Go to Post I find it quite amazing that this thread has been continuously active for more than two years. - Stephanie [more]
  #31   Spotlight this post!
Unread 01-17-2018, 08:01 AM
Akash Rastogi's Avatar
Head Coach | Lead Mentor
FRC #5686 (Wirecats)
Re: FRC 95 2018 Build Thread
Couple questions:
1) Will you be incorporating a disc brake into your elevator?
2) Have you ever used F4 Silicone tape? As per your previous comment you are still playing with different grip materials and I'd suggest trying it.
3) Your hole pattern seems quite large (unless I'm mistaken it looks 1/4), do you choose to rivet/bolt with larger fasteners and lower quantity instead?
4) Will you be getting things powdered/painted?
Jim Zondag is my spirit animal.
['18-'xx]: Lead Mentor FRC 5686
['17-'17]: Mentor FRC 2170
['16-'16]: Floating Mentor FRC 228
['13-'14]: Floating Mentor FRC 11/FRC 2495
['11-'13]: Founding Mentor FRC 3929 - 2012 World Championship Rookie Inspiration Award
['07-'10]: Student/Captain FRC 11 - MORT
['08-'12]: Founder - EWCP (OG)
  #32   Spotlight this post!
Unread 01-17-2018, 08:28 AM
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Originally Posted by Akash Rastogi View Post
Couple questions:
1) Nope. The stall load on the 775s to hold position isn't very large.
2) No, I will take a look at it, thanks! Do you have a suggested vendor?
3) Yes. The holes you see are 0.201, clearance for a #10, or 0.272, press-fit for a #10-32 PEM nut. The chassis design is frozen (on day 3-4 of build) long before we know what all of our mechanisms will look like, so we put a 1in pattern on top of each frame rail and work with that.
4) We're going to talk with a local PC'er, if that doesn't work out we'll spray paint them again.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
  #33   Spotlight this post!
Unread 01-17-2018, 09:21 AM
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
We've bought the silicone tape from ACE Hardware, in the plumbing section, before. It is very grippy, but tends to roll back/double up after a lot of use. And it isn't cheap.
Has prototyping yielded good results from the overhead roller? Any issues with the cube just doing a backflip?
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
  #34   Spotlight this post!
Unread 01-17-2018, 09:40 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Thanks for the tip.
Yes, it has. I have a few videos to post tonight. The top roller is mounted on a swing arm, so when the cube flips the roller just follows the cube until the cube is eventually acquired (<1s).
On a related note:
Our roller construction has been fun and interesting. We have traditionally machined metal inserts and used metal tubes to create rollers. This year, we wanted something lighter, cheaper, faster to make, and easier to replace. Well... we figured out a solution that we're really happy with:
In final form we're going to use a lighter wheel than a Colson and hose clamps to secure the sheet metal to the wheel, but the same general construction technique. This roller took about 10 minutes to cut on our sheet metal shears, roll-bend, and zip-tie in place. We're then attaching a() friction material(s) to the outside with electrical tape.
  #35   Spotlight this post!
Unread 01-17-2018, 12:12 PM
BeanBagel's Avatar
BeanBagel BeanBagel is offline
AKA: Ben Basel
FRC #1982 (Cougar Robotics)
Team Role: Leadership
Rookie Year: 2011
BeanBagel is on a distinguished road
It's really interesting to see other teams' season processes! This year our team is attempting to improve ourselves in several areas, including overall quality and aesthetics. I noticed you mentioned your team has spray painted your parts before. Since we're planning on doing the same this year, would you have any advice for spray painting aluminum?
  #36   Spotlight this post!
Unread 01-17-2018, 12:19 PM
Andrew Schreiber Andrew Schreiber is offline
Petitioning the UN to ban Lythgoe
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
James, any reason to use metal for roller tubes instead of plastics? I had good success last year with a 3" OD polycarbonate tube for an intake. Stuffed the motor right inside it. Reasonably light and should be more resistant to damage than the aluminum (flex vs deform).
Might even be able to get away with 3d printed plugs.
  #37   Spotlight this post!
Unread 01-17-2018, 12:31 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
This is actually the one thing that we get the most questions on, so it will be good to get the answers out publicly!
1. Prep your parts well. We thoroughly de-grease our parts with acetone. IPA will work well too. Degrease twice at least. This improves the chemical bonding of the paint.
2. Rough(ish) surfaces hold paint better than glossy surfaces. A quick sanding with 300-600 grit sandpaper will let the paint 'bite' into the metal more effectively. This improves the mechanical bonding of the paint.
3. Control your spray environment. Keep dust down, extract paint fumes and over-spray, keep temperatures warm or hot (70-80F+).
