Go to Post "Uh-oh, it's in crazy mode again. Hit the button!" - StephLee [more]
Unread 01-12-2018, 02:12 PM
el_pablo el_pablo is offline
AKA: Nicolas Bourré
FRC #4007
el_pablo is an unknown quantity at this point
Unable to drive the robot
Hey guys,
I've read the CTE migration manual.
  • PWM motors work.
  • PCM works.
I'm unable to make our robot drive with the differentialdrive. It just does not respond.
Also, I get this error :
ERROR 103 CTR: Firm Vers could not be retrieved. Use Web-based config to check ID and firmware(CRF) version. Talon SRX 12
at Device_LowLevel::CheckFirmVers(int, int, ctre:hoenix::ErrorCode)
at ctre:hoenix::motorcontrol::lowlevel::MotControll er_LowLevel::SetDemand(ctre:hoenix::motorcontrol ::ControlMode, int, int)
at c_MotController_SetDemand
at Java_com_ctre_phoenix_motorcontrol_can_MotControll erJNI_SetDemand
How code is located here.
https://github.com/team7116/Robot-2018
  • We are using a Command based Robot.
  • The command to drive is DriveWithJoystick.java
  • The system for the drive train is DriveTrain.java
Thanks for helping us
Unread 01-12-2018, 02:46 PM
forbes's Avatar
forbes forbes is online now
NYC Googler
AKA: Evan Forbes
FRC #0694 (StuyPulse)
forbes has much to be proud offorbes has much to be proud offorbes has much to be proud offorbes has much to be proud offorbes has much to be proud offorbes has much to be proud offorbes has much to be proud offorbes has much to be proud of
Re: Unable to drive the robot
What version firmware did you put on the Talons?
Unread 01-12-2018, 03:24 PM
Jacob C. Jacob C. is offline
Engineer at CTR Electronics
FRC #4130 (The Blue Devils)
Jacob C. has much to be proud ofJacob C. has much to be proud ofJacob C. has much to be proud ofJacob C. has much to be proud ofJacob C. has much to be proud ofJacob C. has much to be proud ofJacob C. has much to be proud ofJacob C. has much to be proud of
https://github.com/CrossTheRoadElec/...irmware-and-id
FiM Volunteer
Since 2015: Controls Mentor for FRC 4130, The Blue Devils (Richmond, MI)
2009-2014: FRC Team 1718, The Fighting Pi
Full Disclosure: I am an Engineer for CTR Electronics
Unread 01-12-2018, 03:42 PM
AKA: Nicolas Bourré
FRC #4007
It's been done...
Unread 01-12-2018, 03:44 PM
AKA: Nicolas Bourré
FRC #4007
The article is a loop. There's nothing under this link.
Unread 01-12-2018, 03:56 PM
AKA: Nicolas Bourré
FRC #4007
The web-base says that I need to update the Firmware... I know, but where do I find the 3.1 CRF file?
It's not under the Users/Public/Documents/FRC. The only thing I have is the 2.00
Please don't reply with this link
Unread 01-12-2018, 04:00 PM
Bradley Boxer's Avatar
Bradley Boxer Bradley Boxer is offline
Team Captain
AKA: Bradley Boxer
FRC #0303 (TEST Team 303)
Rookie Year: 2015
Bradley Boxer is an unknown quantity at this point
It should be in C:\Users\Public\Documents\Cross The Road Electronics\LifeBoat\HERO Firmware Files , and called "TalonSrx-Application-3.1-FRC2018.crf". Is it not there?
The opinions expressed in this post are mine and do not necessarily reflect those of my team.
Unread 01-12-2018, 04:33 PM
el_pablo, please e-mail our support: support@ctr-electronics.com
If the firmware file is not present on the same computer you've installed Phoenix on, something is wrong and we need to understand the situation.
FiM Volunteer
AKA: Nicolas Bourré
FRC #4007
Ok, I found the problem. I have done the LifeBoat thing on a VM, but I was working with another computer to communicate with the Roborio.
Be sure the latest Phoenix Framework is installed on the right computer...
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
