Go to Post If we can transform our culture to the point where girls swoon over guys as they pull their dremel off their belt and carve some speed holes in a smooth fluid motion, I think FIRST is half way to its goal. When we get the guys to swoon over the girls for their hot moves on the 5-axis, we have won. - EricVanWyk [more]
Unread 05-08-2018, 06:57 PM
ClayTownR's Avatar
ClayTownR ClayTownR is offline
AKA: Clayton
FRC #0100 (The WildHats)
Team Role: CAD
Rookie Year: 2015
ClayTownR is a name known to allClayTownR is a name known to allClayTownR is a name known to allClayTownR is a name known to allClayTownR is a name known to allClayTownR is a name known to all
What CAD PDM/version control do you use?
I'm curious as to what software you all use to manage and collaborate with CAD. The common tools I've heard of are GrabCAD and Apache Subversion, and with Solidworks particularly in mind there's Workgroup PDM (which is being phased out now) and their newer PDM software.
We used Workgroup PDM for a while - first on a server hidden behind a teacher's whiteboard, then on an AWS server. We took it down when it had been hacked - we didn't care too much about someone else seeing our files, but we did care when we got the bill and found out a Bitcoin miner had been installed. This year we moved to GrabCAD, which I mostly liked for web browser support, but it felt weaker to me and it was much easier to overwrite large amounts of work if you weren't careful, especially compared to Workgroup's ownership scheme.
FTC 4800, 2015-
FRC 100, 2016-
Unread 05-08-2018, 07:00 PM
PrathikM's Avatar
PrathikM PrathikM is offline
Engineering Captain
FRC #0226 (Hammerheads)
Rookie Year: 2017
PrathikM will become famous soon enoughPrathikM will become famous soon enough
Re: What CAD PDM/version control do you use?
I'd highly recommend the GrabCAD desktop app, it syncs to a folder on your computer and makes it extremely easy to upload/manage versions.
Team 226 (2017-Present)
2018-2019 Engineering Captain
2017-2018 CAD/Strategy Lead
2018 Backup Driver, Chairman's Presenter, EI Presenter
Fantasy FIRST : Hammmerheads
Unread 05-08-2018, 07:24 PM
johncooper johncooper is offline
FRC #6072 (Triton Tech Robotics)
Rookie Year: 2016
johncooper is an unknown quantity at this point
We used GrabCad. We had some "strange" behavior, which was likely students overwriting each others files inadvertently. Is there a way to check out files in GrabCad? FYI, I suspect our issue arose in the following way.
Student A is working on the Chassis. They open the top level robot assembly, which they will use to determine whether their chassis changes cause issues in the top level robot assembly. They open the chassis sub assembly and modify the chassis. They save their changes to the chassis and go to close SolidWorks. SolidWorks asks, do you want to save changes to the top level robot and they click yes. They subsequently synch GrabCad.
Student B is working on the elevator sub assembly, which is already place in the top level robot design. Student B changes the elevator design, saves and synchs GrabCad. Chronologically this occurs before Student A synchs.
When Student B returns, to work on the elevator, their work is "lost".
Any recommendations on how to avoid this issue beyond, "don't save the top level assembly."
Unread 05-08-2018, 07:30 PM
pchild's Avatar
pchild pchild is offline
Must be a location thing
AKA: Preston
FRC #0401 (Copperhead Robotics)
pchild has a reputation beyond reputepchild has a reputation beyond reputepchild has a reputation beyond reputepchild has a reputation beyond reputepchild has a reputation beyond reputepchild has a reputation beyond reputepchild has a reputation beyond reputepchild has a reputation beyond reputepchild has a reputation beyond reputepchild has a reputation beyond reputepchild has a reputation beyond repute
We're an Inventor team, but we use GrabCAD. We've started having students 'Lock' assembly and part files when they're working on them to ensure that there are no conflicts.
We also teach the students to only upload files that they've actually worked on, Inventor seems prone to want to save updates to parts and assemblies that weren't really edited.
