OCCRA
Go to Post Remember, FIRST is a great opportunity that will get you ahead in the long run but don't forget about the short run either. - ChrisMcK2186 [more]
Unread 12-04-2017, 11:01 AM
Dev_Otmas's Avatar
Dev_Otmas Dev_Otmas is offline
FRC #4905 (Andromeda One)
Rookie Year: 2011
Dev_Otmas is an unknown quantity at this point
Unhappy Programming in Vim?
Turns out I've been kind of silly and said that I would do all my programming this year in Vim. So now I'm wondering if there's any way to push robot code from within vim.
Unread 12-04-2017, 11:09 AM
Andrew Schreiber Andrew Schreiber is offline
Petitioning the UN to ban Lythgoe
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: Programming in Vim?
Robot code is pushed using ftp (or scp, don't have it in front of me)... so... yes?
Look into the build.xml file eclipse uses. For java at least it's just using ant under the covers. Alternate option would be GradleRio in which case you'd have to shell out from VIM to that and run it. I'd be willing to bet there's an easy way to do it. If not, TMUX is a thing that is totally awesome.
Unread 12-04-2017, 11:13 AM
Dev_Otmas's Avatar
Rookie Year: 2011
Thanks for the response! I'm already familiar with tmux, I was just wondering if there was a way to do it from inside vim. Thanks again!
Unread 12-04-2017, 11:15 AM
marshall's Avatar
marshall marshall is offline
Online Stripe & Drape Sales
FRC #0900 (The Zebracorns)
marshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond reputemarshall has a reputation beyond repute
VIM is a text editor... if you want a full blown operating system then use emacs like a filthy plebeian.*
Seriously though, write some scripts for deploying code.
*Someone's going to get angry at me for this and I don't care because chances are they use emacs.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Clarke's Laws
Unread 12-04-2017, 11:20 AM
Rookie Year: 2000
"You must spread some reputation around before giving it to marshall again"
For reference, it was red.
Fight me.
Unread 12-04-2017, 11:27 AM
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond reputegerthworm has a reputation beyond repute
It's an old code, but it checks out:
https://github.com/RobotCasserole173..._and_deply.bat
https://github.com/RobotCasserole173...build_only.bat
Presumptions:
--Ant is installed and on the system path
--You're using Windows (but, the same concept should apply to your favorite *nix system)
--You're using the 2016 libraries. Haven't tested with anything later yet.
cadandcookies's Avatar
cadandcookies cadandcookies is offline
AKA: Nick Aarestad
FRC #2220 (Blue Twilight) & FTC 9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
And here we see three programmers in their natural states— one asking questions, and two flaming over an arbitrary technical choice.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
grabcad | twitter | github
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16) -> FRC 2220 (18-??)
VEXU UMN (2015-17)
Volunteer since 2011
Unread 12-04-2017, 11:28 AM
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
no team (The Blue Alliance)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
And such a good operating system, too. I've only ever found it to be missing one thing: a decent text editor
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
The Blue Alliance | The Blue Alliance for Android | FRC Notebook
Unread 12-04-2017, 11:29 AM
Rookie Year: 2000
Originally Posted by cadandcookies View Post
And here we see three programmers in their natural statesó one asking questions, and two flaming over an arbitrary technical choice.
My code is compiling!
(But seriously OP, Marshall and I are snarking at each other but if anything is still unclear we can take this outside, I'll have to check which of our states still have dueling laws on the books)
Unread 12-04-2017, 11:30 AM
marshall's Avatar
Don't worry - we can meet up in Myrtle Beach and settle it there!
Clarke's Laws
plnyyanks's Avatar
AKA: Phil Lopreiato
Rookie Year: 2010
Unread 12-04-2017, 11:34 AM
AKA: Nick Aarestad
To be clear to the OP, Marshall, and Andrew, my comment was also being made in jest. I donít really have anything further to add other than good luck to the OP, and have fun with that duel... I hear everything is legal in Jersey, but that might be a bit of a haul
VEXU UMN (2015-17)
Unread 12-04-2017, 12:22 PM
KJaget's Avatar
KJaget KJaget is offline
Zebravision Labs
AKA: Kevin
FRC #0900
Rookie Year: 2015
KJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond reputeKJaget has a reputation beyond repute
Run Vim with this set of keybindings : http://www.vim.org/scripts/script.php?script_id=300
Unread 12-04-2017, 01:15 PM
FlamingSpork FlamingSpork is offline
Eating Utensil
FRC #3003 (Tan[X])
Rookie Year: 2015
FlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really niceFlamingSpork is just really nice
With VIM, you can run shell commands from inside it using ":! ant -buildfile build.xml" if build.xml is in your current directory. You can also get a shell using ":sh" and resume editing by exiting the shell.
Source
Last edited by FlamingSpork : 12-04-2017 at 06:46 PM. Reason: Correcting the command to the command suggested by b2101
  #15   Spotlight this post!
Unread 12-04-2017, 05:16 PM
b2101 b2101 is offline
FRC #6619
b2101 is an unknown quantity at this point
You can deploy by running the ant script in the parent directory:
I recommending mapping this to an alias in bash.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
