OCCRA
Go to Post Canada has five regional events now. Canada. - Nick Lawrence [more]
Unread 10-07-2017, 12:21 PM
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
CNC Router help needed
Hi,
My team has purchesed an old CNC Router that uses MACH3.
There are 2 problems I don't know how to solve bu I think both of them are connected to the software that converts DXF files to GCode.
We currently use DXF2GCODE that I found in google...
1. We don't know how to adjust the height of the material, DXF is heightless but I want to set the height by the material I put inside the table of the machine.
2. We don't know how to set the diameter of the tool we are working with. There is a place to change tool in MACH3 but I don't think it affects the motion profile.
Thanks,
Yarden
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 10-07-2017, 12:50 PM
Bald & Bearded Bald & Bearded is offline
Jack of All Trades/Master on none
FRC #1885 (ILITE Robotics)
Bald & Bearded is on a distinguished road
Re: CNC Router help needed
Yarden:
I am not familiar with the DXF2GCODE software but your assumption that is where the issue resides probably correct. MAC3 is a solid CAM program but it needs something else to generate the tool paths. Those paths are directly related to the bit size and type as well as the material thickness with the speed/rate needing to be adjusted based on the bit and material.
I would invest in one of the better known software programs to generate tool paths. We use Vectric Cut2D. You can find out about them and the costs
at http://www.vectric.com/products/cut2d.html
If your work area is bigger that 24"x24" you will need the pro version.
If you want to do fancy plaques and 3d carving you will need to upgrade to VCarve.
You can download trail versions of all this but they will only output a small part of the gcode.
Unread 10-07-2017, 01:32 PM
sanddrag sanddrag is offline
On to my 17th year in FRC
FRC #0696 (Circuit Breakers)
Use Autodesk Inventor HSM, Fusion360, or or HSMWorks for Solidworks to generate your toolpaths. These programs are free for students and schools, and light-years beyond DXF2Gcode
Unread 10-07-2017, 01:58 PM
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud ofInFlight has much to be proud of
I would suggest you start with a .stp file rather than a .dxf file. Step files contain the full solid surface model, where the older .dxf are a wire frame model.
As part of the First CAD software licensing; the are some CAM packages available free as well. Autodesk Fusion is one option.
Unread 10-07-2017, 08:05 PM
asid61's Avatar
asid61 asid61 is offline
Also 299 mentor
AKA: Anand Rajamani
FRC #1072 (Harker Robotics and Valkyrie Robotics)
299 uses HSMworks with great success. 1072 is planning on using MasterCAM but we'll see if we stick with it.
HSMWorks' 2D options lets you select contours to cut and adjust feed depth and finishing pass size. You can store your tools in a tooling file. I didn't have much fun with V-carve and it generated some really sub-optimal toolpaths for cutting parts out, but it can work with some effort.
Team 1072 2017-present
Team 299 2017-present
Team 115 2013-2016
Unread 10-10-2017, 06:25 PM
DonRotolo's Avatar
Standing on their shoulders
FRC #0832
Yarden, there are many CAD-to-G-Code generators out there; HSM and HSMworks are good, I use Vectric V-Carve Pro, and there are many others at prices from free to very expensive. You do get what you pay for, but above a certain point (about US$1000) the curve tends to flatten for general-purpose programs.
These programs should always compensate for the bit diameter, as well as allow you to specify speeds and feed rates, as well as define complex motion paths
You CAN also write G-Code by hand, but this can get awfully difficult for anything but the simplest of tool paths. Good to know, though, since you can then 'touch up' software-generated tool paths.
When I bought MACH3, I god a program called LazyCAD (also by Artsoft) that was useful for some work. They call it "Beta version" and "Use at your own risk" because it does have some bugs, and it is not supported at all. But it was free...
Let us know how it turns out.
Unread 10-10-2017, 06:30 PM
Jchau's Avatar
Jchau Jchau is offline
FRC #1414 (IHOT Robotics)
Rookie Year: 2015
Jchau is on a distinguished road
I completely agree with Sanddrag. HSMworks is great. We have just started using it and it works really well for our workflow since it's integrated into SolidWorks.
