OCCRA
Go to Post ah, common sense, not as common as one might think... - [more]
CD-Media
Unread 06-26-2018, 06:56 PM
FalconWarriorrr's Avatar
FalconWarriorrr FalconWarriorrr is offline
FRC #0900
FalconWarriorrr has a reputation beyond reputeFalconWarriorrr has a reputation beyond reputeFalconWarriorrr has a reputation beyond reputeFalconWarriorrr has a reputation beyond reputeFalconWarriorrr has a reputation beyond reputeFalconWarriorrr has a reputation beyond reputeFalconWarriorrr has a reputation beyond reputeFalconWarriorrr has a reputation beyond reputeFalconWarriorrr has a reputation beyond reputeFalconWarriorrr has a reputation beyond reputeFalconWarriorrr has a reputation beyond repute
paper: ZebROS 1.0: ROS for FRC
Thread created automatically to discuss a document in CD-Media.
ZebROS 1.0: ROS for FRC by FalconWarriorrr
Unread 06-26-2018, 06:57 PM
FRC #0900
Re: paper: ZebROS 1.0: ROS for FRC
In 2016, Team 900 wrote a neural network for detecting boulders. Last year, we implemented the Robot Operating System, ROS, into our vision code to facilitate communication between multiple processors. But this year, weve gone above and beyond what anyone thought we would be crazy enough to attempt. We transitioned our entire robot code -- including hardware control -- into ROS.
It wasnt an easy transition -- not only did we have to rewrite all of our code from the very basics of controlling motors to starting robot code automatically, but our problems were completely unique to FRC. Since were blazing a trail where no one one else has dared to go, we had to figure out most of our problems on our own without any specific resources. In this white paper, we explain why we did it, how we did it, and what we plan to do in the future. We hope to be a resource for any other teams crazy enough to try this out.
Theres no doubt that its been a difficult year, but many exciting things happened as well. We played back driver station data in real time to debug our different autonomous modes. We made huge strides with localization and mapping. We began integrating vision code with generated motion profiled paths. Were looking forward to next year where we will do even more exciting things. Stay tuned!
Thank you to the entire team that worked tirelessly on the ROS transition and to our programming mentors Eric Blau and Kevin Jaget for their help throughout the competition season to surmount such a significant codebase transformation. Thank you to our mentors and fellow students for their help reviewing this paper. Finally, thank you to our sponsors for providing us with the resources that allowed us to make these groundbreaking leaps. We couldn't do any of this without your continued support!
Unread 06-26-2018, 06:58 PM
marshall's Avatar
marshall marshall is offline
"Who's Marshall?"
FRC #0900 (The Zebracorns)
WOOOOO! Very proud of all of you.
Clarke's Laws
Unread 06-26-2018, 07:22 PM
KJaget's Avatar
KJaget KJaget is offline
Zebravision Labs
AKA: Kevin
FRC #0900
Rookie Year: 2015
KJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond repute
There has been some discussion around the cost-benefit tradeoffs of using ROS for FRC. Living with it for the past year has given me some insight into the benefits. Note that none will be "free code for SLAM/autonomous path planning".
1. Breaking code into individual nodes is a big plus. Being able to drive each node individually from the command line is terrific for testing. This can be used for unit tests as well as for injecting commands to any point in a fully connected compute node. Plus it makes it way easier to have multiple coders collaborating without breaking stuff (but this might also be partly due to switching to Perl, uh, I mean C++).
2. There's existing code for how to do anything. That doesn't mean that we're just slapping other people's code together, but if we need a way to communicate something, someone's already figured out and implemented the right way to do it (or at least a good one).
3. Pre-written command line tools to record, analyze and play back the entire state of a robot from a match has the potential to be huge. We're still looking at the full benefits of this but it is great so far.
4. This is kinda a sub bullet of 1, or forced by it : since code is broken into nodes, we only have to replace the hardware interface node with a simple simulator and can test the rest of stack as-is. It is so nice to be able to bring up robot code on a laptop and test 90%+ of everything without touching a robot.
5. Moving code between processors is changing a config file and it just works. Communication between CPUs, coprocessors and so on is a solved problem.
Granted, a motivated team could code any of this. But getting it for free after (an admittedly impressive) investment in adapting to ROS is a nice benefit.
Most of this should be in more detail in the paper - read it already
Unread 06-26-2018, 07:33 PM
Adithya Balaji's Avatar
Adithya Balaji Adithya Balaji is offline
catkin_maker (wiki.ros.org)
Adithya Balaji has a reputation beyond reputeAdithya Balaji has a reputation beyond reputeAdithya Balaji has a reputation beyond reputeAdithya Balaji has a reputation beyond reputeAdithya Balaji has a reputation beyond reputeAdithya Balaji has a reputation beyond reputeAdithya Balaji has a reputation beyond reputeAdithya Balaji has a reputation beyond reputeAdithya Balaji has a reputation beyond reputeAdithya Balaji has a reputation beyond reputeAdithya Balaji has a reputation beyond repute
Great work guys! This is one impressive paper. I'm excited to see what you all do next season.