Unread 05-08-2018, 07:32 PM
ClayTownR's Avatar
AKA: Clayton
Team Role: CAD
Rookie Year: 2015
Originally Posted by johncooper View Post
(snip)
If you browse through files through the browser (not the desktop application) there's a little lock icon - if you do that, the part or assembly will not be overwritten by anyone except you on check-in. However, any user can still override it, and a user can unknowingly get work done on a locked part and realize they've been wasting their time.
FTC 4800, 2015-
FRC 100, 2016-
Unread 05-08-2018, 07:53 PM
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant futurePeter Johnson has a brilliant future
In Solidworks, there's an option to open files read only by default. You have to also enable the option for workgroup/PDM menu items to get the File | Get Write Access menu option. This works quite nicely for minimizing accidental overwrites / false "new versions" that GrabCAD will pick up as changes.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 05-08-2018, 09:20 PM
Brian M's Avatar
Brian M Brian M is offline
Design Lead
FRC #1360 (Orbit Robotics)
Team Role: CAD
Brian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond reputeBrian M has a reputation beyond repute
Ive used GrabCad for every project in Solidworks ive ever done. It has no down sides, just communicate with your team properly. Tell people what you are working on, and dont upload what you didnt change.
I dont think any other program has the community GrabCad does and the online support is great for version control and viewing who updated what.
2016 - Rah Cha Cha Ruckus Winners (3015 & 4039)
2017 - Industrial Design (Durham), Entrepreneurship (McMaster), Quality Award (Ontario DCMPS)
2018 - Georgian District Winner (1305 & 6864), York District Winner (1325 & 6140), York District Chairmans Award, Georgian Innovation in Control
Unread 05-08-2018, 09:24 PM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is offline
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Minnetonka)
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
GrabCAD. We use Inventor and don't have the issues with top level assemblies that Solidworks users seem to be having.
My posts constitute my opinions, and mine alone, and are not representative of the views held by my team.
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Captain (2+ yrs), Programming Lead (3+ yrs), Driver (2+ yrs), Operator (1 yr), 2017&2018 Dean's List Finalist
2017-: FTC 13471 (Minnetonka/Tater Bot Hot Dish) - Founding Mentor
2017-: FIRST Volunteer - 2017 North Champs Student Ambassador
Unread 05-08-2018, 09:44 PM
sanddrag sanddrag is offline
On to my 17th year in FRC
FRC #0696 (Circuit Breakers)
Autodesk Vault Basic with Inventor. It works very well.
Unread 05-08-2018, 11:14 PM
soundfx's Avatar
soundfx soundfx is offline
AKA: Aaron J
FRC #3238 (Cyborg Ferrets)
soundfx will become famous soon enough
Our team has been using Fusion 360, and all of its built-in version control. Overall, it's worked really well for us. If you don't mind using Fusion 360, it's a great system to use, though it's not useful for much else.
Some pros:
  • Version control is entirely integrated with Fusion 360
  • Web interface allows viewing and easily sharing files
  • Supports comments on designs, both through the web and the program
  • Easy to branch off and test new ideas
  • Version control and online backups are automatically created with every project
Some cons:
  • False new versions are common
  • Having more than one admin (to add and approve new users) requires a paid account
  • Glitches are not uncommon when multiple people work on one file. One of our files got stuck in a perpetual state of "In use by -----", so no one could work on that file. I think we were able to just copy the file, so it turned out fine.
  • Sometimes it is hard to delete parts if they are referenced in an old version of a different design
"I got 99 problems but 0.999 ain't 1."
~Orteil
Unread 05-08-2018, 11:16 PM
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics, #all27everything, Team FUN)
Skyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond reputeSkyehawk has a reputation beyond repute
Version control: The longer the file name the newer the file, 'nuff said.*
*Please don't do this
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
  • A small mountain of hardware, good memories & life lessons with 876: 2011 - 2018
  • Inevitable good times upcoming with an #all27everything team : 2018 - ????
