Go to Post Steamworks looks a bit like trying to play football and baseball on the same field simultaneously. - nuclearnerd [more]
  #46   Spotlight this post!
Unread 05-02-2018, 12:00 AM
samthesnake's Avatar
samthesnake samthesnake is offline
SamD4256
AKA: Sam Dare
Team Role: CAD
Rookie Year: 2015
samthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud ofsamthesnake has much to be proud of
Re: What COTS parts would you like to see?
More sizes of 32 DP gears (50t & 70t) and more pocketed gears would be a nice addition. More beveled gear options are very high on my list. Different sized shoulder bolts would be awesome and easy to do. Different sized colsons would be helpful. Also, I would like to see different sizes of versatubing, with 2” x 2” x .100” aluminum coming to mind. Lastly, a cheaper hex broach would really aid the community.
"Perfection is not attainable, but if we chase perfection we can catch excellence." - Vince Lombardi
2015 - 2018 FRC Team 4256, Cyborg Cats
CAD and Strategy lead, drive coach
  #47   Spotlight this post!
Unread 05-02-2018, 12:02 AM
mman1506 mman1506 is online now
Reversible bumpers are my trigger
AKA: Marcus Quintilian
FRC #5406 (Celt-X)
Team Role: Mechanical
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
6" Vex Pro Colsons.
2012-2015: 865 Warp7 Team Captain
2016/17: Free Agent Mentor
2018: 5406 Celt-X
  #48   Spotlight this post!
Unread 05-02-2018, 12:37 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by mman1506 View Post
A PCM with a switch that would allow you to charge the robot pneumatics without it being enabled.
I am certain that such a switch would never be considered legal on a competition robot. If you wanted one on a practice or demo 'bot, you could easily wire it directly to the compressor.
  #49   Spotlight this post!
Unread 05-02-2018, 01:36 AM
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Pivot brackets for pneumatic cylinders with 1" mounting hole spacing. Would line up much better with Versaframe etc.
A bumper bracket solution for the KOP chassis that does not use T-nuts and tolerates small amounts of misalignment. We finally made a good solution this year modifying the kit brackets but it still took us as much time as building our entire arm mechanism since we don't have a press or mill to bang out brackets with. Include it in the KOP if you want to receive chocolates from every RI in FRC.
A VRM and PCM with larger terminal openings.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
  #50   Spotlight this post!
Unread 05-02-2018, 06:15 AM
marshall's Avatar
marshall marshall is offline
Discerning and exacting individual
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
Originally Posted by bobbysq View Post
A CAN based thermal probe for motors might be interesting to see. That could integrate with a Victor SPX (or any other budget CAN motor controllers we might see) so that it could sense when they're overheating and stop them or slow them down.
Canifier with a thermal probe could do this easily enough. You need to write a bit of code to do it but shouldn’t be difficult.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Clarke's Laws
  #51   Spotlight this post!
Unread 05-02-2018, 07:18 AM
Mr. Ackroyd's Avatar
Mr. Ackroyd Mr. Ackroyd is offline
FRC #3044 (OxBe4)
Team Role: Coach
Mr. Ackroyd is on a distinguished road
Originally Posted by fimmel View Post
I'm actually working on a board that would be able to mount on the talon (using the 2 screws for the data cover) that would give you either spring loaded connectors or a locking pwm cable style connector for encoders / limit switches
I'm not sure i'll be able to sell them, but I'll make a parts list and pcb files available. If there is enough interest, I may bulk order the boards and sell it as a kit.
https://frcteam3044.team/team-resources
Take a look at our website and our team resources tab. You may find what you are looking for with the talons. We have been using these for the last two years and order new boards each year (per the rules). The only issue we have had for failures is if the students do not use the two hex bolts to tie down the PCB board. The zip file will take you to the BOM, descriptions and files needed to have these boards produced.
2018 CNY Engineering Inspiration Award NYTVR Team Spirit Award
2017 NYTVR Chairmans Award, Industrial Safety Award, HVR Imagery Award
2016 CMP Tesla division Quaterfinals
2016 Finger Lakes Regional: Finalist on Alliance 3 (4930, 3044, 340) Industrial Design Award, Industrial Safety Award, Wildcard
2016 NYTVR: Quarterfinals on Alliance 8 (4930, 3044, 4481), Team Spirit Award
2015 Finger Lakes Regional Entrepreneurship award
2015 New York Tech Valley Regional FIRST Dean's List Finalist Award
2014 Finger Lakes Regional Industrial Safety Award, Team Spirit Award, Regional Finalists
2014 New York Tech Valley Regional Team Spirit Award
2013 WPI Regional Regional Winners, Team Spirit Award
2012 Finger Lakes Regional Regional Finalists
  #52   Spotlight this post!
