Go to Post The only way you can be undermined is if you let yourself be undermined. - DUCKIE [more]
Unread 01-17-2018, 09:02 PM
cclee cclee is offline
FRC #2450 (RaiderBots)
Team Role: Webmaster
Rookie Year: 2017
cclee is an unknown quantity at this point
Motor climber issues
Our team was having troubles with making a climber out of a CIM motor. We were trying to climb up roughly 7 feet in 15 second with our bot being around 120lb we found that doing it is really difficult. It appears that we are far from having enough power with a 5:1 reduction. Has anyone found a good gearbox or other solution to this?
Unread 01-17-2018, 09:09 PM
SPang SPang is offline
Stephen Pang
FRC #3146 (Granby GRUNTS)
SPang has a reputation beyond reputeSPang has a reputation beyond reputeSPang has a reputation beyond reputeSPang has a reputation beyond reputeSPang has a reputation beyond reputeSPang has a reputation beyond reputeSPang has a reputation beyond reputeSPang has a reputation beyond reputeSPang has a reputation beyond reputeSPang has a reputation beyond reputeSPang has a reputation beyond repute
Re: Motor climber issues
First, your gearing is nowhere near what you need. Use JVN’s design calculator (https://www.chiefdelphi.com/media/papers/3188) and select “Linear Mechanism” and play around with the gearing and see the current draw and lift times that you desire.
Select a proper gearbox like a VersaPlanetary (https://www.vexrobotics.com/versaplanetary.html) or the new Andymark Sport (http://www.andymark.com/CIM-Sport-p/am-cimsport.htm). When climbing you need a very high reduction in order to achieve the torque to lift a 120 lb robot. Keep in mind that a robot at the weight limit also has bumpers and a battery, so you’ll actually be lifting 154 lbs if you’re at the limit. Also, make sure to protect your gearbox by adding a chain and sprocket or gear reduction so it doesn’t experience issues in season.
ÜberBots (FRC 1124) | 2014 - 2017 | Student
Granby GRUNTS (FRC 3146) | 2018 - ???? | College Student
NE FIRST Volunteer | 2016 - ????
Unread 01-17-2018, 09:25 PM
Landon K's Avatar
Landon K Landon K is offline
FRC #6090
Rookie Year: 2016
Landon K is on a distinguished road
If I were using a cascade elevator with a winch, could I use this same linear tab with the correct pulley diameter of the winch to find the correct gearing and respective climb/lift time?
Unread 01-17-2018, 09:30 PM
Stephen Pang
Yup!
Unread 01-17-2018, 09:35 PM
pkrishna3082's Avatar
pkrishna3082 pkrishna3082 is online now
love/hate relationship with swerve
AKA: Parthiv Krishna
FRC #3082 (Chicken Bot Pie) and FTC #13471 Mentor (Minnetonka)
Rookie Year: 2016
pkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond reputepkrishna3082 has a reputation beyond repute
Also, note that you can get away with climbing much less than seven feet to meet the requirements. Just a thought.
My posts constitute my opinions, and mine alone, and are not representative of the views held by my team.
2010-2011: FLL 11083, 13873 (Minnetonka Silver) - Programmer
2016-: FRC 3082 (Chicken Bot Pie) - Captain (2+ yrs), Programming Lead (3+ yrs), Driver (2+ yrs), Operator (1 yr), 2017 Dean's List Finalist
2017-: FTC 13471 (Minnetonka/Tater Bot Hot Dish) - Mentor
2017-: FIRST Volunteer - 2017 North Champs Student Ambassador
Unread 01-17-2018, 10:46 PM
the programmer's Avatar
the programmer the programmer is offline
AKA: Erik Orlowski
FRC #2830 (Riverside Robotigers)
the programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud of
As you're doing that, the spreadsheet doesn't just tell you how fast you will climb but how much current the motor will draw. This is important because the biggest circuit breaker you can use for an individual circuit breaker is 40 amps. If you go over 40 amps for long enough, the circuit breaker will trip and your robot will fall to the ground. Our team is designing for the motors to draw around 20-30 amps as insurance for unplanned mechanical inefficiencies (which NEVER happen on FRC robots).
