OCCRA
Go to Post Keep 'em cool, run it fast! - ChrisH [more]
Unread 01-16-2017, 08:17 PM
ollien ollien is offline
FRC #5202
Rookie Year: 2015
ollien is a splendid one to beholdollien is a splendid one to beholdollien is a splendid one to beholdollien is a splendid one to beholdollien is a splendid one to beholdollien is a splendid one to beholdollien is a splendid one to behold
How to bend lexan for a hood?
The title says most of it. We want to bend a piece of lexan to create a hood for a shooter. We don't have access to a brake. How can we curve this piece safely?
Unread 01-16-2017, 08:28 PM
Zack-5421's Avatar
Zack-5421 Zack-5421 is offline
FRC #5421 (Birch Bots)
Rookie Year: 2015
Zack-5421 has a spectacular aura aboutZack-5421 has a spectacular aura about
Re: How to bend lexan for a hood?
Light Heat and patience
Unread 01-16-2017, 08:29 PM
FRC #5202
Rookie Year: 2015
How do I know when to stop heating?
Unread 01-16-2017, 08:32 PM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron) (Also, CD mod.)
Depending on your thickness, you can try a heat gun and a piece of angle metal to use as a straight edge (in both dimensions). I would advise holding the bending part with something other than your fingers, for obvious reasons.
This was the second result for Googling "how to bend lexan": https://www.youtube.com/watch?v=6ik-wqRNFSE
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach (oh, and I worked at AndyMark during this time)
2018-: FRC 1293 (Pandamaniacs) - Mentor
113 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
Unread 01-16-2017, 08:34 PM
RoboChair's Avatar
AKA: Devin Castellucci
If you want a sharp bend, when it easily flexes(I highly recommend a heat strip for this kind of bend). If you want a gradual bend, the only advice I can give is to buy extra polycarb and practice. Maybe some kind of radiant heater. Maybe thermoform/vacuform it.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 01-16-2017, 08:47 PM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
how thick is the material? We usually use polycarbonate that is a tad thinner than 1/8" thick. It will bend (and spring back) easily for things like that. If it's supported with an aluminum frame, then it will mostly hold it's shape.
If something looks kind of difficult to make the way you have planned, maybe you could figure out a different way to build it?
Unread 01-16-2017, 08:59 PM
FRC #5202
Rookie Year: 2015
I'd have to check when I get back to the lab tomorrow, but if memory serves me right, it's 3/16"
Unread 01-16-2017, 09:00 PM
RoboChair's Avatar
Ouch! That thick is hard to bend large pieces via heat properly.
Unread 01-16-2017, 09:14 PM
FRC #5202
Rookie Year: 2015
What thickness would you recommend? 1/8?
Unread 01-16-2017, 09:28 PM
Hitchhiker 42's Avatar
Happy Birthday! Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
no team (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
We had a lot of success with 1/8" last year. A lot of our robot, including the bellypan were polycarb. We mostly just used a vise and heat gun (be careful so it doesn't start bubbling). A continuous curve might be a little trickier than a one-place bend, though.
Don't forget your towel!
Unread 01-16-2017, 09:47 PM
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
We either cut several pieces with that profile and then bolt them together (with our without spacers in between) or create the profile with sheetmetal and spacers then line it with a thin piece of lexan that is zip-tied to the spacers.
Unread 01-16-2017, 09:53 PM
PShaw25 PShaw25 is offline
AKA: Preston Shaw
FRC #1261 (Robo Lions)
PShaw25 is a glorious beacon of lightPShaw25 is a glorious beacon of lightPShaw25 is a glorious beacon of lightPShaw25 is a glorious beacon of lightPShaw25 is a glorious beacon of light
If you're just using it for a shooter I can't imagine you need too large a radius. It should be pretty easy to find something with a similar curve (pvc, lunacy wheels, etc) in your build space that you could mold the lexan around after heating it. This will be a lot easier than using a vise, and provide a clean curve.
Unread 01-16-2017, 09:54 PM
Sarakiro's Avatar
Sarakiro Sarakiro is offline
AKA: Rob
FRC #1676 (Pascack ∏-oneers)
Sarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud of
Depends on thickness- the easiest way to get a gradual curve will be to make three mount points along whatever your chosen radius is by which you can use to attach the 'hood' to. (This works best with material up to about 1/16th of an inch.)
Alternatively, you can use a heat gun and apply heat evenly. you can use a similar form mentioned above, or round it by rolling it over a wooden dowel to the desired curve. if the material starts to bubble, you know you have overcooked it.
Hope that helps.
Robert Sarakin,
Mechanical Division leader 2013-2014,
Disc Acquisition Device (DAD) Leader 2012-2013,
Participant: 2011-2014
Unread 01-16-2017, 09:59 PM
MrForbes's Avatar
AKA: Jim
I've been involved with building several robots that used polycarbonate for various things, over the past dozen years...I think I've used heat to form it, once, in that time. Just seems like a bit of unnecessary work?
Unread 01-17-2017, 09:13 AM
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I am with MrForbes.
Polycarb in thicknesses of 1/16 th or so are very easy to bend on a brake without heat at all.
I have seen some splitting with 1/8th but that is still servicable for most applications.
I don't think heat will hurt in most cases but I don't think it is necessary.
Dr. Joe J.
Team #88, TJ2
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