4. Lay your parts out horizontally. I know, you can paint both sides if you hang the parts vertically. Don't, unless you're good at spraying paint. You'll get many fewer, or no, drips if the parts are horizontal.
5. Prime. Get an etching or metal primer from the same manufacturer as your paint and apply a coat before painting. Match the color of the primer to the paint. White primer for light colors or thin-coverage colors like red.
6. Paint! Get a good quality shaker can, spray handle for the can, and go to town. Don't be afraid to practice, but practice with a comparable substrate. Spraying on cardboard is not the same as aluminum, so the practice isn't as useful. If you move fast you can hold the can quite close to the aluminum and get great coverage in 1-2 passes. Don't start spraying on the part, always be moving when spraying on the part, keep the nozzle at the same angle and distance to the part during each spray pass. Follow all instructions on how often to reapply coats as needed.
We used Rust-Oleum Painter's Touch 2X and loved it. See: https://www.homedepot.com/s/Rust-Oleum%2520Painter's%2520Touch%25202X?NCNI-5 with the comparable primers.
I had instruction from an auto-body painter friend of mind and taught my students how to spray paint from what I learned (that is to say the manual technique of spraying). It's hard to describe through text, perhaps we'll take a video of it when we go to paint some parts.
  #38   Spotlight this post!
Unread 01-17-2018, 12:34 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Good question... because we had not considered using plastic! The shop that we work in stocks sheet aluminum (0.030in-0.250) so that's our default go-to.
I think we'll try skinning the wheels in polycarbonate as an iteration/weight reduction effort.
I still can't wrap my brain around motor-in-roller designs. Do you have a good rendering or diagram that shows how this black-magic works?
  #39   Spotlight this post!
Unread 01-17-2018, 12:42 PM
EricDrost's Avatar
EricDrost EricDrost is offline
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Here's an image of 558's in 2014 off the TBA blog:
https://blog.thebluealliance.com/201...s-frc558-2014/
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
  #40   Spotlight this post!
Unread 01-17-2018, 12:48 PM
Rookie Year: 2000
Drost more or less has it covered. The big trick is realizing that the tube spins around the motor and then it starts to make a bit more sense. If you think of it as the hex shaft going into a broached plug in the tube then realize you're just moving that mounting point in a bit it seems to work for me.
I'd post a pic of the one I did last year but i'm pretty sure it's EXACTLY the 558 one because I talked to Foss about it and ended up ordering the same tube of MCM. The only issue we had was holding the tube in our band saw to cut it cleanly, the tube wanted to collapse. In the end we just used a hacksaw.
  #41   Spotlight this post!
Unread 01-17-2018, 12:56 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Awesome, thanks guys! That looks like a great packaging option. We will take a look at it.
  #42   Spotlight this post!
Unread 01-17-2018, 05:53 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Power Cube Collecting
We've been working on a narrow-ish intake to avoid any issues in picking up two cubes, but that still had a wide 'target' for the driver to hit. Conflicting requirements, right? Great.
We've got something that works pretty well in a variety of power cube orientations and can pull in a cube even if only 10% or so of the cube is initally engaged.
See:
https://youtu.be/wIDA2-SGc74 and https://youtu.be/TaUXLpf5GmM
We're also pursuing a multi-axle intake design. More refined prototypes are being made tonight, hopefully we'll have some more results tonight.
  #43   Spotlight this post!
Unread 01-17-2018, 11:33 PM
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Rookie Year: 2007
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
Thank you for the spray paint instructions! We're considering also trying to start painting parts of our robot this year.
  #44   Spotlight this post!
Unread 01-18-2018, 06:49 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Our Mk2 roller collector, something a bit more robot-sized, was unsuccessful last night. Power cubes would tip and jam instead of sliding into the collector or tipping and rolling in. We need to figure out what let our Mk1 collector work that isn't present in our Mk2 collector... A setback, but one we can overcome I'm sure.
  #45   Spotlight this post!
Unread 01-18-2018, 07:26 AM
Cog's Avatar
Cog Cog is offline
Predictor and Neatifier
AKA: Cam Ogden
FRC #3324 (The MetroBots)
Team Role: Tactician
Rookie Year: 2010
Cog has a brilliant futureCog has a brilliant futureCog has a brilliant futureCog has a brilliant futureCog has a brilliant futureCog has a brilliant futureCog has a brilliant futureCog has a brilliant futureCog has a brilliant futureCog has a brilliant futureCog has a brilliant future
By robot sized do you mean smaller wheels? Or did you shorten your prototype to account for the 16" maximum extension?
Alliances win matches, not robots.
Unless you're Team Hammond in 2002
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
