OCCRA
Go to Post Sometimes I think all the Game Hint does to us is make us terrible listeners. - Chris is me [more]
CD-Media
Unread 09-22-2018, 08:08 AM
Anxjos Anxjos is offline
Anxjos is an unknown quantity at this point
2009 Driver Station
The Leader of our team asked me to use the 2009 Driver Statio in one of our older robots but I canīt find any guides or basics tutorial about hpw to use it.
Unread 09-22-2018, 08:36 AM
AriMB's Avatar
AriMB AriMB is online now
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: 2009 Driver Station
If I'm not mistaken, the 2009 driver station was the first year of the cRIOs, and they were controlled by those blue controllers (as opposed to laptops). Those controllers had some problems, including durability problems. If you don't have one on hand, you'll probably be hard pressed to find one.
You can find more information about the 2009 (-2014) control system here, thanks to the outstanding work of team 358.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 09-22-2018, 08:40 AM
Billfred's Avatar
Billfred Billfred is offline
Shock the system.
AKA: Boom.
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron) (Also, CD mod.)
Correct on all counts. The 2009 driver station is best used as a paperweight, as FIRST had to release several fixes mid-season to try to make them survive. If you're using a cRIO, you'd be better served using a laptop and the 2014-spec software.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach (oh, and I worked at AndyMark during this time)
2018-: FRC 1293 (Pandamaniacs) - Mentor
117 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
Unread 09-22-2018, 10:41 AM
Hi, I just looked in team 358 documentation and I couldn't find any tutorials or guides for the 2009 driver station
Unread 09-22-2018, 10:58 AM
AriMB's Avatar
FRC #5987 (Galaxia)
Details for the components
Set up instructions (including a link to download the 2009 Control System manual)
Since that driver station was only in use for one year, and that was before FIRST switched website addresses, breaking all of the old links to documentation, it's probably going to be difficult to find really helpful tutorials. If I were in your place, I would try to load 2010-2011 firmware onto the cRIO and control it with a laptop.
Unread 10-01-2018, 01:44 PM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
AKA: The Bearded ONe
FRC #2974 (WALT)
Any driver station through the 2017 version will control the CRio robots. 2015-2017 have a 2014 communication setting. The 2914 and below lets you set some variables and supports some remote DS IO boards.
Updating the Crio firmware is not necessary to interface with the driver stations. Updating the firmware requires re compiling the source code which is problematic. You have to use the right WPLIB plugins and the correct version program languages which not the current versions. You have to update the source to which version of the WPLIB you are reason. Small changes, but you know how picky and literal minded programs are...
Unread 10-01-2018, 01:57 PM
CarlosGJ CarlosGJ is offline
418 alumnus, 696 mentor
AKA: Carlos Gross Jones
FRC #0696 (Circuit Breakers)
CarlosGJ has a reputation beyond reputeCarlosGJ has a reputation beyond reputeCarlosGJ has a reputation beyond reputeCarlosGJ has a reputation beyond reputeCarlosGJ has a reputation beyond reputeCarlosGJ has a reputation beyond reputeCarlosGJ has a reputation beyond reputeCarlosGJ has a reputation beyond reputeCarlosGJ has a reputation beyond reputeCarlosGJ has a reputation beyond reputeCarlosGJ has a reputation beyond repute
Shameless self-promotion: if you're playing with the 2009 driver station, you may be interested in my whitepaper about its software. I agree, however, that it's definitely not the easiest path to getting a robot working.
Note: if anyone has the 2009 driver station update ("DSUD.BIN") laying around, I'd very much appreciate a copy. I've been unable to find it online.
Unread 10-01-2018, 02:03 PM
AriMB's Avatar
FRC #5987 (Galaxia)
Sure they can use a current DS version, but I'm fairly sure they will need to update the firmware on the cRIO at the least, and probably also recompile the program. The 2009 cRIO firmware interfaces with the blue control box. If they want to use that cRIO with a driver station laptop, will they not need to update the cRIO firmware to a version that communicate with a laptop instead of the blue box (i.e. 2010-2011)?
Unread 10-01-2018, 02:29 PM
This one?
We are what we repeatedly do. Excellence, then, is not an act, but a habit. -Aristotle
Unread 10-01-2018, 02:38 PM
Originally Posted by Mark McLeod View Post
This one?
That's the one. You are a gentleman and a scholar.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
