OCCRA
Go to Post FIRST, in itself, will not make you an engineer. - RogerR [more]
Unread 09-06-2018, 04:11 AM
AriMB's Avatar
AriMB AriMB is online now
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Reinvisioned Sheet Metal Drivetrain
Most people in FRC know what a sheet metal drivetrain is: it's the kind of drivetrain that 148 and other teams build every year, made from thin, bent pieces of riveted-together, CNC cut sheet metal. It is arguably the style that gives the most design flexibility, yet takes the most experience and resources to produce at a competitive level.
Inspired by poohbear, I'd like to introduce to the FRC community a new type of sheet metal drivetrain, which only requires a CNC router/waterjet/laster cutter to make.
The drivetrain is built from flat sheets, which are stacked to make a 3D shape. Easy to make, and easy to build. Only weighs a bit over 50 lbs.
The bellypan layer: https://i.imgur.com/67PQnAI.png
The middle layers: https://i.imgur.com/VIVr1aq.png
Middle layers with bearing cutouts: https://i.imgur.com/oIXFHmD.png
For those who can't tell, this whole post is /s
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 09-06-2018, 04:38 AM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Reinvisioned Sheet Metal Drivetrain
I love this thing! It reminds me of a transformer core, but to use it that way you would need to build with steel plates instead of aluminum.
Built with steel, it would be the ultimate box-on-wheels defensive ram-bot.
Then after the season you could use it anchor a buoy.
Richard Wallace
since 2003
Unread 09-06-2018, 06:13 AM
marshall's Avatar
marshall marshall is offline
Online Stripe & Drape Sales
FRC #0900 (The Zebracorns)
Iím pretty sure it would attract small moons into orbit around it.
Clarke's Laws
Unread 09-06-2018, 08:00 AM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
At first I was like "Eeeew that seems horrible" then I thought a bit more and and actually this seems pretty slick. The big power I see in it is getting the angles more precise than you could with gusseted tubing. Additionally, even though this shows the basic WCD, I could see where you design a much more complex shape to have mount points for other parts, intakes, etc. and retain that same precision.
I feel like there could still be a lot of waste with the design presented (all those center cutouts), but more complex shapes could present more opportunity to inter-populate layers on one piece of aluminum. I could also see 3d-printing-like optimizations where inner layers are removed where not structurally needed to save weight.
Unread 09-06-2018, 08:02 AM
gerthworm's Avatar
Rookie Year: 2015
Built with steel ...
Did it once in college. 0/10 do not recommend.
Unread 09-06-2018, 08:33 AM
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
So....would that mean that you 10/10 DO recommend?
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Lead at Oregon events
2017 Autodesk Volunteer Award
Unread 09-06-2018, 09:05 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by marshall View Post
I’m pretty sure it would attract small moons into orbit around it.
This could be a good thing for 2019 - there's a decent chance that small moons will be the game pieces. It will likely take a few Q&As to determine if orbiting game pieces are considered to be controlled by the robot.
#thechassisisthemanipulator
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Unread 09-06-2018, 09:43 AM
Nick.kremer's Avatar
Nick.kremer Nick.kremer is offline
FRC #3512 (Spartatroniks)
Nick.kremer is a jewel in the roughNick.kremer is a jewel in the roughNick.kremer is a jewel in the rough
Why have the outer frame rails if it's a WCD style drive train? For easier bumper mounting?
Check out Team 3512's Website!
Like us on Facebook!
Unread 09-06-2018, 10:02 AM
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
That's seriously cool but the amount of waist would be huge.
"Champions are champions not because they do anything extraordinary but because they do the ordinary things better than anyone else." óChuck Knoll
Unread 09-06-2018, 10:22 AM
MikeBrock MikeBrock is offline
MikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond reputeMikeBrock has a reputation beyond repute
if you made a fully composite version of this it would be kind of cool
Team 354 (2008 - 2010) G HOUSE!
PA Volunteer (2012-2015)
Systems Engineer
Unread 09-06-2018, 10:37 AM
gerthworm's Avatar
Rookie Year: 2015
Syntax unclear. We'll call this a Spanish style negative reinforcement.
Originally Posted by IndySam View Post
... the amount of waist would be huge.
Ha! I see what you (intentionally?) did there!
Unread 09-06-2018, 11:32 AM
philso philso is offline
Cool concept, Ari. Is there any reason that the middle layers cannot be just "strips" or event short sections in strategic locations that function as spacers? Only the top and bottom layers would be complete "rings" that function much like the gussets do when building a chassis out of 2 x 1 tubing.
Unread 09-06-2018, 02:19 PM
AriMB's Avatar
FRC #5987 (Galaxia)
This was never actually meant to be a real proposal, it was a joke. I thought (and still think) this is a bad idea and has no real benefits over a traditional WCD. But since some people actually want to take it seriously, I'll answer some questions:
I checked, and if you made the chassis out of steel it would weigh about 110 lbs. That leaves a cool 10 lbs for electronics and manipulators. No sweat
I always use an outer rail in my WCDs mainly for easier bumper mounting, but also for increased stiffness, wheel protection, and manipulator mounting points. I know there are other ways of doing the same things without the rain, but usually it's just a thin piece of C channel that doesn't weigh much, not a solid block of aluminum.
Thanks! I could definitely spend time on weight savings and shave a good amount off. I made this as a joke though, so I didn't put a lot of time into it.
Unread 09-06-2018, 02:25 PM
I have to respect the gravity of that remark.*
*Especially from someone who is much better known for levity.
Richard Wallace
since 2003
Unread 09-06-2018, 03:32 PM
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
If you designed all the way through before you cut, you could probably cut your smaller components out of the empty... still a lot of waste though.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