Unread 05-02-2018, 09:07 AM
cadandcookies's Avatar
cadandcookies cadandcookies is offline
AKA: Nick Aarestad
FRC #2220 (Blue Twilight) & FTC 9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
A consistent source for 32DP pinions for 500-series motors. Being on back order 11 months of the year doesn’t count.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
grabcad | twitter | github
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16) -> FRC 2220 (18-??)
VEXU UMN (2015-17)
Volunteer since 2011
  #53   Spotlight this post!
Unread 05-02-2018, 09:45 AM
CEF CEF is offline
FRC #5607
CEF has a brilliant futureCEF has a brilliant futureCEF has a brilliant futureCEF has a brilliant futureCEF has a brilliant futureCEF has a brilliant futureCEF has a brilliant futureCEF has a brilliant futureCEF has a brilliant futureCEF has a brilliant futureCEF has a brilliant future
Originally Posted by Mr. Ackroyd View Post
If we ever meet up, I will buy you an adult beverage.
  #54   Spotlight this post!
Unread 05-02-2018, 09:57 AM
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Team Role: Teacher
I'd like to see a return to 1" linear spacing on mounting holes for whatever components come out, and brackets that would translate current products to a 1" spacing.
Also, I'd like to note that the OP had a very interesting first ever post. Welcome to CD!
Hi!
  #55   Spotlight this post!
Unread 05-02-2018, 10:18 AM
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
I'll add my voice to those requesting integrated encoders and other doodads (ratchet, for example) for the AndyMark 57 Sport gearboxes. The reason we chose to run Versas exclusively this year was simply that we could add more functionality to them. I'm glad to hear that the 57s are impressive; I'd like to try them next season.
My team is likely moving away from shifting gearboxes for the drive base due to expense (for two or three robots), weight, space, and simply because the more we think about it, the less it seems necessary to shift in order to play most games at a high level. I really like WCP's SS boxes, and wouldn't mind seeing other companies come out with a competitive product.
http://www.angelbotics.com
Remember why you're doing this.
  #56   Spotlight this post!
Unread 05-02-2018, 10:21 AM
walterminehart's Avatar
walterminehart walterminehart is offline
FRC #2175 (The Fighting Calculators)
Team Role: Driver
Rookie Year: 2016
walterminehart is an unknown quantity at this point
Some sort of plastic extrusion with a hex bore would be nice for making custom hubs quickly. Currently we use McMaster 8705K49, but broaching is annoying and it takes a long time for a simple part.
A three inch option for a compliant wheel would be cool. We used some 2 7/8 banebots this year that ended up being a really convenient size, but they could have done with a little more squishy grip.
+1 for 2'' mecanums with hex bore.
  #57   Spotlight this post!
Unread 05-02-2018, 10:51 AM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron)
I'm curious, what does the WCP SS offer that the EVO Slim doesn't? (I can think of a couple things, but I'm also 200% stirring the pot here.)
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach
2018-: FRC 1293 (Pandamaniacs) - Mentor
113 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
  #58   Spotlight this post!
Unread 05-02-2018, 11:07 AM
maxxman maxxman is offline
Rookie Year: 2013
maxxman has a spectacular aura aboutmaxxman has a spectacular aura about
6" Vex Pro Colsons.
GTA people can just buy them from here and use the dead or live hubs that vexpro already sells.
http://www.colson.ca/contact/toronto.php
We bought them and had them shipped the next day.
There is a place in Cambridge as well if thats a more convenient location for your team.
  #59   Spotlight this post!
Unread 05-02-2018, 11:09 AM
Shahil_FRC's Avatar
Shahil_FRC Shahil_FRC is offline
Mentor
FRC #0176 (Aces High)
Shahil_FRC will become famous soon enough
Biggest thing would be its not WCD compatible out of the box and its heavy running steel gears vs 7075 gears that vex/wcp offers.
  #60   Spotlight this post!
Unread 05-02-2018, 11:12 AM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Minnetonka)
Team Role: Leadership
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
Evo slim for AM14U3, WCP-SS for any WCD due to the option to have sprockets inside the gearbox itself.
My posts constitute my opinions, and mine alone, and are not representative of the views held by my team.
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Engineering Captain, fmr. Programming Lead, 2017&2018 Dean's List Finalist
2017-: FTC 13471 (Minnetonka) - Founding Mentor
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
