OCCRA
Go to Post [Pi day] is an irrational holiday - KenWittlief [more]
Unread 08-08-2018, 04:19 PM
SentientBacon's Avatar
SentientBacon SentientBacon is offline
AKA: Ronak
FRC #3128 (Aluminum Narwhals)
Rookie Year: 2015
SentientBacon is a name known to allSentientBacon is a name known to allSentientBacon is a name known to allSentientBacon is a name known to allSentientBacon is a name known to allSentientBacon is a name known to all
pic: Upgraded FRC Control System Wiring Diagram
Unread 08-08-2018, 04:24 PM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: pic: Upgraded FRC Control System Wiring Diagram
Looks good, except the PWM wire labels arenít correct. PWM wires are:
red = +5V
white = signal
black = GND
The PWM signal works by quickly switching the signal wires between high (+5V) and low (0V/GND). The amount of time the signal spends at high vs low determines the value.
You may also want to label which terminal in the VRM to plug in the radio, and add a second power wire on that path going to the radio barrel jack.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 08-08-2018, 04:32 PM
Bluman56's Avatar
Bluman56 Bluman56 is offline
No more carpet ripping Robots
AKA: Nikita
FRC #2579 (LIC Robodogs)
Bluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant futureBluman56 has a brilliant future
I would also differentiate between single and double solenoids just so teams with only single solenoids and not a lot of pneumatic experience don't freak out.
Unread 08-08-2018, 04:34 PM
chadr03's Avatar
chadr03 chadr03 is offline
FRC #2582 (PantherBots)
chadr03 is a splendid one to beholdchadr03 is a splendid one to beholdchadr03 is a splendid one to beholdchadr03 is a splendid one to beholdchadr03 is a splendid one to beholdchadr03 is a splendid one to beholdchadr03 is a splendid one to behold
Originally Posted by AriMB View Post
Looks good, except the PWM wire labels aren’t correct. PWM wires are:
red = +5V
white = signal
black = GND
The red line +5V on a PWM wire will also be the center wire. Neat feature so if you plug PWMs in backwards you will not fry anyting.
Unread 08-08-2018, 05:26 PM
AKA: Ronak
Rookie Year: 2015
Thanks for the feedback! Looks like my PWM knowledge isn't quite up-to-par (in my defense, our team went all in with CAN this year, and I can't say we've ever looked back).
Here's an updated snapshot:
(Chief Delphi doesn't like high-quality pictures, apparently)
Also, if anyone finds this to be a useful resource (just like how the 2015 one that Frank Merrick auctioned off a couple weeks ago was really helpful for our team in teaching new members electronics), here's a high-res, printer-friendly pdf.
Unread 08-08-2018, 05:35 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
*Snip*
I might suggest adding wires for the outputs of the speed controllers (with their associated colors and polarity) and noting that they go to the motors (you might have to reverse the PWM speed controllers to do this).
You could also probably move some of the items on the right side over a bit to get more room if you're trying to maintain a particular size. You could also probably shrink the compressor graphic.
Also, most wiring diagrams indicate wire cross points with indicators like these that you might want to consider adding:
2005-2008: FRC 703 Phoenix - Robot Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 08-08-2018, 06:14 PM
stingray27's Avatar
stingray27 stingray27 is offline
Michigan to Texas
AKA: Michael Ray
FRC #6800 (ViperBots Valor)
stingray27 is a splendid one to beholdstingray27 is a splendid one to beholdstingray27 is a splendid one to beholdstingray27 is a splendid one to beholdstingray27 is a splendid one to beholdstingray27 is a splendid one to beholdstingray27 is a splendid one to beholdstingray27 is a splendid one to behold
Gauge sizes are also nice to have.
Looks like you have wire size reflected in the diagram just based on the thickness of the wire, but maybe have a key or annotations?
