OCCRA
Go to Post the always so humble metal-in-motion.....i know your tricks; you all are gonna have a killer robot as usual.... - Stephen Kowski [more]
CD-Media
Unread 11-06-2018, 10:13 AM
acastagna acastagna is offline
FRC #1493
acastagna is an unknown quantity at this point
Visual Studio - create a new class
I am playing around with Visual Studio to try and get ahead of the learning curve, and have been able to create a robot project and even import our code from last year. However, when working with a new robot project I cannot figure out how to add a new class.
The "WPILib: Create a new class/command" function gives me the message "Must select a folder to create a command". I have been unable to figure out how to specify the folder. If I just create a new file and put in some code to define the class , the class is not recognized. I also tried creating an empty folder with the name of the class I want.
Is this something that is not enabled in the alpha version, am I missing something obvious, or is my problem the fact that I don't know anything about gradle?
Unread 11-06-2018, 10:20 AM
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
Re: Visual Studio - create a new class
If you right click on the folder you want to add a class to in the Explorer on the left of Visual Studio Code, you should see an option to "Create new class/command".
Unread 11-06-2018, 01:57 PM
FRC #1493
Thank you !
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
