Go to Post A thread already exists (and boy, does it exist!) on the topic: - Billfred [more]
Unread 07-11-2017, 09:18 AM
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
pic: Over the rail delrin gearbox
Unread 07-11-2017, 09:21 AM
marcusbernstein's Avatar
marcusbernstein marcusbernstein is offline
Baseball hat kid
AKA: Marcus Bernstein
FRC #1836 (Milkenknights)
Team Role: Team Spirit / Cheering
Rookie Year: 2013
marcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond reputemarcusbernstein has a reputation beyond repute
Re: pic: Over the rail delrin gearbox
Looks like a cool way to save space! What is the stuff between your two red plates? Why use it over just spacers? What are the yellow things poking from your outer red plate?
Overall, Great gearbox!
Here are some quotes that drive me and my team to be successful: (some are mine, some are borrowed, and the list will continue to grow)
"Once you've concluded that it isn't a code problem, it isn't an electrical problem, and it isn't a mechanical problem, after all that blaming you now have a culture problem."
"Precedence is no excuse for being wrong."
"Aesthetics are great, but not at the expense of functionality."
"An entire team rallied around a potentially wrong decision is better than half a team rallied around the right one. And if that potentially wrong decision ends up being the right one, that unified team will be successful."
My views do not necessarily represent the views of my team or any other groups I am affiliated with.
Unread 07-11-2017, 09:25 AM
Chris is me's Avatar
\_(ツ)_/
AKA: Pinecone
FRC #3929 (Atomic Dragons); fmr. FRC #228 (GUS) & FRC #2791 (Shaker)
My educated guesses:
1. 1/2" square aluminum tubing, makes for an easy spacer
2. 10-32 push to connect air fittings, for cooling motors between matches.
Mentor: 3929 (2018-?)
Mentor / Drive Coach: 228 (2016-2017) - 2016 RIDE Winner (with 1058, 6153)
Consultant Person: 2170 (2017)
College Mentor: 2791 (2010-2015) Build Photos - 2013 WPI Regional Finalists (with 20, 3182), 2012 BAE Finalists (with 1519, 885)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
Unread 07-11-2017, 09:27 AM
Flywheel Police
1. Yes, and also adds stiffness since the plates are delrin.
2. Or during the match
Unread 07-11-2017, 09:34 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Based on the McMaster part numbers, it's pneumatic fittings that attach to a hollow screw. Teams have used these in the past to provide airflow through the CIM casings to try and cool them from the inside.
EDIT: got sniped pretty bad
Studying MechE at the Technion - Israel Institute of Technology
2017-present: Technical Mentor FRC 5987
2017-present: CSA for FIRST Israel
2012-2016: Member FRC 423 Captian, Programmer (LabVIEW), Electrical, CAD, Manipulator, Chassis, Business, Outreach (everything)
Unread 07-11-2017, 02:43 PM
FrisbeeFunTime's Avatar
FrisbeeFunTime FrisbeeFunTime is offline
AKA: Erik Yngstrom
FRC #1768
Team Role: Mechanical
Rookie Year: 2015
FrisbeeFunTime will become famous soon enoughFrisbeeFunTime will become famous soon enough
Looks pretty cool! Once concern though, have you taken into consideration the tolerances of the aluminum extrusion?
Unread 07-11-2017, 04:02 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Mentor
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Looks neat! I get 6.83:1 as the total gear ratio, which makes sense for a 3 mini-cim gearbox. Further, there's easy variation up or down by changing the two gears in the second stage.
A few more questions:
  • Why is there an extrusion spacer at the top but not the bottom? Is there any reason the bolts on those spacers aren't more evenly spaced around the gearbox? (They're much closer together at the corners)
  • Why is the bull gear (output gear) lightened when the cluster gear is solid? The forces/torques of the two gears are only 14% different, and it's the bull gear which is likely to be taking the shock loads.
Unread 07-11-2017, 04:06 PM
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is offline
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
That's VEXpro's VersaKey geometry. Some gears only come with VersaKey.
Unread 07-11-2017, 04:43 PM
Flywheel Police
  • The bottom of the gearbox will be flush against the drive rail (we run chain in tube) which will provide the flex support that the other extrusion spacers provide. The holes are much closer on the bottom because those bolts are what will be used to mount the gearbox directly to the tube.
  • What Ty said.
Unread 07-12-2017, 08:59 AM
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
Team Role: Leadership
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Hey Matt,
Looked over your design last night and it's really cool! We've been trying to find a way to "fine tune" a single speed and this is a great solution (and some ideas we may adopt into our own potential design). With all the gears available from VEX these days, there are so many gear set options that add up to 90 (or some other number). Everything I saw made sense except for two things:
1. what holes are you using for mounting to the tube? I see 4 different hole patterns: 1) the clearance holes for 10-32 on the outsides, 2) clearance holes for a 1/4" bolt, 3) tapped holes for 10-32 with a 1.875" c-c distance (looks like it could mate up with a WCP bearing block), and 4) the four-hole pattern around the output bearing.
2. the 0.100" holes on the diagonal around all the bearing and motor holes.
Also, any plans on installing an encoder onto the output shaft backside (inboard side)?
FRC78: 2010-Present
FRC121: 2002-2009
Unread 07-12-2017, 09:06 AM
Flywheel Police
Originally Posted by TD78 View Post
Hey Matt,
1. We plan on using the outside 10-32 clearance holes for mounting. The 1/4" holes are our current mounting pattern for the 2 cim ball shifter that I had modelled into it early. The other pattern is for mounting directly to a versa block if the need was there.
2. The small holes around the motors and the first stage bearing are there for optional encoder mounts. The plan would be to pick a location and drill those holes out to the correct size to tap and mount.
Unread 07-13-2017, 09:44 PM
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
Cynicism isn't wisdom
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Unread 07-13-2017, 10:23 PM
ToddF's Avatar
ToddF ToddF is online now
mechanical engineer
AKA: Todd Ferrante
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Easily adjustable 2nd stage gear ratio.
https://scontent-iad3-1.xx.fbcdn.net...43&oe=59FC73AD
Motors roughly even with outside of wheels.
https://scontent-iad3-1.xx.fbcdn.net...56&oe=59FE15A4
Three mini CIMS grouped over 4" colson wheel.
https://scontent-iad3-1.xx.fbcdn.net...32&oe=59C984D0
Vastly expanded interior space for electronics and mechanisms.
https://scontent-iad3-1.xx.fbcdn.net...01&oe=59FACE0C
Video of first powered testing.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 07-13-2017, 10:43 PM
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
That's pretty nifty.
Regarding the air fittings to the motors: It looks like there is just a spot for air to enter, where does it exit? Also, has anyone used a cooling system like this and recorded motor temperature over time to see how well it works?
Are there belts or chains inside of the tube? If belts, do you have the ability to accurately machine bearing holes in the tube for the front/back wheels and get rid of the versablocks?
  #15   Spotlight this post!
Unread 07-13-2017, 10:54 PM
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Rookie Year: 2011
The two mounting fasteners for the motors have through holes down the center. One has an air fitting inline. That's the inlet. The other is a drilled socket head cap screw. That's the outlet.
Inside the tube are chains. We developed a fixed center to center chain drive a few years ago, and worked with a sponsor to have the rails CNC machined. Unfortunately, this year our sponsor has said they would be able to continue supporting the team. Our top priority this summer is to develop a new drive train design, or find another sponsor to machine the drive rails. We're experimenting with the versa blocks after hearing good reports back from teams we're friendly with using them. With them, we think we can make our own drive rails in house without relying on sponsors.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
