OCCRA
Go to Post It's cool to see that Shaun White is an active team member (6th person from top left). That guy must be amazing, as he can win a gold medal in snowboarding while also being active on a FIRST Robotics team. - Andy Baker [more]
CD-Media
Unread 03-13-2018, 09:29 PM
Landon K's Avatar
Landon K Landon K is offline
AKA: Landon Kohtz
FRC #6090 (Wayland Wildcats)
Rookie Year: 2016
Landon K is on a distinguished road
Talon SRX not keeping track of position
We were working on our comp. bot and our drive encoders (Greyhill 63R) are feeding into the SRX and the position and velocity are going up in the system print out and counting but when the motors stop the position and velocity goes to zero. We ran these all season and the printout of these values has been right. The practice bot has exhibited the same behavior and we have tried numerous encoders, cables and the two separate SRXs on the practice and competetion bot. We have also tried to go back on good backup code and that is also the same problem. If you have any solutions or ideas, it would be much appreciated.
Unread 03-13-2018, 10:41 PM
BriFRC1922 BriFRC1922 is offline
FRC #1922
BriFRC1922 is an unknown quantity at this point
Re: Talon SRX not keeping track of position
Is there something in the code that's resetting it to 0 after the motor stops turning? Are you talking about saving positions between enabling and disabling or are you talking about within one session?
Unread 03-13-2018, 11:14 PM
Landon K's Avatar
AKA: Landon Kohtz
Rookie Year: 2016
Solved- It appears there was something not right in the init for teleop. Thanks
Unread 03-20-2018, 05:52 PM
Maxcr1's Avatar
Maxcr1 Maxcr1 is offline
AKA: Max D "Code Boy"
FRC #2169 (KING TeC)
Rookie Year: 2016
Maxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant futureMaxcr1 has a brilliant future
Could you share specifically what worked? Someone else may have the same problem in the future.
Max DeVos | Programmer | KING TeC 2169
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
