Go to Post WE might have a different plan than being overweight, but thats just my guess - pakrat [more]
Unread 11-14-2017, 08:39 AM
AriMB's Avatar
AriMB AriMB is online now
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
pic: 2-Speed Flipped CIM Gearbox
Unread 11-14-2017, 08:53 AM
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #3739 (Oakbotics)
cad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud ofcad321 has much to be proud of
Re: pic: 2-Speed Flipped CIM Gearbox
I really like the design of this; it's unfortunate you couldn't keep it down to 2 stages, but in return for the packaging , it all works out. A few questions.
One, what size wheel is this designed to be run with?
Two, is that gear ratio adjusted or free speed.
And finally, why a dog shifter over ball shifter (note i'd be asking the other way around if you had chosen ball shifter, just curious)?
Unread 11-14-2017, 08:56 AM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Without seeing this on a chassis with bumpers it's really hard to tell, but my initial concern is how far that cylinder protrudes past the wheel.
I feel like a better option would be to connect the cylinder using some sort of armature and mounting the cylinder inside the gearbox, pushing out. Alternatively, it also looks like you could also reverse some of the gear orientations and mount the cylinder on the inside of the frame.
True you would protrude into the frame area more with the later of those two options, but it looks like in the current configuration your bumpers would have to extend out to protect the cylinder anyways, so you'd either have a large wasted space past the wheels or a small wasted space inside the frame.
I suppose I might just be stuck in the "old school" line of thinking from back before bumpers were a thing and no one dared to extend anything fragile (and in this case, important) past the frame perimeter, so take the above critique with a grain of salt.
2005-2008: FRC 703 Phoenix - Robot Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 11-14-2017, 09:07 AM
AriMB's Avatar
FRC #5987 (Galaxia)
It's designed to use a 4" wheel. That is the adjusted gear ratio, though I'm not so set on that final ratio. It's super easy to change the final ratio by changing the 3rd gear set. Dog shifter because it packaged better in this application (all 3 gears between the bearings instead of just the shifter gears between and the third cantilevered).
According to the CAD model, the back of the pancake cylinder is ~0.03" inside of the end of the colson retaining screw, so the bumpers shouldn't need to move out substantially. To achieve that, I had to substitute the spacers that come with the hardware kit with custom spacers, and use a custom shifting shaft. I know it's still close, but the bumper should help protect it, and I really wanted to keep the cylinder on the outside for space reasons (that was kind of the main requirement for designing this).
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FRC 5987 Technical Mentor
2017-present: FIRST Israel CSA/FTAA
2012-2016: FRC 423 Member Captian, Programmer (LabVIEW), Electrical, CAD, Manipulator, Chassis, Business, Outreach (everything)
Unread 11-15-2017, 07:29 AM
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Did you fillet the corners of the plates? Those renders look REALLY good.
Unread 11-15-2017, 07:42 AM
AriMB's Avatar
FRC #5987 (Galaxia)
Thanks! Right before I started rendering I put a 0.5mm chamfer on basically every edge of the custom aluminum parts. I found that helps reflect the light to define the edges in the renders so you can see where one part ends and the other begins even when they’re mated coincident with the same appearance. Each of the renders (except for the gif) took less than 20 mins on my laptop.
Unread 11-15-2017, 07:49 AM
Registered Muser
I'll have to remember that, thanks.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
