OCCRA
Go to Post Mmmm scrap used parts. Dismantle, find data sheets and have fun.:D - techhelpbb [more]
Unread 04-14-2018, 04:29 PM
NerdRage's Avatar
NerdRage NerdRage is offline
Student Captain
AKA: Aaron Fang
FRC #3863 (Pantherbotics)
Team Role: Student
Rookie Year: 2016
NerdRage has a spectacular aura aboutNerdRage has a spectacular aura aboutNerdRage has a spectacular aura about
pic: 4x 775pro Ball Shifting Gearbox
Unread 04-14-2018, 04:31 PM
asid61's Avatar
asid61 asid61 is offline
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
Re: pic: 4x 775pro Ball Shifting Gearbox
Looks pretty neat! I would caution against using the aluminum (?) gear for the first stage, as I've heard aluminum 32p gears wear down pretty fast in drivetrains.
I love your standoff placement up near the 775s, and the simple 2-plate design. Very good stuff.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016 (student)
2018 Davis Finalists (w/ 6474 and 3880), 2018 Roebling Winners (w/ 3476, 1323, and 1778)
Unread 04-14-2018, 04:48 PM
Andrew_L's Avatar
Andrew_L Andrew_L is offline
Learn to crawl before you ball
AKA: Yo! Champ in the making!
FRC #0299 (Valkyrie Robotics)
Andrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond reputeAndrew_L has a reputation beyond repute
Looks great! You should model your wheel geometry and see if your motors would intersect if they're pushed further out - if they don't, you can shorten the gearbox and the spacers inside and have the motors hang over the wheel for extra space and weight savings.
And of course, make sure you test a 775drive in the off-season before attempting it in-season!
Unread 04-15-2018, 10:59 AM
JohnFogarty's Avatar
R I P Georgia Dome
FRC #1102 (M'Aiken Magic & Team FUN)
Yeah we use 20dp gears in our drive and have not had any wear issues in our gear drive after over 50 matches. I think there are better tooth count options in 20dp as well.
John Fogarty - 13 Years in FIRST - http://cceti.com
FLL 1102 -> FTC 3864/1102 | FRC 1102 -> FRC 1772 -> FRC 4901 -> FRC 5632 | FTC 11444 -> FRC 1102 | VRC 5817
Head Coach - FRC Team 1102 M'Aiken Magic
"By teaching students the power of STEM, we're M'Aiken Magic happen!"
2010 FTC World Championship Winner - FTC Team 3864 Driver/Captain
Unread 04-15-2018, 08:59 PM
SpruceyBrucey's Avatar
SpruceyBrucey SpruceyBrucey is offline
FRC #0885 (Bruce Force Trauma)
Rookie Year: 2015
SpruceyBrucey has a spectacular aura aboutSpruceyBrucey has a spectacular aura about
20dp gears are great expect they don't come with matching 20dp pinions that you can press onto 775s (that I know of).
Unread 04-15-2018, 10:24 PM
Andrew_L's Avatar
With the great options for 32dp gearing (and 3mm pitch belting), I'd never want to run straight to a 20dp stage off a 775pro!
Unread 04-15-2018, 10:53 PM
NerdRage's Avatar
Student Captain
AKA: Aaron Fang
Team Role: Student
Rookie Year: 2016
I was definitely trying to do that when I was modeling this gearbox, although then mounting the spacers on top would have been difficult. Furthermore, since we're not really that experienced with chain-in-tube, we still put our chain outside of the tube, so there's just enough space to put in two #25 sprockets from VEXPro, so it all works out kinda nicely, despite the bit of space lost from not letting the motors hang over the tube and wheels.
FIRST Stronghold - LA Regional Judge's Award & Semifinalists, Ventura Regional Semifinalists
FIRST Steamworks - Orange County Quarterfinalists
FIRST Power Up - LA Regional Quarterfinalists, Ventura Regional Semifinalists
Unread 04-15-2018, 11:17 PM
asid61's Avatar
Design Simple
AKA: Anand Rajamani
The great options that don't let you get the reduction you need, in the form factor you want!
Call me when they get 32p gears in multiples of 2 teeth any pitch diameter from 0.7" to 4.2".
Team 299 2017
Unread 04-15-2018, 11:21 PM
Andrew_L's Avatar
For an initial reduction, they pretty much get you in most ranges you'd want. I use the 12:100 almost every time I use a 775pro gearbox, or sometimes a 12:80. I've used the 12:60 in intakes before and know people who have used 12:40 on shooters. The 20dp stuff is great for finer adjustment later on within a gearbox, but when you just need as much reduction in as little space possible, 32dp wins every time!
Unread 04-15-2018, 11:23 PM
asid61's Avatar
Design Simple
AKA: Anand Rajamani
You can't fit two 775s on a 40t, and 60t leaves a lot of space unused. 80t is just small enough to make doing a gearbox like the OP posted difficult due to the gear clearances with the cluster shaft, which is part of why 1072 opted to go with the 85t steel gear from AM this year for our elevator.
Team 299 2017
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
