OCCRA
Go to Post "FIRST" is not a verb (yet - give us time, and we will see what happens). - dlavery [more]
  #31   Spotlight this post!
Unread 05-01-2018, 07:40 PM
nlknauss's Avatar
nlknauss nlknauss is offline
Clap clap whoosh!
AKA: Nate Knauss
FRC #2729 (LC Storm Robotics Team)
Team Role: Teacher
Rookie Year: 2000
nlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond reputenlknauss has a reputation beyond repute
Re: What COTS parts would you like to see?
Originally Posted by cscottm View Post
A cheaper option for a Ratcheting Gearbox.
I agree. A ratchet and paw combo for a 1/2" hex shaft.
Nate Knauss
FRC 2729 Teacher, Drive Coach
FRC 87 Student 2000-2002 and Mentor 2003-2006, FRC 1647 Mentor 2006-2008, FIRST Senior Mentor 2009-2013
"We can't change the cards we are dealt, just how we play the hand." -Randy Pausch
  #32   Spotlight this post!
Unread 05-01-2018, 07:55 PM
AriMB's Avatar
AriMB AriMB is online now
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Originally Posted by Thrice View Post
Personal I would like to see a wider variety of hex broached gears in both 32 and 20 DP with a pocketed version to lose some weight on the robot. I would also like to see a disc brake that had a hex hub.
Originally Posted by philso View Post
A mount for the calipers with holes that match the VEX VersaFrame hole pattern would be nice too. All the calipers I have seen will not mount nicely on a flat surface.
Originally Posted by kaliken View Post
I think i would think more GT2/3 Pulleys and Belts would be great.
Originally Posted by AustinH View Post
In-line direct 1:1 encoder mounting options for 3/8 and 1/2 hex shaft.
Originally Posted by mman1506 View Post
Encoder stage option for the 57 sport. Don't think I'll ever go back to VPs for anything high reduction/low output speed again. I'd love to see an easy to mount output stage encoder solution like the VPs have. And please for the love of god do not put those tiny molex connectors on it.
+1 to all of these.
Additionally, I'd like to see:
• a redone, more reliable CIMcoder with a better connector.
• heavily pocketed gears (for low load applications like intakes)
• steel 1/2" hex shaft
• aluminum hex tube 1/2"OD 3/8"ID (I know WCP makes an adapter, but they're expensive and only 1/2" long)
• 6/8" colsons with premade hex hubs
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
  #33   Spotlight this post!
Unread 05-01-2018, 08:14 PM
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (IBOTS 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Originally Posted by CEF View Post
A better solution to connecting encoders, switches and analog inputs to Talons. Say, for example, something that took the data cable in one end and had small spring-loaded connectors on the other.
But, heck, I'd be happy for the vendors just not to run out of stock of the stuff that's technically "available" now.
I'm actually working on a board that would be able to mount on the talon (using the 2 screws for the data cover) that would give you either spring loaded connectors or a locking pwm cable style connector for encoders / limit switches
I'm not sure i'll be able to sell them, but I'll make a parts list and pcb files available. If there is enough interest, I may bulk order the boards and sell it as a kit.
  #34   Spotlight this post!
Unread 05-01-2018, 08:15 PM
Mike Marandola's Avatar
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (LUNATECS)
Rookie Year: 2007
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Originally Posted by EricDrost View Post
Those are two very different things for an "or".
We got all of ours from WCP this year. It is easy to get, just not cheap. We will definitely be buying some from 973 later this year and potentially splitting it with local teams.
LUNATECS.org
FRC 316 Student 2007 - 2011
FRC 316 Mentor 2012 - 2017
FRC 316 Lead Technical Mentor 2018 - ?
  #35   Spotlight this post!
mman1506 mman1506 is offline
Reversible bumpers are my trigger
AKA: Marcus Quintilian
FRC #5406 (Celt-X)
Team Role: Mechanical
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
1/2" round shaft stock with a through hole sized for a 1/4-20 tap.
2012-2015: 865 Warp7 Team Captain
2016/17: Free Agent Mentor
2018-present: 5406 Celt-X
  #36   Spotlight this post!
Unread 05-01-2018, 08:18 PM
marshall's Avatar
marshall marshall is offline
Online Stripe & Drape Sales
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Would love some new COTS swerve modules.
