Go to Post try to be careful and follow good safe practices. - meaubry [more]
Unread 09-10-2017, 06:32 AM
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily is a jewel in the roughcpapplefamily is a jewel in the roughcpapplefamily is a jewel in the rough
Steamworks gear parameters
Has anyone identified or published the gear tooth parameters for the game piece? We wish to use a online gear generator to create a gear with more teeth and if the gear has a real world profile I would just use them vs making something look correct. Even if our project is mostly cosmetic.
Unread 09-10-2017, 08:09 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Mentor
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Steamworks gear parameters
This is all I've seen in text form:
Originally Posted by 2017 Game Manual
3.12.2 GEARS
A GEAR is a toothed wheel used to start ROTORS on the AIRSHIP. Each GEAR is made from gold (Pantone PMC 124C) polypropylene, has 10 teeth, an 11 in. (~28 cm) diameter, 10 in. (~25 cm) pitch diameter, and is 2 in. (~5 cm) thick. Each GEAR weighs 18.4 oz. (~0.5 kg.) GEARS may be purchased from AndyMark (am-3302).
There's also the CAD File and PDF drawing on the AndyMark site.
Unread 09-10-2017, 11:05 AM
Rookie Year: 2015
I seen the PDF for the basic layout. We are looking for the details to model a larger 15 tooth gear to properly mesh with the game piece.
Unread 09-10-2017, 05:09 PM
DonRotolo's Avatar
Standing on their shoulders
FRC #0832
Best of luck finding the details.
If that fails, you only need to model a single tooth-space pair, and distribute 15 of them around a circle. Since those gears actually do mesh, they use a 'normal' (but perhaps non-standard) tooth profile.
Unread 09-10-2017, 05:46 PM
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
10 teeth on a 10 inch pitch diameter --> diametral pitch = 1
You might try searching on gear tooth profile generator, or variations of that. I found this link immediately:
http://geargenerator.com/#700,700,10...0,0,0,0,2,-420
Richard Wallace
since 2003
Unread 09-10-2017, 07:40 PM
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
If the Pitch Diameter is 10 and the OD is 11" then that suggests that it is not a "standard" gear (meaning the addendum, dedendum, & tooth thicknesses follow standard formulas). 10T with a 10 Pitch Diameter implies DP=1. But the addendum on a standard gear is 1/DP which implies that the OD = (Nteeth+2)*DP => (10+2)*1=12"
So...
Something is wacky there.
But it shouldn't be that hard to "guess and check" you way the right values if you have a way generate gears. You only have 5 values to match:
  • DP (or module -- same information)
  • Pressure angle
  • Circular Tooth Thickness
  • Addendum
  • Dedendum
It seems hard but really only DP and Pressure Angle are required to be solved at the same time and you really only have a two values to check for Pressure Angle (if FIRST didn't use either 14.5 or 20 degrees -- shame on them). Similarly, DP (or module) should only require you to check a handful of discrete values. The last 3 can be solved sequentially.
Dr. Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 09-10-2017, 08:00 PM
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Here's an IBL file for a 15T gear that looks decent.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
