Go to Post Maybe between Art, skimoose, and some of the other intelligent folks on CD (most of us), we can force a redesign of the game.... - EricH [more]
Unread 05-10-2018, 06:00 PM
FredK FredK is offline
FRC #3676
FredK is an unknown quantity at this point
T shirt Cannon barrel material and adaptor
Everything figured out except the barrel and adapter for the cannon. Been searching for something that doesn't require extensive metalworking or cost over $100. Any suggestions appreciated. Have found galvanized 3" pipe with a 3"/1" reducer but it is expensive. Cannot find a reducer for a 3" copper pipe. Not using PVC.
Thank you
Unread 05-10-2018, 06:33 PM
ClayTownR's Avatar
ClayTownR ClayTownR is offline
AKA: Clayton
FRC #0100 (The WildHats)
Team Role: CAD
Rookie Year: 2015
ClayTownR is a name known to allClayTownR is a name known to allClayTownR is a name known to allClayTownR is a name known to allClayTownR is a name known to allClayTownR is a name known to all
Re: T shirt Cannon barrel material and adaptor
I'm not quite sure what you're after. CAD or screenshots (even better, touched up with MS paint diagrams of what you need) would be really helpful.
FTC 4800, 2015-
FRC 100, 2016-
messer5740's Avatar
messer5740 messer5740 is offline
AKA: Matt
FRC #5740 (Trojanators)
Team Role: Leadership
Rookie Year: 2015
messer5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to beholdmesser5740 is a splendid one to behold
Might be a weird suggestion, but box tube might work well actually. Itís easy to find at your local metal distributor, comes in really long lengths, and is generally under $100 depending on your size. Attach your box tube to maybe a wooden/ metal base so your launching mechanism can interface with the barrel.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: Quarterfinalists at Greater Pittsburgh Regional and Buckeye Regional
2017: Dean's List Finalist
2018: Engineering Inspiration Award; Quarterfinalists at the Miami Valley and Greater Pittsburgh Regional
Unread 05-10-2018, 06:39 PM
FRC #3676
Looking for something to make a 3" diameter t shirt cannon barrel and a way to attach it to a 1" pipe at the end of a pressurized air system (a solenoid, accumulator tank, pressure guage and storage tank.)
Unread 05-10-2018, 06:46 PM
ClayTownR's Avatar
AKA: Clayton
Team Role: CAD
Rookie Year: 2015
I'm guessing that 3" is the ID you're after, not the OD. If you can weld, that's an easy way to make braces for actually mounting/aiming the thing. Alternatively, you can use pipe clamps to the same effect.
When it comes to the barrel itself, if you have a lathe it'll be dead easy - the barrel can be a pipe where you've cut a thread onto the end, and the join can be another lathe part with threads on either side. If that's beyond reasonable for you, you can just use a press-fit or tight fit with a connector piece made out of some solid round stock on the drill press, then add loctite.
FTC 4800, 2015-
FRC 100, 2016-
Unread 05-11-2018, 07:00 AM
Tom469's Avatar
Tom469 Tom469 is offline
AKA: Tom Riggs
FRC #5402 (Iron Kings)
Rookie Year: 2015
Tom469 is an unknown quantity at this point
You might look at automotive exhaust pipe, Muffler shop, parts store, etc. Also most cities will have a scrap metal dealer that buys, and, sells odd lots of metal.
Unread 05-14-2018, 05:59 PM
21brownz's Avatar
21brownz 21brownz is offline
I Make Things Go Woosh
AKA: Zach Brown
FRC #6502 (DARC SIDE)
Team Role: Electrical
Rookie Year: 2018
21brownz is a glorious beacon of light21brownz is a glorious beacon of light21brownz is a glorious beacon of light21brownz is a glorious beacon of light21brownz is a glorious beacon of light
Thank you
Try some Acrylic, I've had good results with it and its very strong. they don't use it for fish tanks for nothin'.
Is this loss?