Would love a new VRM with a battery backup or a plug for a USB battery pack.
Would also love more brushless motor options and a replacement for the CIM/mini-CIM and maybe some more motors with integrated encoders.
Would love to see a cheaper and smaller Limelight-type camera.
Lastly, I really would love to see 1x1 and 2x2 90 degree brackets for versaframe because cutting stock to those lengths is annoying and I suspect vex could make more money from me by selling them to me.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Clarke's Laws
  #37   Spotlight this post!
Unread 05-01-2018, 08:19 PM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Minnetonka)
Team Role: Leadership
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
1/2" shaft stock with a through hole sized for a 1/4-20 tap.
Here ya go
or this if you want something for lower loads
Marshall knows all the right words
“Courage cannot exist in the absence of fear.”
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Engineering Captain, Driver, Programming Lead
2017-: FTC 13471 (Minnetonka) - Founding Mentor
  #38   Spotlight this post!
Unread 05-01-2018, 08:20 PM
FRC #5406 (Celt-X)
Rookie Year: 2012
A PCM with a switch that would allow you to charge the robot pneumatics without it being enabled.
  #39   Spotlight this post!
Unread 05-01-2018, 08:24 PM
marshall's Avatar
C.R.E.A.M.
Clarke's Laws
  #40   Spotlight this post!
Unread 05-01-2018, 08:31 PM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron) (Also, CD mod.)
217-4238 would like a word with you. (I agree, a simple L would be significantly cheaper and good enough for many applications.)
Please don't go into the bolt standardization thread and tell them to diversify their (mechanical) bonds.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach (oh, and I worked at AndyMark during this time)
2018-: FRC 1293 (Pandamaniacs) - Mentor
113 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
  #41   Spotlight this post!
Unread 05-01-2018, 08:37 PM
Big-b's Avatar
Big-b Big-b is offline
Makes strange design decisions
AKA: Bram
FRC #0900 (♞Zebracorns♞)
Team Role: CAD
Rookie Year: 2016
Big-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond reputeBig-b has a reputation beyond repute
4" colsons with a bearing bore and versahub for dead axle swerve without having to replace versawheels every 2 events.
2018 NC District Forsyth Event Chairman's Award
2017 NC District Championship Winner
2017 NC District Raleigh Event Chairman's Award
"I've found from past experiences that the tighter your plan, the more likely you are to run into something unpredictable." - Angus MacGyver
  #42   Spotlight this post!
Unread 05-01-2018, 08:49 PM
ClayTownR's Avatar
ClayTownR ClayTownR is offline
AKA: Clayton
FRC #0100 (The WildHats)
Team Role: CAD
Rookie Year: 2015
ClayTownR has much to be proud ofClayTownR has much to be proud ofClayTownR has much to be proud ofClayTownR has much to be proud ofClayTownR has much to be proud ofClayTownR has much to be proud ofClayTownR has much to be proud ofClayTownR has much to be proud of
Originally Posted by pchild View Post
I am 100% here for this.
FTC 4800, 2015-2017
FRC 100, 2016-
  #43   Spotlight this post!
Unread 05-01-2018, 09:16 PM
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond reputenuclearnerd has a reputation beyond repute
Vex and WCP came out with a nice set of products this year for driving 1.25" OD tube as rollers. Unfortunately they pretty much all need the tube to be a "live axle" (unless you drive it with polycord or flat belt). I would love to use 1.25" tube more as a stronger dead axle for mechanisms (like our arm) but we are missing one piece:
A hub that pins to 1.25" tube (or another size), which has a 1.875" bolt circle for timing pulleys, plate sprockets and wheels
  #44   Spotlight this post!
Unread 05-01-2018, 10:46 PM
Nbot's Avatar
Nbot Nbot is offline
FRC #4488 (ShockWave)
Team Role: CAD
Rookie Year: 2015
Nbot will become famous soon enoughNbot will become famous soon enough
Hex bore 2" mecanum wheels.
  #45   Spotlight this post!
Unread 05-01-2018, 11:07 PM
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond reputebobbysq has a reputation beyond repute
A CAN based thermal probe for motors might be interesting to see. That could integrate with a Victor SPX (or any other budget CAN motor controllers we might see) so that it could sense when they're overheating and stop them or slow them down.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
