC #2067 (Apple Pi)
Team Role: CAD
Rookie Year: 2016
OwenD is a splendid one to beholdOwenD is a splendid one to beholdOwenD is a splendid one to beholdOwenD is a splendid one to beholdOwenD is a splendid one to beholdOwenD is a splendid one to behold
+1 to this. We used the modification to the VP encoder that 5406 made which worked pretty well for us, but an actual product would be a godsend.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