Unread 05-09-2018, 07:23 AM
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
TL;DR GrabCAD is the way to go for FRC use cases.
There are lots of options out there to choose from; however, there are only so many free / donated options.
Each CAD company has their own:
  • SolidWorks --> SolidWorks PDM
  • Inventor --> Autodesk Vault
  • Creo --> PTC Windchill
  • Onshape --> [Native to Onshape]
Of these, SolidWorks PDM and Autodesk Vault both require their own servers to be setup and maintained by the end user (FRC team). We ran into port accessibility issues when we were part of the school system and trying to use SolidWorks PDM, but others use it successfully.
PTC Windchill is cloud based and they maintain your files for you. As someone who uses Windchill at work, it is a powerful software tool, but can be very difficult to learn. I haven't used Onshape enough to really comment, but it is entirely cloud based. They also advertise as their own revision control software is built in native to their file structure. The people over at 319 would be good to reach out to...
Other 3rd party options:
  • GrabCAD Workbench - Free, lightweight, easy to learn, easy to use
  • SVN - No comments as never attempted to use; I think 971 uses it if you have questions
  • Dropbox - Essentially a cloud based share drive; limited version control abilities
  • Google Drive - similar to Dropbox
  • Other misc cloud based share drives (Box, Microsoft OneDrive, Amazon Drive, etc)
Of these, SVN requires the end user to setup and maintain their own server. Cloud based share drives (Dropbox, Google Drive, etc...) are not designed for the CAD workflow, and to some degree the level of collaboration that goes into designing a robot. It can be done though. We started off with a master external hard drive - do not recommend. I have seen teams use Dropbox, and equivalent, pretty efficiently when paired with a shared spreadsheet (primarily Google Sheet) as the live logbook for files. We adopted GrabCAD in the 2016 season, and we had very little training or working knowledge of the tool; but it worked really well for us. I was 3000 miles away for most of build season and could quickly view and provide feedback without having to open SolidWorks. All you need is an internet connection and the web client renders the files in the browser. GrabCAD also has a desktop app that can integrate with SolidWorks - this is what makes GrabCAD stand out relative to the other 3rd party options. Users can lock files they are working on so others can't make changes.* Anyone on the team can view the design, without the need for a massive software install or knowing their way around a CAD software. The interface is pretty easy to learn and understand. You can set revision schemes, and roll back to any uploaded version of the file at any time. The shared library feature is also very useful and quite easy to setup.
All options have their respective pros and cons, but IMO GrabCAD is the best bang for the buck** for FRC teams.
*A locked file can be unlocked by anyone, but they have to intentionally unlock the file. A notification is sent to the user that had the file locked. This is actually a nice tool incase someone has to miss time (sick, school, work, etc.).
**Not just talking about money; referring to other resources: learning curve, user interface, setup/maintenance, etc.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 05-09-2018, 10:11 AM
RickyRobot RickyRobot is offline
AKA: Ricky Marcus
FRC #1745 (The P-51 Mustangs)
RickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud ofRickyRobot has much to be proud of
I believe that Onshape is the perfect CAD/PDM solution for FIRST programs. There is only one reason I can think of that would prevent a team from switching: inertia. Don't hold your team back because you don't want to put in a small amount of time to get familiar with a different CAD software.
Pros of Onshape:
  • Browser based - No software installation so works on PC/Mac/Linux/Chromebook/Smart Phones.
  • Version Control built in - No need to upload/download files. It's mindless.
  • Automatic save - need I say more?
  • File change history is available from the beginning of your project. You can also see who made any particular change.
  • Version branching is available - but this would take some time to get used to and doesn't work particularly well in any CAD/PDM software.
  • Doesn't crash - well it crashes but it's happening on a back-end server somewhere and doesn't affect you.
  • Education edition doesn't cost anything for FIRST teams. Functionally, it matches their 'Standard' paid software. Team members can be added to your 'Team'. Files can be shared with the Team or kept privately. Any number of admins are allowed.