In addition to the 40 amps for each individual motor, consider the 120 amp main breaker as well. If the sum of all your branch currents (current per motor * number of motors) exceeds 120 amps for long enough, not only will your robot fall down but it will turn off for the rest of the match.
Some great information about this is available from VEX here: http://motors.vex.com/introduction.
2006-2008: FLL Student
2009-2014: C.O.R.E. 2062
2010-?: FLL Referee
2016-?: FTC Referee
2015-?: Riverside Robotigers 2830
Unread 01-17-2018, 11:28 PM
Billfred's Avatar
Billfred Billfred is offline
Eat, Sleep, Break The Streak
AKA: Less Curt Hawkins, More a Paul Heyman Guy
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron)
To throw the counter-point, at the risk of derailing the thread: if a team's goal is to make it easy for other robots to fit underneath, or to be able to Tarzan their way up with another robot also on the rung, that much travel is probably a good look.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach
2018-: FRC 1293 (Pandamaniacs) - Mentor
108 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 71,000 miles, and still on a mission from Bob.
Unread 01-18-2018, 08:44 AM
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Tarzan ... please, no.
*** Has visions of a 3 robot newton's cradle ***
- Tennyson, Ulysses
Unread 01-18-2018, 10:12 AM
Billfred's Avatar
My gut says Tarzan-ing will be limited to two robots, part for time constraints and partly because Levitate exists. The ability to hook, spool out to get clear of another robot, and coordinate a 2-up climb feels about as plausible as it's gonna get for multiple robots on the rung.
Unread 01-18-2018, 10:17 AM
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
To give you a better starting point... last year my team climbed with a CIM through a 20:1 reduction on a 1" spool, and it was certainly quick enough, under 5 seconds to get up to the trigger on the airship.
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016-2018; Galileo 2016; Iowa 2017; Tesla 2017; Northern Lights 2018
2016: Lake Superior WFFA
Unread 01-18-2018, 10:29 AM
Billfred's Avatar
An additional data point: 5402 used a Mini CIM through a GEM at 49.4:1, followed by a 12:15 chain reduction (so, 61.75:1 overall) on a 1.5" pulley. That was needlessly conservative and took us about five seconds once hooked. We had a lot of retrofitting to do at our second district event on the gear system, but had we made it to district championships the plans were already in place to jettison one stage from the GEM (making it 13.5:1, 16.88:1 overall) and switch to a CIM motor. That would've pulled closer to 46A for the 2-second climb, which is playing with fire a little but to rein it back in would take a lot more re-engineering.
Unread 01-18-2018, 10:33 AM
Mad Scientist
AKA: Me
FRC #2040 (DERT)
another datapoint.
we used a CIM with a 12:1 planetary and a 3.5:1 chain and sprocket (total 42:1) on a 2" spool.
- Tennyson, Ulysses
Unread 01-18-2018, 11:28 AM
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich will become famous soon enoughamesmich will become famous soon enough
And another, we used one cim on a banebot 64:1 gearbox with a ~4 inch drum, and climbed in about 4 sec.
Unread 01-18-2018, 11:36 AM
Type's Avatar
Type Type is offline
AKA: AJ
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to beholdType is a splendid one to behold
When gearing your climber, give yourself some lead room with the amperage. We designed ours right on the edge last year so we could climb quick but resulted with our first event being a joke. Our climber woukd get half way up and it would start tripping breakers. It was a combination of us using a bad rope and no enough gearing. In qualifications, we missed 9 climbs, and looking back we probably would've been in the top 8, but ended up in 34th.
3452- Lead Builder/ Pit Boss
*My posts do not reflect the opinion of my team*
Unread 01-18-2018, 08:37 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
One more data point: last year we climbed with one CIM and a 1/2" hex shaft as a "drum" quite rapidly (<4sec), using nylon webbing which wrapped upon itself quite neatly. We weighed less than 100#, with batteries and bumpers. This year, if we're anticipating pulling up another robot, we'll likely add a second CIM to keep the time quick to allow time for ramp-climbing and/or hook-engaging. If just one robot, probably one CIM. As only a 12" climb is required this year, we might possibly use only one CIM for two robots if our climb says fairly level.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
