Go to Post Everyone needs to start working with what they are given, and start appreciating FIRST, not complaining about what they think FIRST is doing wrong. - Marygrace [more]
Unread 09-13-2017, 09:19 AM
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has a reputation beyond reputebdaroz has a reputation beyond reputebdaroz has a reputation beyond reputebdaroz has a reputation beyond reputebdaroz has a reputation beyond reputebdaroz has a reputation beyond reputebdaroz has a reputation beyond reputebdaroz has a reputation beyond reputebdaroz has a reputation beyond reputebdaroz has a reputation beyond reputebdaroz has a reputation beyond repute
[FRC Blog] 2018 Beta Testing and 2017 Usage Reporting
From: https://www.firstinspires.org/roboti...sage-reporting
Written by Kevin O'Connor, FIRST Robotics Competition, Robotics Engineer
Beta Testing
This year we are once again looking for 90 teams, 30 for each software language, to help us test the 2018 FIRST Robotics Competition software. A small number of teams have been invited to bypass the application process based on past performance in Beta testing. Most of the spots are still up for grabs, though, so make sure to fill out the application found here by Sunday, September 24th, if you are interested. Beta teams will be asked to upgrade their 2017 robots to the 2018 software, perform some specific tests with any significant changes or new tools, and help educate other teams about the changes for 2018. Beta Testing will begin approximately the 2nd 3rd week of October and each task will have specific deadlines through approximately the end of November. Teams may continue to test through Kickoff, but software starts to lock in early December so testing done in December may not be done in time to fix any bugs discovered.
One of the under-the-hood features of the FRC Control System software is a system called Usage Reporting. This system tracks what WPILib objects are created in each team's code and reports the data back to FMS when the robot is connected to the field. This data helps FIRST and our Suppliers understand how teams are using the Control System which can give us insight into things such as adoption of new features or usage of legacy classes.
Here are a few numbers from the data that teams may find interesting:
25,151
The total number of motor controllers used on 2017 robots
6,296
The total number of USB input devices used to control those motors
2,0451
Total Encoders used to get feedback from those motors
1,4122
The number of teams that used pneumatics (with the PCM) on their 2017 robot
762
The number of Digital Outputs used to control non-actuators (lights, sensors, etc.) on 2017 robots
33
Number of teams programming in Python
15
The number of Analog Outputs used to control non-actuators (sounds, lights, etc.) on 2017 robots
The complete processed data set can be found here.
A few notes on this data:
  • The data has been semi-anonymized. Team numbers have been replaced with rookie years and the data has been resorted so teams are not in order by team number.
  • We can only track the objects teams create in code. If you create extra motor controllers that aren't on your robot3, they will still be captured by this system. If you create motor controller objects of the wrong type, that wrong type will be captured by this system.
  • Counted objects and TRUE/FALSE show the largest number of any given object used in any one match (i.e. if a Robot had 2 Encoders in match 1 and 3 Encoders in match 7, 3 will be reported). Language and Framework report what was used in the last recorded match.
  • Some objects naturally result in double counting (Encoders use Digital Inputs)
1 Only includes encoders plugged directly into the roboRIO
2 Compressor may not show for C++ and Java teams that didn't use the Compressor object. Counting the # of teams that had > 1 Solenoids is a more accurate count of teams using pneumatics.
3 Example: A handful of teams report more than 16 motor controllers which would be awfully tough with only 16 channels on the PDP.
Unread 09-13-2017, 09:39 AM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: [FRC Blog] 2018 Beta Testing and 2017 Usage Reporting
Big brother is always watching
Studying MechE at the Technion - Israel Institute of Technology
2017-present: Technical Mentor FRC 5987
2017-present: CSA/FTAA for FIRST Israel
2012-2016: Member FRC 423 Captian, Programmer (LabVIEW), Electrical, CAD, Manipulator, Chassis, Business, Outreach (everything)
Unread 09-13-2017, 09:59 AM
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
Cynicism isn't wisdom
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
When they uploaded this document, they put it at the same url as the one they linked to in the blog last year. Is the 2016 report still available anywhere?
Unread 09-13-2017, 10:11 AM
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
Rookie Year: 2012
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Originally Posted by Nate Laverdure View Post
When they uploaded this document, they put it at the same url as the one from last year. Is the 2016 report still available anywhere?
I went to my downloads folder to check if I had it,
I downloaded the 2016 report back in 29/7 but it has the same data as the new one.
When looking at the properties of the 2017 report it says 'Content created: 31/05/2016'.
So I guess the link hasn't updated yet.