  • Seamless collaboration. Onshape will show you who is in the document and exactly what they are working on. You can even watch them as they work (kind of like a window share but you don't need their permission).
  • Standard features. Onshape has recently added standard screws, washers, and nuts. These can be added to your assembly just like inserting any other part. It can even detect which size screw you need based on the hole size and can automatically populate a bunch of holes at the same time if you let it.
  • Public CAD Libraries. 1836, Milkenknights, has the best public FRC CAD Library right now. Just search for MKCad when inserting parts into your assembly. They are very approachable, if something that you need is missing or not working, just ask them nicely! marcusbernstein maintains it for the most part.
  • Featurescript. Do something regularly in CAD. Just write some code and automate it! I have released a couple of scripts that allow you to create common FRC extrusions. These are publicly available, just search 1745 when adding a custom feature in a Part Studio.
Cons:
  • CAM isn't as integrated as Fusion. There are 3rd party apps for this that I haven't used, so I won't comment on them. Many teams export STEP files and bring them into a separate CAM software package, so it probably won't impact your workflow anyways.
  • Missing X feature. If there is some feature you feel is missing, just put in an improvement request and get everyone you know to upvote it. Onshape is constantly updating their software. New releases are typically every 3 weeks. The releases are automatic, so there is nothing you need to do to get your projects updated. No costs or new installations.
Onshape allows you to focus on the design since they take care of all the back-end challenging parts of team-based CAD. GrabCAD works well, we used it with SolidWorks before switching to Onshape, but it still requires each team member to go through certain steps before and after they want to work on the CAD model. Get a new computer? You need to install CAD software, deal with licensing associated with that, manually configure the software so it's setup how you like it, install GrabCAD, and wait for all your files to download. Onshape is just a single login per user.
It bears repeating. Many things teams struggle with are mindless in Onshape. I can be working on the document on my work computer. Leave for the day without even logging out and pick right back up at home or the high school on a completely different computer. Nothing gets lost or overwritten. If someone makes a change you don't like, it is trivial to back out of it.
If the last time you tried out Onshape was a year ago, please give it another chance.
Mechanical Engineering Mentor for FRC 1745 and FTC 13140/13141/13142
Unread 05-09-2018, 10:23 AM
tim-tim's Avatar
AKA: Tim Miedzinski
Originally Posted by RickyRobot View Post
I believe that Onshape is the perfect CAD/PDM solution for FIRST programs. There is only one reason I can think of that would prevent a team from switching: inertia. Don't hold your team back because you don't want to put in a small amount of time to get familiar with a different CAD software...
I have two other drawbacks to Onshape:
1) Have to have internet access to use. That's a deal breaker for me in certain scenarios.
2) It's not used in our local industry, I don't see this changing anytime soon with all the IT and IA concerns.
I do plan to test drive Onshape this summer to enable me to make better decisions.
The RoboBees
Unread 05-09-2018, 10:46 AM
AKA: Ricky Marcus
1) Didn't think of this. Definitely a deal breaker if you don't have reliable access to internet. This hasn't been an issue for my team or myself.
2) I don't really buy this argument, and I hear it a lot as I work in academia. It is my opinion that once you know one CAD software, you can pretty easily pick up most others. I don't think anyone would have trouble using SolidWorks, Inventor, SolidEdge, or Onshape if they've used another one in that list. Creo, CATIA, NX, etc are on another level, but it still shouldn't be too overwhelming to learn those either. No one will ever know what company they will work for when they are in high school or middle school. Most likely they will work for many companies over the course of their career and those companies will use different CAD software. It is pretty likely that the CAD we use in 5, 10, or 25 years will be different from what we are doing today, and I will hazard a guess that it will move more in the direction of what Onshape is doing with browser based CAD with integrated collaboration and document control. The most important thing we can teach the students is to learn how to learn and how to creatively solve problems. CAD is just a tool, design is a discipline.
For anyone, please feel free to reach out to me directly if you want to discuss moving to Onshape.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