Michael Ray
Head Coach: ViperBots Valor 6800
Alumni: Team RUSH 27
Driving Record: 93-64-0 Best Finish: Finalist (x4 FiM Districts)
Coaching Record: 49-37-0 Best Finish: Finalist (2018 Lone Star South)
Unread 08-08-2018, 06:31 PM
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond repute
That's one way, and it's arguably easier to read, but it's a hell of a lot of work. There's another popular style which shows crosses like the OP did, and interconnects with a dot. I prefer that style personally.
edit: and there's only one spot on your diagram you'd use a dot - at the RSL. Maybe at the POE injector (but that's weirder)
Unread 08-09-2018, 08:49 AM
scubadiv3r's Avatar
scubadiv3r scubadiv3r is offline
Allison
FRC #6574 (Ferradermis)
scubadiv3r will become famous soon enough
Love that you're doing this, we haven't had a properly updated system visual since 2015, looking great so far!
One thing to note though is the PWM cable on the SPARK is flipped, ground goes towards the outside of the controller
Keep calm and believe in the water game
2012-2015: #1259 Paradigm Shift
2016: #1259 Paradigm Shift
2017-Present: #6574 Ferradermis
Unread 08-09-2018, 12:12 PM
philso philso is offline
This is a cool resource.
I would suggest making some of the symbols (especially the RSL, servo, compressor) for the components smaller to give you more "space" on the drawing. They do not have to be to the same scale to communicate how they are connected.
Standard practice is for wire sizes and colours to be defined in a document separate from the schematic. The schematic should contain a reference to the relevant Game Manual for the wire sizes and colours so that they are only defined in one document. This avoids the problem of conflicts between documents.
... Also, most wiring diagrams indicate wire cross points with indicators like these that you might want to consider adding:
The most unambiguous practice for schematics is to always indicate junctions with a T-intersection. Thus, wires crossing (like a +) always indicates no connection. With this methodology, the dots are completely optional. One reason for this comes from when reproduction methods were more "low-fi" i.e. blue-prints and photostat machines (early form of photocopier). These older reproduction methods produced fuzzier images and after one or two generations of copies, details such as the dots would become indistinct and cause confusion. The schematic that Brendan attached is drawn using this methodology. If I am not mistaken, there is an old Mil-Spec that required schematics to be drawn this way.
Unread 08-09-2018, 12:58 PM
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Looks great but a couple of nit picks.
I would not consider the nominal 12v battery to be "high voltage" which I associate with dangerous voltages. Also since the robot frames are isolated I wouldn't call the corresponding black lead ground. I'd suggest the use of the common terms B+ and B- which is what you'll actually find on some of the motor controllers.
For the same reason I wouldn't call the black wire in a PWM ground but instead use either B- or Signal Return because it allows the signal current to return to the source.
Unread 08-09-2018, 01:44 PM
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
It might make sense to change the label "Victor SP" to "Victor SP/SPX/Talon SRX" in the PWM section. Many teams don't realize SPX/SRX supports PWM and CAN-bus (auto detects on the same wires).
Omar Zrien - CTR Electronics - Cross The Road Electronics - Chief Software/Owner
CTRE New products | CTRE/FRC Source Examples | FRC Installer (for Talon SRX and more)
Get Latest Updates on Facebook | Twitter
Unread 08-09-2018, 07:10 PM
Big Ideas Big Ideas is offline
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
I would Put the output lines on the motor controllers. After all, that is the point. --looking good
Unread 08-09-2018, 11:13 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
But why would you ever use them this way on an FRC robot?? Since the SRX came out, the only reason we've used PWM is because we were able to use controllers we already had, or we're controlling it with an Arduino; in both cases we've used PWM-only controllers, which are significantly less expensive. Just because you can doesn't mean that you should.
And to OP, thanks thanks for this! Our main controls guy will be a senior this year, and we really need to train his replacement; this will be a great help.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Unread 08-10-2018, 10:24 AM
ozrien's Avatar
Omar Zrien
AKA: Omar
I agree, and I like CAN bus too. I'm sure there are other CAN-vs-PWM and TalonSRX-versus-whatever CD threads that cover the reasons.
...Just because you can doesn't mean that you should...
But ultimately it is the team's choice, and I thought the wiring diagram was meant to show all the options.
Also Victor SP is not available for purchase anymore, because it has been replaced by Victor SPX (lower price + CAN/PWM). It came off as strange that the SP was on there, but not mention SPX for PWM.
BTW, kudos to the OP - great work.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