2016-2018 Programming Mentor
Hopper Sub-Division Finalists with 1706, 2974 & 957 (2018)
Israel DCMP Chairman's Award Winners (2017)
Curie Sub-Division Champions with 694, 379 & 1511 (2016)
2014-2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711 (2015)
First Ever Israeli Team on Einstein (2015)
2012-2013 - Member & Head of Programming Crew
Israel Engineering Inspiration Award Winners (2013)
Unread 09-13-2017, 10:21 AM
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
Discount Nate Silver
AKA: inkling16
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
That is probably why there are no 2017 rookies in this data set.
Unread 09-13-2017, 02:39 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Mentor
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
It looks like FIRST fixed the bad link in the original blog. Here's the updated link.
Edit: 3946 is row 1553 this year, based on rookie year, language, infrastructure, 4+ CANTalons, 1+Talon, 1+Analog Input, 1+Encoder (direct). But...we didn't have three joysticks or use arcade this year??
Edit2: Three joysticks is because we used two flight sticks as a primary and a single xBox as a secondary, and put all three in the code. I couldn't find arcade drive code anywhere on our 2017 competition GitHub; it must have been something we used in the last match but never synced to the repository.
Unread 09-13-2017, 02:53 PM
FRC #2363
Team Role: Coach
Rookie Year: 1999
Cool
Unread 09-13-2017, 03:18 PM
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | Senior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2012
dirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond reputedirtbikerxz has a reputation beyond repute
Fairly certain team 3991 is 1705 on the list this year (nothing else matches), and everything seems pretty accurate
Team 3991: Driver (2014-), Captain (2016-)
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Cool
I'd be interested to see this as "% of market" as well, since the raw values are going to scale with # of teams and average # of motors per robot (I think average number of motors per robot in 2017 was higher than 2016 just based on the game)
Unread 09-13-2017, 03:20 PM
Unsung FIRST Hero
Karthik Karthik is offline
Rookie Year: 1998
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Some summary data for 2017:
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Unread 09-13-2017, 04:21 PM
nickbrickmaster nickbrickmaster is offline
Human left pad
AKA: Nick Schatz
no team (3184 Alum)
Rookie Year: 2014
nickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond reputenickbrickmaster has a reputation beyond repute
I'm interested in the two Unknown programming languages, rows 359 and 580. Anyone who used a nonstandard language care to come forward? Kotlin reports as Java.
Proceed as if success is inevitable.
Unread 09-14-2017, 10:50 AM
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
I wonder whether any of these statistics are correlated with OPR.
2018 UofM Kickoff, Great Northern Regional, Midwest Regional, Minneapolis regionals, Daly@CMP, Minnesota State Tournament, who knows how many offseason events, but won't be playing Santa at Minne Mini this year
2011 - present FRC 3081 Kennedy RoboEagles mentor
2013 - present event volunteer at[list truncated]
http://twitter.com/MrRoboSteve www.linkedin.com/in/speterson Microsoft is hiring
Unread 09-14-2017, 11:43 AM
piersklein's Avatar
piersklein piersklein is offline
FRC #0320 (Pyongyang Academy of Denim)
Rookie Year: 2014
piersklein has a reputation beyond reputepiersklein has a reputation beyond reputepiersklein has a reputation beyond reputepiersklein has a reputation beyond reputepiersklein has a reputation beyond reputepiersklein has a reputation beyond reputepiersklein has a reputation beyond reputepiersklein has a reputation beyond reputepiersklein has a reputation beyond reputepiersklein has a reputation beyond reputepiersklein has a reputation beyond repute
It would seem rookie year is correlated with OPR. Hmm...
10 events/8 elims/2 wins
I used to know what I was doing. But then I went on CD and they sorted me out.
Unread 09-14-2017, 09:37 PM
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
Rookie Year: 2014
SamcFuchs has a reputation beyond reputeSamcFuchs has a reputation beyond reputeSamcFuchs has a reputation beyond reputeSamcFuchs has a reputation beyond reputeSamcFuchs has a reputation beyond reputeSamcFuchs has a reputation beyond reputeSamcFuchs has a reputation beyond reputeSamcFuchs has a reputation beyond reputeSamcFuchs has a reputation beyond reputeSamcFuchs has a reputation beyond reputeSamcFuchs has a reputation beyond repute
Anyone have an idea of why my team isn't on here? There's no 1999 Java teams with compressors so I'm pretty sure.
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
  #15   Spotlight this post!
Unread 09-14-2017, 09:40 PM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Did you actually use the compressor object in your code? Instantiating a Solenoid will run the compressor automatically, but will not report a compressor usage.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
