Go to Post GP is a much longer-term investment, yet offers surprisingly high returns. Just like 401(k) plans, the important thing is to keep making contributions even when it seems there's no reward for it. - ayeckley [more]
Unread 01-13-2018, 09:03 PM
MattBaron MattBaron is offline
FRC #5099 (Cyberian Tigers)
MattBaron is an unknown quantity at this point
Climbing strategy/compatibility
My team has come up with 4 basic strategies for climbing:
1) Climb to top and have extenders that allow bots to climb on us ("Alpha" Climber)
2) Create a ramp for a bot to stand on ("Ramp bot")
3) Attach to somebody else extender/ramp ("Beta" Climber)
4) Climb from the side to prevent obstructing other climbers ("Side" Climber)
We voted down option 1, in part because of concerns that group 3 won't really exit given the unpredictability/lack of practice with something other than the provided bar. We are currently going with option 4.
I would like to see what other teams are thinking and whether anyone will be compatible with bots 1 or 2.
Unread 01-13-2018, 09:11 PM
Foxy_Fox Foxy_Fox is offline
FRC #5700
Foxy_Fox is an unknown quantity at this point
Smile Re: Climbing strategy/compatibility
Interesting idea
Unread 01-13-2018, 09:50 PM
Boltman Boltman is online now
Strategy/Rules/Scouting/Volunteer
AKA: Tom Byrne
FRC #5137 (Iron Kodiaks)
Boltman has a reputation beyond reputeBoltman has a reputation beyond reputeBoltman has a reputation beyond reputeBoltman has a reputation beyond reputeBoltman has a reputation beyond reputeBoltman has a reputation beyond reputeBoltman has a reputation beyond reputeBoltman has a reputation beyond reputeBoltman has a reputation beyond reputeBoltman has a reputation beyond reputeBoltman has a reputation beyond repute
Many ramp bots never score a climb themselves unless levitate and pretty much (unless dual size huge) negate a triple climb.
So the other options I find to be better strategy/RP wise, since they allow a more feasible double or triple climb with or without levitate.
That being said I don't expect to see much of it until late in the season. Sort of like capture in SH
We will likely try to climb have tried/succeeded when offerred prior, most likely 1 or 2 have not explored 4 yet but its valid
Iron Kodiaks Team #5137 San Marcos, CA
2017 Ventura Captain 3 (8, 3882) QF , 2016 Central Valley Captain 2 (973, 2135) SF
2015 Ventura Elimination selection (696, 1836) SF , 2014 San Diego Rookie All-Star Galileo Division
San Diego Elimination selection'17 (399, 968) SF ,'16 (1159, 812) SF , '15 (3021, 1772) QF
Orange County Volunteer 2016 and 2017
Unread 01-14-2018, 02:28 AM
Keefe2471's Avatar
Keefe2471 Keefe2471 is offline
FRC #2471 (Team Mean Machine)
Keefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud ofKeefe2471 has much to be proud of
There's also option 5, popularized as the "iron cross" in another thread, where you climb and bring either one or two other robots with you. Obviously, you now have to design a climber to lift 450-500 pounds, possibly with one hundred and fifty pounds offset without a balancing robot (if you use levititate to facilitate last minute scoring) and deploy some type of platform or fork for your partners to drive up onto. The advantages being that all you rely on your partners being able to do is move, and clear the wire harnesses. No cheesecake, lifters, or other abilities required for the robots you want to get a ranking point with.
Unread 01-14-2018, 05:22 AM
StarryNebula's Avatar
StarryNebula StarryNebula is offline
AKA: The infamous Ambre Crackers ;)
FRC #6996 (Koalafied)
Rookie Year: 2015
StarryNebula is an unknown quantity at this point
Our team went through some similar thinking. In my perspective, being able to climb from the side (option 4) would increase your chances of getting that Ranking Point in quals. If you can climb from the side, without obstructing the front rung, then another alliance partner who could climb using that rung (a climbing system based on the what-if-no one-else-can-climb-and-I-want-30-points strategy) + the levitate powerup will give you a well-deserved ranking point.
Then again, being able to take another robot up with you will make you very attractive as an alliance partner.
Just my thoughts
If the prototype works the FIRST ; ) time, you're doing it wrong.
I don't know how many times I've said this, but software, you ain't getting the robot.
