OCCRA
Go to Post I know nothing. - Erin Rapacki [more]
  #31   Spotlight this post!
Unread 06-16-2017, 12:50 PM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: How to bend lexan for a hood?
Originally Posted by Chris is me View Post
For single ball shooters with a consistent loading path, this will almost always produce more accurate results than a flat back.
Would you say the same is true for non-spherical balls like 2017 and 2009? I'm not disagreeing, just wondering your opinion. I would think that not having a flat back would exacerbate the inconsistency caused by different ball orientations. I haven't done any actual testing on this though, so I'm wondering if anyone can comment on this.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
  #32   Spotlight this post!
Unread 06-16-2017, 01:14 PM
Chris is me's Avatar
on a break
AKA: Pinecone
no team (formerly FRC 3929, 228, 2791)
I am not certain about 2017, since my team did a multiple-ball shooter we really didn't test a no-backing option. The holes in the balls really didn't change the dynamics of the ball shooting that much, though.
In 2009, it probably would have been better to use a flat back, but it also wasn't a good idea to shoot a single ball at a time that year either, so it's sort of a moot point.
Sort-of looking for a new team in or near Chicago; PM me if you have a lead.
Mentor: 3929 (2018)
Mentor / Drive Coach: 228 (2016-17) - 2016 RIDE Winner &
Consultant: 2170 (2017)
College Mentor: 2791 (2010-15) Build Photos - 2013 WPI Finalists, 2012 BAE Finalists
Student: 1714 (2009) - 2009 MN 10K Lakes Winners
  #33   Spotlight this post!
Unread 06-16-2017, 01:25 PM
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
On our limited prototypes, the holes in the balls caused quite a bit of variance on rail shooters.
Please take the GreyT Products survey here!
2x1 and 2x2 1/16" wall tubing for sale!
Need help? Check out 973 Remote Assistance and Mentorship Program.
2017 "World Champions"
2014 Galileo Champions
2011 World Champions
  #34   Spotlight this post!
Unread 06-16-2017, 03:29 PM
Rangel's Avatar
Rangel Rangel is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond reputeRangel has a reputation beyond repute
We found the same. A soft backing seemed to help alleviate this provided the ball could be centered left-to-right the same way each time. The ribbed hood we first made had terrible accuracy and the balls would go everywhere. We then tested different hood materials by bouncing a ball on the material and seeing what made the ball bounce the least. Of the materials we had on hand, shelf liner ended up performing the best but I'm sure there was better material out there.
Did anyone have a lot of success with a ribbed hood? If so, what did you have to do to get it working?
2012 Dean's List Winner
2014-? Mentor
  #35   Spotlight this post!
Unread 06-16-2017, 05:43 PM
GeeTwo GeeTwo is offline
In Transition
AKA: Gus Michel II
Rookie Year: 2013
Originally Posted by Rangel View Post
We found the same. A soft backing seemed to help alleviate this ...
You might want to try corrugated plastic; it already has some give built in. It is also much easier to work with an airgun than polycarbonate. We found out when we used it to prototype gear slides on our robot, and wound up using it because it has such a low CoF with the gear. Caveat - I've never used corrugated for a shooting hood, but I thought it was worth a try.
Also, by "shelf liner", do you mean the contact-paper like stuff, the irregular mesh that many teams use in the drawers of their tool chests, or something else?
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
  #36   Spotlight this post!
Unread 06-16-2017, 05:48 PM
Rangel's Avatar
John Rangel
Yes exactly that material. Our hood was shaped with cnc cut arcs with polycarbonate mounted and bent against the arcs. The shelf liner was then placed on the polycarbonate. I believe we used more layers of shelf liner on the bottom and worked our way up to two layers thick at the end of the hood.
2014-? Mentor
  #37   Spotlight this post!
Unread 06-16-2017, 08:42 PM
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
What is it about multiball shooters that makes this not the case? I know 2012 also saw a lot of successful hood shooters. Do spines only improve consistency if the flywheel is more consistent as well, ie not being affected by back-to-back balls?
2018 | Gracious Professionalism x3, Asheville Winners, NCCMP Finalists, NC District - 3rd Rank
2017 | Industrial Design, Gracious Professionalism, NCCMP Winners, NC District - 1st Rank
2016 | Innovation In Controls, Industrial Design, Quality Award, NC District - 4th Rank
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