2018 - FIRST NC Volunteer
2017 - 900 - Newton Quarterfinalist, District Championship Winner, Excellence in Engineering (NC District Championship)
2016 - 900 - Excellence in Engineering (NC District Championship)
2015 - 4828 - Spirit Award (NC Regional)
2014 - 4828 - 8th Alliance Captain (NC Regional)
Unread 06-26-2018, 07:34 PM
marshall's Avatar
"Who's Marshall?"
Speak of the devil - your name is in the paper. Along with some others...
Clarke's Laws
Unread 06-26-2018, 07:38 PM
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Regarding the starting scripts, was the robotCommand script just not running? I'd be interested in helping to figure that issue out, as it might help make the WPILib startup simpler as well.
Team 4488 - Mentor 2013-2016
Unread 06-26-2018, 08:10 PM
amstrudy amstrudy is offline
AKA: Anja Sheppard
FRC #0900 (Zebracorns)
amstrudy has a brilliant futureamstrudy has a brilliant futureamstrudy has a brilliant futureamstrudy has a brilliant futureamstrudy has a brilliant futureamstrudy has a brilliant futureamstrudy has a brilliant futureamstrudy has a brilliant futureamstrudy has a brilliant futureamstrudy has a brilliant futureamstrudy has a brilliant future
Man I would love to figure this out too. I spent a week on this exact issue. Maybe it was just an issue with the way we hacked up our roboRIO because someone I was working with got it to work on their end, but no matter where I tried sticking the startup script it never got run.
Unread 06-26-2018, 11:40 PM
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #6367 (), FRC #7240 ()
virtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond reputevirtuald has a reputation beyond repute
You have to execute this at least once to get it to run the robot command. RobotPy executes that anytime we deploy a new version of the code.
/usr/local/frc/bin/frcKillRobot.sh -t -r
Maintainer of RobotPy (Python for FRC) & WPILib Contributor
Creator of pyfrc (Robot Simulator + utilities for Python), pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript), and lots more...
Unread 06-27-2018, 08:46 AM
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is a glorious beacon of lightamesmich is a glorious beacon of lightamesmich is a glorious beacon of lightamesmich is a glorious beacon of lightamesmich is a glorious beacon of lightamesmich is a glorious beacon of light
Our team got ROS up and running this past year and then for various reasons scraped it. One of the main reasons is the closed loop feedback and processing that the talons provide. We could not leverage that as intended. So until another day. Thanks for the update. You work is interesting and helpful.
Unread 06-27-2018, 09:04 AM
marshall's Avatar
"Who's Marshall?"
I will let the students respond to this but from an old-linux-dude standpoint, what I'd REALLY like to see is a simplified startup process that is basically a "FRC Teams using non-traditional stuff please put your startup scripts here"-Folder. Where each script is a name like 0-startMeFirst.sh, 1-startMeSecond.sh, 2-startMeThird.sh. And then those are all executed in the appropriate order with each returning a success/failure. This is similar to how init worked and granted, systemd has replaced it so maybe systemd is an option. Basically, I'd like the roboRIO to behave more like the linux system that it is(n't).
I remember you contacting us a couple times early this season and getting an email forwarded from Omar I think. As I recall, you were using the ROS for LabVIEW implementation from Tufts. We have moved 100% away from LabVIEW at this point as we also found it a hindrance to making ROS behave like ROS. Hopefully our paper helps you out with getting it working down the road.
Clarke's Laws
Unread 06-27-2018, 10:17 AM
virtuald's Avatar
RobotPy Guy
There is a traditional init.d/rc.d folder on the RIO, and it works exactly as you would expect. I was actually quite surprised you tried to use robotCommand instead of this.
Unread 06-27-2018, 10:24 AM
marshall's Avatar
"Who's Marshall?"
LOL - as if I have anything to do with coding the robot.
Build season is a crazy time and the obvious solutions sometimes escape us. Probably worth digging into this.
Though, honestly, what we ended up with worked well for us.
Clarke's Laws
Unread 06-30-2018, 01:25 AM
JamieSinn's Avatar
JamieSinn JamieSinn is offline
Control Systems Mentor
FRC #1334 (Red Devils), FRC #1374 (Amped Up)
JamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond reputeJamieSinn has a reputation beyond repute
Year after year, 900 astounds me with the abilities of FIRST students and robots in FRC.
Congratulations, and I can't wait to try out some ROS in the offseason!
1334/1374 Control Systems Mentor
Unread 07-14-2018, 07:43 PM
agamemnon agamemnon is offline
FRC #0088
agamemnon is a glorious beacon of lightagamemnon is a glorious beacon of lightagamemnon is a glorious beacon of lightagamemnon is a glorious beacon of lightagamemnon is a glorious beacon of light
That was a really interesting read, very impressive work. I'm probably going to try this out myself. I've thought about using ROS on an FRC robot but never got around to trying.
However, the way I was thinking about it was running the roscore and most nodes offboard the RoboRIO and just using a ROS java library or roscpp on the RIO itself to do hardware/field interfacing (controlling talons, interacting with DS and FMS, etc). Is that an approach you considered? I'm curious to hear from people that have spent a lot more time thinking about this than me..
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
