OCCRA
Go to Post Use checklists. If it's good enough for NASA, it's good enough for FIRST. - Rick TYler [more]
Unread 03-18-2017, 05:12 PM
Oblarg Oblarg is offline
AKA: Eli Barnett
Pathfinder + Motion Profile Details
So, today we (finally!) got Talon SRX motion profiling with Pathfinder-generated trajectories working acceptably well on our practice bot.
We noticed a couple of things during the process, and were wondering if other teams have had similar experiences:
1) Measured wheel diameter does not seem to correspond exactly to "effective" wheel diameter. That is, we measured our 4'' Colsons at ~3.85'', but empirical tests (i.e. having the robot run a linear trajectory and measuring distance traveled) indicate that they're "effectively" closer to ~3.75''. This may be due to wheel slippage, but our profiles are pretty tame. Perhaps it's due to wheel compression? We don't quite know.
2) Similarly, measured wheel base size does not seem to correspond to "effective" wheel base size. That is, when we generate profiles with our measured wheel base width of ~24.5'', the robot notably under-turns - the "effective" wheel base width for turning correctly seems to be closer to 30''. We think this is due to wheel scrub, but again, we're not quite sure.
After empirically "fudging" the aforementioned quantities, the profiles seem to work quite well. Have any other teams done similarly?
(We have, indeed, verified that the profiles are being followed reasonably well - so this is not due to poor control loop tuning or unachievable profiles)
"The breakfast of champions!"
Unread 03-18-2017, 05:22 PM
Re: Pathfinder + Motion Profile Details
This might be related in a way to rolling radius. Have you tried running the bot on both compliant (e.g. carpeted) and non-compliant (e.g. hardwood or concrete) flooring to see what difference that makes?
AKA: Eli Barnett
We have not! I'll put this on our list of things to try.
Unread 03-18-2017, 05:31 PM
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Understeer was an issue for 1736 last year for our low bar high goal due to our high scrub drivetrain with encoders only. We added a gyro with a P gain loop to maintain heading and the result was night and day when it came to repeatability of our path plan. We also had a fudge factor adjustment for distance traveled due to pneumatic wheels to get distance to within inches. With a known wheel diameter, the factor should be much closer to 1, but I wouldn't be surprised if you still need a small adjustment to get actual measurement close to your theoretical calcs. Other tweaks like preloading your gear mesh at start of the path can help a little also also.
2526 Crimson Robotics (2017 - current)
1736 Robot Casserole (2012 - 2016)
Unread 03-18-2017, 05:34 PM
AKA: Eli Barnett
We're using a NavX similarly this year (simple P loop to keep us driving straight), but only employ it in teleop. It's not clear to me how we would integrate it with running motion profiling on the Talons.
Unread 03-18-2017, 06:48 PM
jeremylee's Avatar
We had left and right velocity control loops for our 6wd. Then we add the output from our gyro P loop to one side (+ 1 rpm) and subtract from the other (-1 rpm) causing it to turn in the direction the heading is off. Main issue is this can cause some overall error in distance by the end of the path. More complicated implementations account for this, but we stopped here and added to our path as needed based on what happened on the field.
Unread 03-18-2017, 06:50 PM
AKA: Eli Barnett
Yeah, we're not using our velocity servo to follow paths - we're using the Talon SRX motion profiling, which runs a position servo with a velocity feedforward. All of it is run on the motor controllers (you send them a buffer with the whole profile and then the motor controllers execute it), and I don't see any obvious way to add gyro feedback to it.
Unread 03-18-2017, 06:58 PM
jeremylee's Avatar
Yeah, we're not using our velocity servo to follow paths - we're using the Talon SRX motion profiling, which runs a position servo with a velocity feedforward. All of it is run on the motor controllers (you send them a buffer with the whole profile and then the motor controller executes it), and I don't see any obvious way to add gyro feedback to it.
You would have to send your setpoints from the rio to the srx make it work. This is how 2526 is doing it this year.
Unread 03-18-2017, 09:24 PM
phurley67's Avatar
phurley67 phurley67 is offline
Programming Mentor
AKA: Patrick Hurley
phurley67 will become famous soon enough
We started out using the Talons built in motion profiling, but decided (after some testing) to use the talons in closed loop velocity mode and run our motion profiles on the RIO, so we could add in gyro compensation.
That said both methods worked very well.
Unread 10-05-2017, 09:10 PM
JayShower JayShower is offline
AKA: Jay Schuaer
FRC #1732 (Hilltopper Robotics)
JayShower is an unknown quantity at this point
Can you elaborate on what you did? If the Talons are in closed loop velocity mode, are you only following the velocity portion of the profile and not the position? Are you somehow modifying the velocity setpoint based on the position and gyro error?
Unread 10-06-2017, 11:06 AM
Jared Russell's Avatar
in hibernation
This is what 254 does. We compute a velocity setpoint based on the equation:
V_setpoint = V_desired + Ka * A_desired + Kp * position_error + Kv * velocity_error
V_desired itself is the result of a pure pursuit controller and motion profile generator, but is basically equivalent to:
V_desired = V_profile + (left_side ? 1.0 : -1.0) * Kg * heading_error
Unread 10-11-2017, 10:09 PM
AKA: Jay Schuaer
What resources would you recomend to learn more about this (Control theory?)? I know there is a lot on Chiefdelphi but it is all very spread out. I have a lot of questions.
Unread 10-11-2017, 11:14 PM
AKA: Jay Schuaer
Also, after getting the V_setpoint, how do you convert that to motor output?
Unread 10-12-2017, 10:32 AM
M3rcuriel's Avatar
M3rcuriel M3rcuriel is offline
Head Mentor
AKA: Lee Mracek
FRC #0299 (Valkyrie Robotics)
M3rcuriel has a spectacular aura aboutM3rcuriel has a spectacular aura aboutM3rcuriel has a spectacular aura about
Velocity PID loop on the Talon would work.
Unread 10-12-2017, 10:36 AM
in hibernation
V_setpoint is the velocity setpoint we send to the Talon SRX controlling the drive motors (in velocity control mode). Alternatively you could multiply the V_desired term by a gain to do unit conversion and get a voltage to command.
For learning more about this stuff, there are two categories of resources (and approaches in general) that I find useful. The first is looking at literature from the industrial motion control community. For example, see this article about using feedforward with PID. Industrial motion control in this context is basically using COTS servo drives, PID controllers, and trajectory generators to do (generally single input, single output) feedback control of industrial processes. This community skews towards the practical and intuitive without getting too math-heavy. This makes it a good match for most FRC applications where students don't already have a strong controls background. The Talon SRX documentation also falls into this category and is must-read, IMO.
The second category is "formal" control systems literature, more akin to what you would learn in a college class. There are many textbooks and online resources for this. You'll read about "classical" control systems in the frequency domain (Laplace and Z transforms, Root-Locus plots...eww, etc.) and also "modern" control systems in the time domain (state-space, pole placement, LQR, etc.). There is a ton of material to cover, so absent a mentor who is fluent in this stuff and/or a *very* motivated student with a strong math background, it's easy to drown before you can swim. The upside of this approach is you learn some very powerful tools that can help you design complex control systems (multi input/multi output, nonlinear systems, etc.) with confidence that they will behave as expected on real world hardware.
Motion profile and path planning is a bit of a separate beast, and you can find resources in the robotics and video game communities. Some buzzwords to search for: "Motion profile", "Pure pursuit", "Motion planning", "Path planning", "A*", "spline"
