Go to Post The biggest fallacy in FIRST is the belief we are just a bunch of different teams. We are ONE BIG TEAM with a lot of sub teams for the purpose of competition. - Al Skierkiewicz [more]
Unread 01-14-2018, 12:06 AM
Crabcakes5's Avatar
Crabcakes5 Crabcakes5 is offline
FRC #0156 (RPM - Robotics Plus Mayhem)
Rookie Year: 2015
Crabcakes5 is an unknown quantity at this point
Thumbs up FRC Game Calculation Interface 2018 Edition
Hello Everyone!
I am from FRC Team 156, and over the summer, I decided to create a small project to easily determine distances across the competition field. As this project developed, it naturally escalated into what it is today.
Currently, the program supports:
  • Measuring field distances (with some degree of accuracy (not perfect))
  • Planning alliance routes before matches at competitions
  • Measuring turn angles in degrees
  • Calculating ideal and estimated robot travel times (Estimated Time = 1.2*Ideal+4*(distance(inches)/600inches))
  • Outputting steps to be programmed during the autonomous period
  • Outputting python scripts for a robot to travel across an elliptical path (outputs the ideal gyroscopic heading from start of turn)
  • Scouting data from The Blue Alliance, determining averages, and conditionally formatting an excel document for teams to use to compare teams for alliance selection.
Here are some images of what the program can do:
Robot Field Mapping and Distance Measurement
Multiple Alliance Robot Strategy Planning
Autonomous Step and Script Sample Outputs
Scouting Utility Main Page
Scouting Utility Results Pittsburgh 2017
If you would like to try out this program for yourself, please feel free to download it at the link below:
FRC Game Calculator Interface 2018 Edition
Also, if you notice any bugs or inaccuracies within the program, please notify me at the email address provided in the Contacts section of the program, and I will hopefully release a patch within a short period of time.
Good Luck with the 2018 Season Everyone!
Unread 01-14-2018, 10:06 PM
frcfastteam frcfastteam is offline
FRC #7056
Rookie Year: 2018
frcfastteam is an unknown quantity at this point
Re: FRC Game Calculation Interface 2018 Edition
Instructions for running your program. Please and thank you!
Unread 01-14-2018, 10:09 PM
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is online now
Fuel Advocate
FRC #4967 (That ONE Team)
Jarren Harkema has much to be proud ofJarren Harkema has much to be proud ofJarren Harkema has much to be proud ofJarren Harkema has much to be proud ofJarren Harkema has much to be proud ofJarren Harkema has much to be proud ofJarren Harkema has much to be proud ofJarren Harkema has much to be proud ofJarren Harkema has much to be proud of
This is a lot of fun to play around with! Thanks for sharing it! We just had our big autonomous routine discussion yesterday. This will be useful in helping us validate our discussions and get some estimates on timing.
Unread 01-14-2018, 10:12 PM
Crabcakes5's Avatar
Rookie Year: 2015
Oh, sorry. I forgot to transfer the original README file into the program, but I can explain how to use it here.
To use the program you must be using a 64-bit Windows computer. It will eventually be ported as a project on GitHub, but that will not be for a week or more at the earliest. Once downloaded, you can use an unzipping program to uncompress the files (this step is not necessary as you can run the program within the .rar directory.)
To run the program itself, simply run the executable file titled "FRC_Game_Calculator_Index.exe" and the controls for the Field page are located within the "Controls" tab on the main menu. I also forgot to note the key "M" which creates a model robot on your screen to see how the sizes interact with your robot dimensions, and you can rotate this with the arrow keys and shift to speed it up.
Thanks for your interest in the program!
Unread 01-14-2018, 10:13 PM
Crabcakes5's Avatar
Rookie Year: 2015
I'm glad you enjoy the program! If you notice any bugs, feel free to tell me so that I can hopefully patch it quickly to keep the results as reliable as possible! Good luck this year!
Unread 01-14-2018, 10:27 PM
FRC #7056
Rookie Year: 2018
Hello I tried running from within the rar file and it uncompresses some files but then nothing happens. I am using Windows 10 with a 64 bit Core i7.
Unread 01-14-2018, 10:36 PM
FRC #7056
Rookie Year: 2018
I tried upcompressing the file with WINRAR and double click the .exe file the file disappears and nothing happens for me.
Unread 01-14-2018, 10:54 PM
Ian H. Ian H. is offline
FRC #5026 (Iron Panthers)
Ian H. will become famous soon enough
This is pretty sweet, thanks.
It works for me on Windows 10.
2005-2008 FRC492
2014-Future FRC5026
Unread 01-14-2018, 11:02 PM
FRC #7056
Rookie Year: 2018
Here is the error I received when running from within the .rar file: https://ibb.co/hnkdNR
I dont have any idea whats wrong and why it will not run for me.
Unread 01-14-2018, 11:15 PM
Crabcakes5's Avatar
Rookie Year: 2015
I'm not sure what is happening on your end either. Are you sure it is not opened anywhere else from beforehand which would stop it from unpacking properly?
One thing you may want to try could be going to Options->Settings->Viewer on WinRar itself and checking if *.exe exists within the "Unpack everything for" list. If it does exist there, try to add *.* to the end of the list and see if that resolves the problem.
Options->Settings
Viewer Normal Screen
View with *.*
Unread 01-15-2018, 05:56 PM
FRC #7056
Rookie Year: 2018
I have tried a couple things and received errors in both instances, i have provided screenshots to both instances:
Error received when double-clicking the .exe file from within WINRAR
https://ibb.co/ddBtrm
Error received when double-clicking the .exe file after extracting the folder with WINRAR:
https://ibb.co/jOfKWm
Unread 01-17-2018, 09:22 PM
Crabcakes5's Avatar
Rookie Year: 2015
Do you by any chance have another computer that you can try to run the program on? I'm having trouble figuring out what is going on as it has never happened to me on the numerous computers I've tested it on.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