Unread 01-14-2018, 09:12 AM
GeeTwo's Avatar
GeeTwo GeeTwo is online now
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
... We are currently going with option 4.
Just grabbing the box tubing supporting the rung and pulling up on it will not keep you clear of the space under the rung; you'll hang directly below it, and unless your robot is unusually small, will fill most of the width below the rung.
In brainstorming, we had a design which did this, with the hang set so that the robot would have its wheels on the scale side wall, oriented horizontally so we could DRIVE to one side or the other. Didn't prototype it.
We're working on a setup which should allow us to do both 1 and 3 as needed, though we'll probably only design to carry one additional robot, letting the third levitate.
Unread 01-14-2018, 11:38 AM
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Software engineer
no team (Anonymous)
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Not to mention it will be hella cool seeing 3 robots ascend at once
Unread Yesterday, 01:11 PM
georon georon is offline
FRC #4252
georon is an unknown quantity at this point
The idea here in this link is similar to #2.
https://debug-java.blogspot.ca/2018/01/blog-post.html
Can someone confirm, If the partner Bots in the alliance climb on either side on fold able raised platforms, and the team uses levitate power up, with the bot in middle is on ground, is this considered a successful 3 bot climb for the ranking point?
Unread Yesterday, 01:24 PM
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
As a team our students and mentors agreed upon constructing a robot with a deployable ramp on one side with an extension that folds out the other side of the robot to support both the alliance robots.
To make it clear, we will drive onto the middle of the platform, deploy ramp on one side while dropping an extension off the other side, have the other two robots drive up the ramp:
Robot A: sits on the extension
Robot B: Sits on the back of our robot
(yes both sections are wide enough for both max configurations of drive bases.)
*Game strategy for this indicates grabbing 3 power cubes for the levitate power up which we will do ourselves if need be.
*Neither ramp nor extension touch the carpet thus effectively completing the end game.
Team member 2004-2008
Team mentor 2008-20XX
http://www.team1708.com/
"Education is a powerful tool. Always use it to better someone else's life"
Unread Yesterday, 01:27 PM
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
I can't even count how many times this has been confirmed in the last few weeks. The thread search tool is your friend here. Check out previous discussions on ramps.
2012-2013: FTC 4601 (student)
2014-2015: FRC 135 (student) - 5 banners in 2 years!
2016-present: FRC 4272 (mentor)
Thanks to all of our alliance partners!
11, 51, 68, 71, 201, 234, 447, 494, 868, 910, 1108, 1241, 1501, 1746, 1760, 1918, 3098, 3147, 3180, 3301, 3487, 3865, 4269, 4485, 4580, 4926, 4982, 5188, 5403
Unread Yesterday, 01:29 PM
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
6) hang independently in such a way as to not prevent any other robots from doing their thing on the rung. This option is neutral in that it is minimally interfering but does not actively assist other robots in any way. My guess is that this will be what wins Einstein, but will be a crapshoot in your average qualification round.
http://www.angelbotics.com
Remember why you're doing this.
Unread Yesterday, 02:08 PM
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is online now
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Where would "attaching a winch with hooks to the rung and cheesecaking loops onto alliance members for said hooks" be?
Its kinda 1 and kinda 3
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I mean when the scariest thing in the room is on your side everything is fine.
Play is for kids this is serious...
Unread Yesterday, 02:23 PM
Keefe2471's Avatar
The main issue I see with 6 is there is that it leaves you no way to seed #1 on your field without that style hanger being very common. Last year for example on our field (Carver) the number 1 and number 2 seed averaged 3.30 ranking points. So, I think teams that want to seed 1st at competitive events will attempt stratagies that effectively guarantee them that ranking point. As long as one of the other robots on your alliance can move, the iron cross can get you the point, if both move ramps will work. I think that contributes to style 6 climbers being a somewhat rare commodity, and therefor less valuable. But that’s just a guess, shooters were pretty uncommon last year and I would think iron crosses or ramps (while far easier than 40 Kpa solo) will be fairly rare.
Unread Yesterday, 02:29 PM
mrnoble's Avatar
teacher/coach
Agree, this strategy will not seed first in quals, since the RP will only happen if there is another active climber on your alliance. I do think that it makes a team valuable in eliminations though, especially if it's fast, reliable, and really does not interfere.
Unread Yesterday, 02:38 PM
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
If you can make it package, this is a great concept. We've been going round and round on how to raise ramps. I really like the answer, "don't".
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
