Go to Post A very important thing that I learned is how to think, not what to think. - Anna B. [more]
Go Back   Chief Delphi > Technical > CAD
Unread 07-19-2018, 05:01 PM
RickyRobot RickyRobot is offline
AKA: Ricky Marcus
FRC #1745 (The P-51 Mustangs)
RickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud of
Vex Configurable Parts in Onshape!
Building on some of the newest features built into Onshape. I hereby introduce configurable VexPro Parts!
Just search '1745' when inserting parts into your assemblies. You'll find the following with more to come:
  • Motors (Switch seamlessly between CIM and MiniCIM)
  • Hex Spacers and Standoffs
  • Sprockets
  • Gears
  • Gearboxes
  • Shafts of Custom Length
  • VersaFrame Extrusion of Custom Length
  • Bearings
  • Pulleys* (Coming Soon)
What does this mean for you?
Change the length of a shaft without having to model it yourself or use a 'Move Face' feature. Change from a 12T sprocket to a 22T sprocket seamlessly. Change from a hex bearing to a thunderhex bearing or a 1/2" round bearing. And so many others!
One of the current downsides of Onshape is it's inability to easily replace one part with another. All the mates will break and have to be redone. Now you can insert a part, like a gear or sprocket, and then change it to a similar part without mates breaking. It will just update! After you have inserted it, change between configurations by right clicking on the part in the assembly and select 'Change Configuration...'
Part numbers are used as extensively as possible so they should come up correctly on your BOMs. Part numbers and names do not not work on configurable length parts at this time due to Onshape limitations. Materials, appearance, and weights should be mostly correct.
How do you use them?
There are two ways to use a part in Onshape.
  1. Most commonly, you will insert a part into an Assembly. Then use mate connectors to place and constrain the part.
  2. Sometimes, you'll want to bring the part into a Part Studio using the Derived feature. This will allow you to add features to the part, like grooves in a shaft or extra holes in a piece of rectangular tubing. Don't forget that I have a 'Custom Extrusion' Featurescript available that might better suit your needs in this case, but everyone likes to do things differently.
For more complex configured Part Studios such as the WCD SS Gearbox, you must configure it correctly upfront then insert it into an assembly. Don't forget to select all these parts and group them so they don't move relative to one another!!! If you're super fancy, you can only group some of the parts and then add gear relations where appropriate. I recommend inserting the parts into their own assembly then adding that gearbox assembly to your robot. It will be difficult to switch back and forth between different configurations of a gearbox (at least until Onshape introduces Assembly Configurations), but at least you can have your CAD quickly reflect your purchases.
Disclaimer: Please understand that I am generating these parts myself. This was significantly more involved than just importing Vex's STEP files. Part profiles, specifically gears, will not be 100% identical to Vex's files. But they are pretty close and shouldn't affect your CAD models. The only caveat is be careful that you are paying attention when using the parts to 3D print.
While you have the ability to make copies of public Onshape Documents, keep in mind that your copy will not receive any fixes/future updates that I make to my master Document.
Please let me know if you find any mistakes or have any questions about using these parts (how or why). If you have any part/assembly requests, I will try to accommodate before the 2019 FRC season begins.
Mechanical Engineering Mentor for FRC 1745 and FTC 13140/13141/13142
Unread 07-20-2018, 10:11 AM
asid61's Avatar
asid61 asid61 is offline
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Re: Vex Configurable Parts in Onshape!
Have you seen MKCAD? It would be nice to integrate both libraries together to make them more consolidated.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016 (student)
2018 Davis Finalists (w/ 6474 and 3880), 2018 Roebling Winners (w/ 3476, 1323, and 1778)
Unread 07-20-2018, 10:41 AM
AKA: Ricky Marcus
Definitely aware of MKCad and use it regularly. I agree it would be nice to have them integrated and will speak with Marcus to that end. The main issue is that without some help directly from Onshape, libraries will always get out of hand. I can't even search for MKCad now without copies coming up higher in the list than the original files. I don't know how we can create a set of 'Official' CAD files for FRC parts since there will always be people who want the information/data in slightly different formats.
I have no intention of duplicating what MKCad has in place for all the one-off parts that our vendors sell, but it is nice to use configurations for families of parts.
Unread 07-21-2018, 12:18 PM
cadandcookies's Avatar
cadandcookies cadandcookies is offline
AKA: Nick Aarestad
FRC #2220 (Blue Twilight) & FTC 9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Thanks for making this! I've been poking around a bit and really love the configurable part workflow with gears and such!
As for managing external libraries, what I've done is create labels for MKCAD and your library, so that instead of searching for them all the time, I have a "shortcut" under other documents that always takes me to the right libraries. It took all of a minute to set up and saves me the hassle of searching for them all the time, which is a real pain. I wish I could do this on the "Team" level so that all our members could automatically have them, but alas, that doesn't seem possible. Still way easier than managing a GrabCAD Common Parts library though.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
grabcad | twitter | github
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16) -> FRC 2220 (18-??)
VEXU UMN (2015-17)
Volunteer since 2011
Unread 07-21-2018, 01:06 PM
marshall's Avatar
marshall marshall is online now
Discerning and exacting individual
FRC #0900 (The Zebracorns)
https://forum.onshape.com/categories/product-feedback
Clarke's Laws
Unread 07-23-2018, 11:50 AM
marcusbernstein's Avatar
marcusbernstein marcusbernstein is offline
I should be at baseball practice
FRC #1836 (The Milkenknights)
Team Role: Mascot
marcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond repute
Ricky,
I'm so happy to see this idea coming to life and am looking forward to testing it when I get back to real life!
Shoot me an email and we can work on integrating these projects as well as some more Onshape tools for this summer/fall!!
"Once you've concluded that it isn't a code problem, it isn't an electrical problem, and it isn't a mechanical problem, after all that blaming you now have a culture problem."
"Precedence is no excuse for being wrong."
"Aesthetics are great, but not at the expense of functionality."
"An entire team rallied around a potentially wrong decision is better than half a team rallied around the right one. And if that potentially wrong decision ends up being the right one, that unified team will be successful."
Unread Yesterday, 08:17 PM
tdogb tdogb is offline
FRC #6502
tdogb is an unknown quantity at this point
Darnit, just added configurable Versaframe to MKCad . Here is the link for anyone that is interested. What you guys have done is great, I will definitely be using this!!
https://cad.onshape.com/documents/51...d4a9f0c2f93783
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
