OCCRA
Go to Post Ship day is a sweet and sour day. You're happy to see your robot ship, but then you start going through robot withdrawl - Schneidie [more]
Unread 05-14-2018, 05:57 PM
Nicholas Liu Nicholas Liu is offline
Rookie Year: 2015
Nicholas Liu will become famous soon enough
Robot Base for Post-FRC Development
Hey CD,
I'm looking for a robot chassis to continue development in areas like pure pursuit and potentially working with a 360 degree lidar and a stereo camera. Something reliable that has wheels and encoders will work; however, it would be ideal if it had an IMU and expandability to add other sensors later. I have a Jetson I'll use as the processor.
I'm looking for a kit that emulates the MIT RACECAR or Turtlebot but at a reasonable price (<$200). Does anyone have any recommendations or previous experiences?
Unread 05-14-2018, 06:01 PM
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Robot Base for Post-FRC Development
You can get a traxxas rustler for $150 and build the rest up yourself.
Please take the GreyT Products survey here!
2x1 and 2x2 1/16" wall tubing for sale!
Need help? Check out 973 Remote Assistance and Mentorship Program.
2017 "World Champions"
2014 Galileo Champions
2011 World Champions
Unread 05-14-2018, 06:20 PM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron) (Also, CD mod.)
I've owned a Rustler and found them to be pretty bombproof. But if OP is mounting a bunch of things to one, I might suggest the Slash for a hair under $200. Both share a reasonable amount of DNA, but the Slash has a bit more real estate on the main chassis plate, and having the wheels and tires tuck into the body more is good for protecting the operating environment. Neither is a wrong answer, though.
The Traxxas Bandit is a Rustler with a few buggy-specific tweaks. Probably won't see it cheaper than a Rustler or Slash since stadium and short-course trucks are more popular racing classes, but it's worth a search.
The Traxxas Stampede is also related to the Rustler, but has a really narrow and high main chassis plate so it can do the monster truck look. Probably the least-suited of anything in this post for what you want, but if you got it for a song it might be useful.
Edit to add: All of these are available in a lot of bundles and variants--some are 4WD instead of 2WD, some are brushless instead of brushed, some have a battery included, some are smaller-scale versions of the same racing class, so on so forth. For your purposes, get the cheapest 1/10 scale version of whatever you settle on unless you are planning to race it somewhere.
Also, none of these come with encoders at the wheels. You'd need your own setup for that, though all also have enough sidewall on the tires that you can probably come up with some marks to get something.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach (oh, and I worked at AndyMark during this time)
2018-: FRC 1293 (Pandamaniacs) - Mentor
113 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
Unread 05-18-2018, 11:16 PM
apache8080 apache8080 is offline
Addicted FRC Alumni
AKA: Rishi Desai
Rookie Year: 2014
apache8080 has a reputation beyond reputeapache8080 has a reputation beyond reputeapache8080 has a reputation beyond reputeapache8080 has a reputation beyond reputeapache8080 has a reputation beyond reputeapache8080 has a reputation beyond reputeapache8080 has a reputation beyond reputeapache8080 has a reputation beyond reputeapache8080 has a reputation beyond reputeapache8080 has a reputation beyond reputeapache8080 has a reputation beyond repute
If you are using a Traxxas RC car with brushless motors you could use a Vedder ESC which has odometry and can be controlled over a USB port. This will allow you to avoid expensive encoders.
Rishi Desai
An FRC alum who misses the competition.
Student:
Team 5677, 2016-2017
Team 3256, 2013-2016
My GitHub
Unread 05-19-2018, 09:33 AM
wgorgen's Avatar
wgorgen wgorgen is offline
FRC #1533 (Triple Strange)
Rookie Year: 2014
wgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to beholdwgorgen is a splendid one to behold
Actobotics sells some fairly cheap base kits:
The scout is $170. It includes motors, but does not include electronics. I believe the motors do not have encoders, but Servocity does sell a version of that same motor with an encoder for about $20 more per motor. I'm sure you could call them and request upgraded motors.
https://www.servocity.com/scout
This base has bolt holes that are compatible with the Actobotics construction system so it would make it very easy to build a superstructure to support the OPs equipment.
Depending on the scope of the project they sell a bunch of interesting simple chassis or some fairly complex chassis with more space for components.
One of our FTC teams switched to the Actobotics building system a couple years ago and have found it to be a really well designed system. They have a bunch of specialty COTS parts to be able to create really unique mechanisms. They have mounting plates that are compatible with standard servos, motors, etc that make it really easy to assemble. The parts are not as cheap as Tetrix, but they fit together a lot more precisely and solidly.
Our club has also built a bunch of very simple holonomic drive robots using some of our older FTC electronics that we don't use any more, 4 motors mounted diagonally on the 4 corners of a square board with direct drive Tetrix omni-wheels. We use these for outreach based on a game we saw at worlds in 2016 that another FTC team, the Lazybots, had developed for outreach. We copied the Lazybotts plans for their robots which are posted on their website:
http://www.lazybotts.com/krazy-kubes.html
Click on the 'more info' link at the bottom of the page to go to their google drive where they have the plans and construction instructions for their robots. Obviously, you could make these as large as you wanted by just making the square plate larger. These robots are way under $200 and provide a very versatile platform if you have a flat, indoor space that you are using for your project.
Unread 05-19-2018, 09:48 AM
mman1506 mman1506 is offline
Reversible bumpers are my trigger
AKA: Marcus Quintilian
FRC #5406 (Celt-X)
Team Role: Mechanical
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
The car included in the MIT racecar kit is a Traxxas Slash 4x4 and the ESC is just a VESC.
2012-2015: 865 Warp7 Team Captain
2016/17: Free Agent Mentor
2018-present: 5406 Celt-X
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
