OCCRA
Go to Post Many of us are engineers who value precision and accuracy in communication. Words mean things. - Alan Anderson [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
CD-Media
Unread 02-14-2017, 09:24 AM
7keleher's Avatar
7keleher 7keleher is offline
AKA: Connor
FRC #0706 (Cyberhawks)
7keleher is an unknown quantity at this point
Electrical Noise on CAN BUS
Hi-
For this year's wiring on our bot, we are using Talon SRXs with CAN BUS. They are all right next to each other on the robot and there is a lot of excessive wiring. As of now, it is simply bundled up and zip tied together along with the 12V power wires right next to it. Will the constant change in voltage in the power wires induce a charge in the CAN BUS wires creating interfereance and electrical noise?
Thanks
Unread 02-14-2017, 09:30 AM
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Electrical Noise on CAN BUS
Originally Posted by 7keleher View Post
Hi-
Thanks
CANbus is differential signals.
As long as you use twisted pair for wiring, the CAN signals should not be affected by external interference and noise.
- Tennyson, Ulysses
Unread 02-14-2017, 09:36 AM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
AKA: The Bearded ONe
FRC #2974 (WALT)
The short answer is maybe. It is bad practice to put communication wiring next to power wiring. Especially something with rapidly fluctuating voltages like PWM motor controllers. (Talons are PWM output) Worst case is to loop wiring and lay it parallel to the power wires. General recommendation is to cross power wiring at 90 degrees ant to keep as much separation as possible. Of course if you follows all the rules for digital data busses, then is practically impossible to connect them to the equipment they are supposed to control.
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
