Go to Post It is possible to live without the Big sponsors, it just takes a lot of fund raising and hard work. - Raumiester2010 [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 02-13-2017, 09:51 AM
COLA COLA is offline
AKA: DrDoug
FRC #3367 (Ogichidaa Robotics)
Rookie Year: 2016
COLA is an unknown quantity at this point
Team3367 old power distribution panel
Upon wiring up our robot, we discovered that our power distribution panel has no connection ports for the CAN (green and yellow) wires. We are not using pneumatics.
Can we still wire the CAN to another port on the older-style power distribution panel? Thanks in advance.
miigwech
#3367 Ogichidaa Robotics
Unread 02-13-2017, 09:57 AM
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Team3367 old power distribution panel
No, the old PDB (the blue one) is NOT legal for this year's robot. You need the newer one.
R44. The one (1) ROBOT battery, a single pair of Anderson Power Products (or APP) 2-pole SB type connectors, the one (1) main 120-amp (120A) circuit breaker (Cooper Bussman P/N: CB185-120), and the one (1) CTR Electronics Power Distribution Panel (PDP, P/N: am-2856, 217-4244, 14-806880) shall be connected with 6 AWG (7 SWG or 16 mm2
) wire or larger, with no additional devices or modifications, as shown in Figure 8-8
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016-2018; Iowa 2017; Northern Lights 2018; Great Northern 2018
Division LRI: Galileo 2016; Tesla 2017; Archimedes 2018
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 02-13-2017, 09:59 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Mentor
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
The old PDB does not have any CAN capability. If you just have PWM, you can build a test version of your robot, but it is not competition legal.
(Emphasis mine)
Originally Posted by R44
The one (1) ROBOT battery, a single pair of Anderson Power Products (or APP) 2-pole SB type connectors, the one (1) main 120-amp (120A) circuit breaker (Cooper Bussman P/N: CB185-120), and the one (1) CTR Electronics Power Distribution Panel (PDP, P/N: am-2856, 217-4244) shall be connected with 6 AWG (7 SWG or 16 mm2) wire or larger, with no additional devices or modifications, as shown in Figure 8-8.
Unread 02-13-2017, 10:03 AM
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The old blue PDP can only be used on practice or old robots.
It can be used with the roboRIO control system, just not in competition anymore.
Just leave the blue PDP out of any CAN chains, e.g., CAN from the roboRIO to PCMs or Talon SRX's. A 120 Ohm resister at the end of the CAN wiring is recommended.
For an old or practice robot the CAN to PDP is not required for anything.
2018 Beta Testing Results
Unread 02-13-2017, 10:22 AM
GreyingJay GreyingJay is offline
we'll fix it in the pit
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
On a related note, what do teams do with old RoboRio-based robots that they want to keep going for demo purposes?
Our team is too young to have owned any cRio based control systems to transplant.
We could swap out the RoboRio with some other CPU board (various options have been discussed on the forums) but that's only one piece of the control system. What about the PDP? Do you replace that with an alternate, hopefully inexpensive, breaker panel? What do you do with the PCM and VRM?
How do other teams do it?
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 02-13-2017, 10:55 AM
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
most teams get a second or third (or fourth!) control system. even if you have cRio based hardware, most teams no longer have anyone that remembers how to use it, and it's annoying to keep the older software around.
Our team has 4 roboRios at this point i think. one for the competition bot, one for the practice bot, one on the T-shirt cannon (I think, though that could be a cRio), and one for the demo robot from previous years.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes | 2017 SE Mass #7, QF, Inspector - Reading #4, Winners (1071, 5556), EI, Inspector - NECMP #TBD
Unread 02-13-2017, 01:42 PM
AKA: DrDoug
Rookie Year: 2016
Many thanks. We will use a 120 ohm resistor while we wait for the AndyMark order to arrive.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
