OCCRA
Go to Post I'm sure an inflatable Dean Kamen action figure would be quite the sight around the home. lol - Elgin Clock [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
CD-Media
  #16   Spotlight this post!
Unread 02-16-2017, 01:57 AM
jlindquist74's Avatar
jlindquist74 jlindquist74 is offline
WOPR Software Integration Lead
FRC #1622 (Team Spyder)
Team Role: Coach
Rookie Year: 1337
jlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond repute
Re: Best CAN Connector Interface
The Molex connectors Jim listed look fantastic. I stayed closer to the 0.1"-spaced Molex connectors used for PWM. Amphenol makes a locking variant of those: A34186-ND and A34216-ND
Those connectors are designed for IDC (insulation displacement)... you're supposed to press the unstripped wire onto the connector, and sharp edges will penetrate the insulation and make contact. I found this unreliable, particularly with the yellow wire used on the Talons. It also make it very hard to slide the contact inside the housing. I had MUCH better luck soldering them instead.
Pick up some 120-ohm resistors and you can make terminators, too. Then your layout won't require you to make the PDP the last device in your chain.
Strange thing about those connectors and DigiKey, they're like hot dogs. You can only order one type in multiples of 8, the other in multiples of 10.
Last edited by jlindquist74 : 02-16-2017 at 02:00 AM. Reason: John Whorfin ordered me to
  #17   Spotlight this post!
Unread 02-16-2017, 09:09 AM
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
Rookie Year: 2012
dvanvoorst is an unknown quantity at this point
This is a more compact version of the lever nut from Wago that works really nice. am-2575a
  #18   Spotlight this post!
Unread 03-17-2017, 08:06 AM
caltemus's Avatar
caltemus caltemus is offline
Clean Wiring Fanatic
AKA: Charlie
FRC #3461 (Operation PEACCE)
Rookie Year: 2010
caltemus is a glorious beacon of lightcaltemus is a glorious beacon of lightcaltemus is a glorious beacon of lightcaltemus is a glorious beacon of lightcaltemus is a glorious beacon of light
We used those exclusively for our CAN network this year and they've worked well. Their ease of use beats other methods in my book; no crimps to over torque, no solder joints to booger. We have the larger predecessor model that was previously mentioned, and they did prove to be a bit bulky for this application.
Team 3461-Mentor, electrical and manufacturing, 2017-present
[2017 Season] -Hartford District Event Finalist
Event Volunteer, 2012-Present: Queueing, Field Reset, Robot Inspector, Glasses Yeller, Dunkin Runner
Team 195-Student, electrical and pit lead, 2010-2012
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
