OCCRA
Go to Post *wonders if omni wheel rollers come in MOE green or have to be dyed* - EricH [more]
  #46   Spotlight this post!
Unread 03-06-2017, 12:28 PM
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: Fuel is for The Few (Not You)
Originally Posted by wesleyac View Post
Do you have data on how much force the hopper actually takes to open? Did you actually measure that it took more than 25 lbs, or is that your guess based on feeling it? If that is based on feel, what would you estimate the actual activation force is?
There are so many unknowns about the field this year, so I'd love to get a data point for a real hopper's activation force.
Nope; no data, unfortunately. At Week Zero (the Week 0 with the official field in NH) we attempted a 40kpa auto which relies on triggering the hopper by strafing into it sideways and hitting it with our bumper (our bumper's roughly within 0.5" of the floor). It never triggered the hopper in auto, and I think the only way we could trigger it in teleop was driving into it with a bit of a "running start." Since we didn't want to rely on a significant amount of momentum to get the hoppers to deploy consistently, we tried adding something that would extend beyond the frame perimeter by a few inches so we could press on the hopper higher up (>12" above the floor). At Week 0 we bolted a 2x4 to the outside of the robot (outside the frame perimeter), which worked very nicely.
Since Week 0, we've been making a mechanism that starts within the frame perimeter and then extends outward to ensure reliable hopper actuation... but our only experience was ~4-6 matches at the first field that FIRST ever assembled for an event (Week Zero).
I didn't attend Week 0, but I'd guess that with the top edge of our bumper roughly 5" above the floor, it was taking >60 pounds of force to trigger THAT HOPPER, and I wouldn't be surprised if it was over 100. Maybe this was at the high end of what the hoppers will be, but we didn't want to leave that up to chance.
Originally Posted by SamcFuchs View Post
At one point our robot sideswiped one and it barely moved, so I would tend to corroborate his suspicion.
I'd be very interested to hear what 33, 118, 2481, or the others who were autonomously triggering the hoppers in Week 1 found. It seemed from the webcast that all of them required some adjustments to get their 40kpa autos working (with various accuracy) on the real field.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
  #47   Spotlight this post!
Unread 03-06-2017, 12:38 PM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Off course a lot depends on where your bumper actually contact the bar.. 6" is on the high side. You are making a moment arm with the pivot just above floor level. Depending on tolerances and such you are actually lifting the hopper bottom a little before it drops. Lots of moving parts. I agree that this should be well stated in the manual. Whether or not the variance should be part of the challenge is a separate debate.
If you don't know what you should hook up then you should read a data sheet
  #48   Spotlight this post!
Unread 03-06-2017, 12:48 PM
BJC's Avatar
BJC BJC is offline
Bee in California
AKA: Bryan Culver
We had 99 problems but triggering the hopper wasn't one. Touching the triggers with minimal force would drop the fuel.
Cheers, Bryan
frc33 2009-2017, frc148 2018
  #49   Spotlight this post!
Unread 03-06-2017, 12:56 PM
marshall's Avatar
marshall marshall is offline
Online Stripe & Drape Sales
FRC #0900 (The Zebracorns)
Cheers, Bryan
Our biggest issue with the hoppers and triggering them was down to 3 things:
-The hopper bins would dump about 5 inches lower than indicated by the field drawings (Queue Sean Lavey and others explaining that the field can be +/- 5 inches because the manual says so...). This was actually solved by a volunteer using string at the right height.
-The hoppers were not fastened to the floor or field perimeter in any method. They were literally just hanging around and could be easy moved by a person or a robot. This lead to issue #3.
-The hoppers, on multiple occasions, FELL INTO THE FIELD and onto our robot, breaking it. This seems like a fairly major oversight and not something all that hard to solve.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Clarke's Laws
  #50   Spotlight this post!
Unread 03-06-2017, 01:43 PM
Ginger Power's Avatar
Ginger Power Ginger Power is offline
Founder of COR Robotics
AKA: Ryan Swanson
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
During the field setup for Northern Lights and Lake Superior I questioned why there wasn't velcro on the bottom of the Hoppers. I couldn't get an answer other than "It's not on the field drawings". This is a 20 minute fix that can easily be applied during the initial field build. Hopefully FIRST comes out with updated field drawings that include velcro on the bottom of the Hoppers.
  #51   Spotlight this post!
Unread 03-06-2017, 01:46 PM
marshall's Avatar
"It's not on the field drawings" is actually trademarked by FIRST like gracious professionalism.
Clarke's Laws
  #52   Spotlight this post!
Unread 03-06-2017, 01:48 PM
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
And here's a fun fact: even if you do manage to trigger the hopper, it may jam and not empty all the balls into your bot.
Todd F.
Photo gallery
video channel
Triple Helix mobile
  #53   Spotlight this post!
Unread 03-06-2017, 01:51 PM
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Lizard King
AKA: "very active discussion within our community"
FRC #0422 (The Mech Tech Dragons)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Not A Field Fault™
We hope this is fixed in the future :/
  #54   Spotlight this post!
Unread 03-06-2017, 01:57 PM
Hallry's Avatar
Hallry Hallry is offline
2017 World Champions
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Originally Posted by PayneTrain View Post
Not A Field Fault™
Funny enough, it's also apparently not a field fault when 5 of the 6 robots on the field lose comm simultaneously for a few seconds, or are randomly switched back into autonomous during teleop.
[2009-2013]: Team 1676 - Student, Co-CEO, Carpentry Lead
[2013-2017]: Team 1676 - Alumni Mentor
[2017-Present]: Team 1676 - Mentor
Won: 2010 New Jersey Regional, 2010 Virginia Regional (undefeated), 2011 New Jersey Regional, 2011 Virginia Regional, 2011 Brunswick Eruption, 2012 Rutgers MAR District, 2012 girlPOWER, 2012 Ramp Riot, 2013 Bridgewater-Raritan MAR District, 2014 girlPOWER, 2015 Bridgewater-Raritan MAR District, 2016 Mt. Olive MAR District, 2016 Bridgewater-Raritan MAR District, 2017 Daly Subdivision, 2017 St. Louis World Championship, 2017 MidKnight Mayhem, 2017 Festival of Champions
2017 Season Recap Video
Festival of Champions Recap Video
  #55   Spotlight this post!
Unread 03-06-2017, 02:03 PM
marshall's Avatar
Not A Field Fault™
Team Update 53: Minor Field Fixes
Clarke's Laws
  #56   Spotlight this post!
Unread 03-06-2017, 02:05 PM
Hallry's Avatar
AKA: Ryan Hall
Team Update 53: Minor Major Field Fixes
FTFY.
  #57   Spotlight this post!
Unread 03-06-2017, 02:12 PM
marshall's Avatar
Originally Posted by Hallry View Post
FTFY.
This guy fields?
Clarke's Laws
  #58   Spotlight this post!
Unread 03-06-2017, 02:16 PM
AKA: Ryan Swanson
It's also apparently not a field fault when the field sound, audience display, and field lights don't work... but that could never affect the outcome of a ma... oh wait. But it could never affect the outcome of an event... oh wait. I'm not salty about Finals 3 on Lake Superior at all...
  #59   Spotlight this post!
Unread 03-06-2017, 02:17 PM
Hallry's Avatar
AKA: Ryan Hall
This guy fields?
HQ watching the Week 1 streams this weekend.
^Language warning.
  #60   Spotlight this post!
Unread 03-06-2017, 02:18 PM
PayneTrain's Avatar
Lizard King
Team Role: Mascot
This guy fields?
Fix That Field, Y?
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
