OCCRA
Go to Post Even though our team really digs the Tumbleweed name, the kids normally refer to the robot as the 'Neun-agon'. - Amanda Morrison [more]
CD-Media
Unread 01-15-2018, 11:26 AM
Nick 6846 Nick 6846 is offline
FRC #6846
Nick 6846 is an unknown quantity at this point
Spark or Talon and CAN or PWM
For our Rookie team would it be best to use the provided Spark motor controllers and spend more $$ to get 2 more Talons ? Would it be best to use CAN or PWM for connecting the motor controllers ?
Unread 01-15-2018, 11:37 AM
mandrakejr3rd mandrakejr3rd is offline
FRC #0145 (T-RX)
Rookie Year: 2015
mandrakejr3rd is an unknown quantity at this point
Re: Spark or Talon and CAN or PWM
The Sparks should be put on your highest load motors.
As for PWM/CAN, what language is your team using? I know that LabVIEW has been having trouble with using CAN motor controllers, so if you use that, use PWM. In general PWM is less difficult to make work.
Unread 01-15-2018, 11:45 AM
nickbrickmaster nickbrickmaster is offline
AKA: Nick Schatz
no team ('Snow Problem, 3184 Alum)
nickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond repute
Unless you plan to use the advanced closed loop features of the Talon, there's no need to double your expenditure.
Sparks only support PWM, Talons support both. The aforementioned closed loop features only work over CAN.
In your place, I would stick with the Sparks. There's nothing wrong with PWM, and unless you want to do motion profiling there's no reason to use Talons.
This is a postmodern signature.
Unread 01-15-2018, 11:59 AM
Mr.R^2 Mr.R^2 is offline
FRC #6762
Mr.R^2 is on a distinguished road
Thank you for this thread and advice. I think this very helpful as a second year team that is just experimenting with CAN and closed loop. The follow up question I have is this.
If one wants to close loop the drive base, would you reccommend 4 talons (one for each cim motor, purchasing the new Victor's, for two, or could we use the old Victor's for two. I want to try to make the closed loop in the data port to free up resources from the Rio.
Thanks.
Sent from my SM-T810 using Tapatalk
Unread 01-15-2018, 12:03 PM
MuskieProgramme MuskieProgramme is offline
FRC #6420 (Fire Island Robotics)
MuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of lightMuskieProgramme is a glorious beacon of light
You can use 4 Talons (probably the safest bet), or 2 Talons and 2 Victor SPXs (a little risky, as they are brand new this season).
2 Talons + 2 VictorSPs would not work, as the Talons cannot communicate with the VictorSPs (only the RIO can).
Unread 01-15-2018, 12:10 PM
FRC #6762
Thanks. That was my thought. We have the new framework working on our benchtop test right now. We do not have the new Victor's, but may invest as a cost saving measure. If we do that, we may plan talons as a backup (drop a closed loop elsewhere).
Unread 01-15-2018, 01:00 PM
5719Titans 5719Titans is offline
FRC #5719
5719Titans is an unknown quantity at this point
If you plan on utilizing the closed loop features of the Talon SRX’s you only require one Talon per side. The second motor can then be controlled by the cheaper Victor SPX by utilizing the follow command in the new Phoenix framework. Personally I prefer CAN to PWM as PWM connections have fallen off our robot in previous years. CAN is slightly slower then PWM but I have not noticed the speed drop.
Unread 01-15-2018, 07:54 PM
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant futurethatnameistaken has a brilliant future
Why?
As a LabVIEW team, we haven't had trouble with CAN since we last used Jaguars in 2013. What trouble do you know of?
Unread 01-15-2018, 09:06 PM
orangeandblack5's Avatar
orangeandblack5 orangeandblack5 is offline
LabView in 2018 lol
AKA: Ian Stewart
FRC #5498 (Wired Devils)
Rookie Year: 2015
orangeandblack5 will become famous soon enough
I'm interested as well, we swapped to CAN off of PWM immediately after our rookie year and haven't seen any issues. Would be good to know about any, just in case.
Unread 01-15-2018, 10:03 PM
FRC #6762
A lot of people are having trouble getting labview running with the new libraries, but we have been successful thus far. We are using labview as well. Last year we used sparks, and did not know about PID or have any real deadband control. Our robot was top heavy to boot so it was incredibly jerky. It was to the point that we just used two motors to drive.
Our solution was to have a limit slider in the driver station and a trigger to give full throttle after we got going.
It was useful, but we would like to avoid the necessity this time around.
Unread 01-16-2018, 09:53 AM
Is it safe to say this is due to programming and mechanical design rather then speed controller choice?
Unread 01-17-2018, 03:01 PM
FRC #6762
This is definitely a possibility.
Unread 01-17-2018, 04:08 PM
FRC #0145 (T-RX)
Rookie Year: 2015
Originally Posted by thatnameistaken View Post
Why?
The Sparks have a higher peak amperage than the Talons and thus can handle the higher load motors better.
Since 2017, to use CAN you need to download the CAN libraries. This can be difficult for newer teams and prevents the easy sharing of code between teams that have included the library and teams that have not.
Unread 01-17-2018, 04:31 PM
Andy A. Andy A. is offline
Getting old
FRC #0095
The Talon SRX and SPARK have the same current ratings for both peak and continuous operation. 60 amps continuous, 100 amps for 2 seconds. Exactly what the parameters under which those limits are determined is a good question, but I suspect they're conservative enough we don't have to worry about it.
In any case, both controllers have been used with success in very high current FRC applications.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
