Go to Post It goes to show how a FIRST team is not one person but a complex codependence of people who are all striving to meet the same goal. - Bill_Hancoc [more]
Unread 01-13-2018, 09:49 PM
ClarkBuchenroth's Avatar
ClarkBuchenroth ClarkBuchenroth is offline
FRC #3374 (Robobroncs)
Team Role: Driver
ClarkBuchenroth is an unknown quantity at this point
Lightbulb Wiring Plates!
Hello CD!
Team 3374 has a question for you!
What does your team use for wiring plates? Sheet metal? Box extrusion? How do you fit the wiring on your robot?
Unread 01-13-2018, 09:57 PM
MuskieProgramme MuskieProgramme is offline
FRC #6420 (Fire Island Robotics)
MuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of light
Re: Wiring Plates!
We use a Lexan panel, because it is non-conductive and lightweight.
Unread 01-13-2018, 09:58 PM
jtseng232's Avatar
jtseng232 jtseng232 is offline
AKA: Justin Tseng
FRC #5530 (The Lawnmowers)
Team Role: Electrical
jtseng232 will become famous soon enoughjtseng232 will become famous soon enough
Re: Wiring Plates!
+1. I don't know about them, but we get ours with holes, so it makes zip ties really easy to string through and doesn't require having a drill handy whenever you want to secure something to the board.
Unread 01-13-2018, 10:17 PM
philso philso is offline
Re: Wiring Plates!
The team I worked with last year used Coroplast for the electronics panel. It was very light, non-conductive, very quick and easy to work with and very inexpensive. We cut it with a knife. It was easy to make complex cutouts for components like the gearboxes. We attached the components using zip ties. The zip ties went through holes made with a small screwdriver. The whole plate was attached to the kit chassis using about 4-6 zip ties on each side and a few at the front and back. It was removed before Bag & Tag and installed on the practice chassis. It saw extensive (rough) service in practice, one Regional and several off season events with no trouble.
Unread 01-14-2018, 01:46 AM
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Wiring Plates!
Wood. 3/8" plywood is good though it is set up for 1/2". It provides an important structural portion of the robot as it forms one large triangulation gusset.
Unread 01-14-2018, 03:00 AM
jlindquist74's Avatar
jlindquist74 jlindquist74 is offline
WOPR Software Integration Lead
FRC #1622
Rookie Year: 1337
jlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond reputejlindquist74 has a reputation beyond repute
Re: Wiring Plates!
The last few years, we've used 3/16" ABS. It's a good structural shield to protect the wiring and components. It cuts and drills easily, and you can tap holes for machine screws to anchor components. Wiring is attached with zip ties using zip tie "saddle" anchors screwed to the board.
Of course, we buy it in black, and last year stuck a large spider logo decal on the bottom to be visible during the endgame climb.
Unread 01-14-2018, 09:18 AM
GeeTwo's Avatar
GeeTwo GeeTwo is online now
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Wiring Plates!
Plastic pegboard, for the same reasons given in post #3.
Unread 01-14-2018, 09:22 AM
Billfred's Avatar
Billfred Billfred is offline
Eat, Sleep, Break The Streak
AKA: Less Curt Hawkins, More a Paul Heyman Guy
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron)
Re: Wiring Plates!
1293 is fond of non-perforated lexan. I've used wood in the past too. No strong preference, just whatever is working with the design that year.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Taking on some tall orders.
2017: FRC 5402 (Iron Kings) - Mentor, Coach
2018-: FRC 1293 (Pandamaniacs) - Mentor
106 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 70,000 miles, and still on a mission from Bob.
Unread Today, 11:54 AM
Re: Wiring Plates!
We use aluminum perf stock and use wire ties to mount everything. In the event of a failure, a pair of wire cutters is the only tool needed to replace a defective component.
Generating steam since 1996.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
