OCCRA
Go to Post It's sooo stressful! I brought my suitcase to school today, and I still don't know if we're going! - elfenari [more]
CD-Media
Unread 12-04-2018, 07:37 AM
RSimpson's Avatar
RSimpson RSimpson is offline
AKA: Reis Simpson
FRC #7457 (SuPURDUEper Robotics)
Rookie Year: 2015
RSimpson is an unknown quantity at this point
pic: How small can it get?
Unread 12-04-2018, 07:39 AM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
Re: pic: How small can it get?
At first glance, I saw only one wheel and thought "boy that's a new one for the list of "interesting drive trains"." I now see the others.
Unread 12-04-2018, 07:40 AM
carpedav000's Avatar
carpedav000 carpedav000 is offline
FF: TSIMFD
AKA: David Carpenter
no team (Lincoln Tech)
carpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond repute
Hot dang, Reis! This 100% qualifies as tote bot material. Also how fast does it go?
It isn't shiny enough.
Unread 12-04-2018, 09:43 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
methinks the H drive takes up room that should be housing the electronics/battery...because if you don't put the electronics/battery as low as possible, it won't stay upright very long!
How about the compete design, what does it look like? and how would it have done in Overdrive?
Unread 12-04-2018, 10:24 AM
Type's Avatar
Type Type is offline
AKA: AJ
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud ofType has much to be proud of
You could get even smaller if you staggered the gearboxes. If the left side was in the front and the right was in the rear, you could make it even narrower. You would have to eliminate the H drive though.
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
Unread 12-04-2018, 10:39 AM
RSimpson's Avatar
AKA: Reis Simpson
Rookie Year: 2015
I like that idea, how small do you think we can get it??
Unread 12-04-2018, 11:03 AM
RSimpson's Avatar
AKA: Reis Simpson
Rookie Year: 2015
16.9 fps free speed and 13.69 fps adjusted
Unread 12-04-2018, 11:11 AM
GeeTwo GeeTwo is offline
Somebody Else
AKA: Gus Michel II
Looks familiar:
My 2-CIM version
As noted above, getting the battery down is a big deal with this small a drive base. If you want to put it inside, you're looking at 7" + 2 side modules. If you go down to 9mm belt and low profile shaft heads, you should be able to get to 12" wide.
If you aren't worried about the battery being on top, you may want to look at putting the slide wheel's motor inside, using a VP or CIM Sport or TB micro gearbox*.
Also, you can take an inch off the length at the motors end if you notch the top of the end sheet to allow clearance for the motor. If you look carefully, you can see this in the underside view from my version. I expect you can get to 14.8", possibly 14.3" with a low CoG battery- any shorter, you won't be able to get the battery in or out.
* [Edit] If you really want to get short with a planetary, figure out how to mount the wheel to the planetary housing (ring gear) and lock the normal output shaft (planetary carrier) down.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Unread 12-04-2018, 11:41 AM
Lil' Lavery Lil' Lavery is online now
Hungry Dawgs Run Faster
AKA: Sean Lavery
FRC #1712 (DAWGMA)
They can get it narrower while keeping the H-drive by only having one motor (staggered) in each gearbox. This thing is going to weight less than 40 lbs anyway, having 4 NEOs motors in the primary drivetrain is overkill to begin with. One per side, offset so the gearboxes can be wedged even closer together.
Unread 12-05-2018, 07:18 PM
Attention Attention is offline
Professional Something
AKA: Chun-che
FRC #4388 (Ridgebotics)
Rookie Year: 2015
Attention will become famous soon enough
What if you did this?
But with NEO.
https://goo.gl/images/ZGD6gM
2015 - 2018 | FRC 4388 STUDENT
2018 - ? | FRC 4388/4499 MENTOR
2018 - ? | SLFF 1.21 GIGAWATT
Unread 12-05-2018, 07:27 PM
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond repute
But with NEO.
Leave room to fit this electronics module from 2342 in the middle, and you can keep it FRC legal
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