"Ah, the old LRI-a-roo" -marshall
Unread 05-14-2018, 06:33 PM
mman1506 mman1506 is online now
Reversible bumpers are my trigger
AKA: Marcus Quintilian
FRC #5406 (Celt-X)
Team Role: Mechanical
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
They also use glass for fish tanks. I wonder why people don't use it to make robots...
Poly-carbonate tubes aren't a bad option. They also have a nice look to them.
2012-2015: 865 Warp7 Team Captain
2016/17: Free Agent Mentor
2018: 5406 Celt-X
Unread 05-14-2018, 06:58 PM
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan Rickards
no team (1592 Bionic Tigers / 2338 Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
https://www.mcmaster.com/#pipe-thread-adapters/=1cue50y
Similar to: McMaster Part - 44705K446
We used these or very similar on ours. To connect to the aluminum tube barrel we used a sch 80 fitting from HomeDepot that had a smooth bore and fit the barrel well and female pipe threads. Then we put a bolt through to all the way through the barrel. Then the metal reducers threaded to it.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-2017
Winner - Wisconsin Regional 2013
Finalist - Midwest Regional 2014, 2015, 2016
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2015, 2016, 2017
Unread 05-21-2018, 10:34 PM
coderkevin coderkevin is offline
AKA: Kevin Killingsworth
FRC #2357 (System Meltdown)
Rookie Year: 2012
coderkevin is an unknown quantity at this point
We're also starting on a project like this in our offseason. So far, the best material I've seen is DuraPlus ABS:
http://www.ipexna.com/usa/products/i...ndustrial-abs/
It's designed for air pressure up to 150 PSI or even 230 PSI depending on the type you get. I spoke to one of their engineers today about this application and he said the industrial version is just fine for this since it's low PSI and the air we use won't have oil or water in it. He also said that this ABS is so ductile that even if it fails, it peels in ribbons like copper does.
I originally found this product through looking at some OSHA notices condemning the usage of PVC for compressed air. Even OSHA recommends this stuff. It's what we'll be using, for sure.
https://www.osha.gov/dts/hib/hib_data/hib19880520.html
You'll probably need to call them to find a local distributor to get it. I'm guessing it will take a while to get into our hands, so I'll be ordering as soon as we know what we need.
Good luck!
Unread 05-22-2018, 09:33 AM
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
No, no, just no.
DO NOT USE PLASTICS FOR PNEUMATICS. The failure modes are catastrophic.
Fish tanks are by nature hydraulic and as such liquid which means it is incompressible.
Please people, think safety first and foremost.
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 05-22-2018, 10:00 AM
Kyle Warren's Avatar
Kyle Warren Kyle Warren is offline
FRC #2052 (knightkrawler)
Rookie Year: 2017
Kyle Warren will become famous soon enoughKyle Warren will become famous soon enough
Why donít you want to use pcv? Our t-shirt cannon barrel is made of pvc.
"I build things"
2018:
lake superior Finalists, Medtronic Foundation Regional Winners, Curie Sub Division Semi Finalists
2017:
Lake Superior Regional Winners, 10,000 Lakes Regional Quarter Finalists
Carson Sub Division Semi Finalists MN State Championship Quarter Finalists
Unread 05-22-2018, 10:53 AM
Rookie Year: 2012
Take a look at this OSHA bulletin. PVC is hazardous and has a great potential for injury: https://www.osha.gov/dts/hib/hib_data/hib19880520.html
Unread 05-22-2018, 10:55 AM
Rookie Year: 2012
I agree with this in general, with the above IPEX Duraplus ABS as an exception because it's rated for air pressure, and even recommended by OSHA.
  #15   Spotlight this post!
Unread 05-22-2018, 11:11 AM
21brownz's Avatar
AKA: Zach Brown
Rookie Year: 2018
https://www.engineeringtoolbox.com/p...res-d_796.html this is a good source for pressures
Is this loss?
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
