OCCRA
Go to Post It's sooo stressful! I brought my suitcase to school today, and I still don't know if we're going! - elfenari [more]
Unread 04-15-2018, 07:56 PM
airbornehurdle airbornehurdle is offline
FRC #6922
airbornehurdle is an unknown quantity at this point
How hard is it to program a swerve drive train in arcade drive?
Hello,
I'm from a rookie team (that is actually getting out of rookie status next season) and I'm the programmer lead for my team. My team was thinking of doing swerve drive train instead of slide drive train. As a newbie in Java, I was thinking that putting arcade drive on a swerve drive train must be hard. I was wondering for veteran programmers out there, how hard is it to do arcade drive for a swerve drive train?
Unread 04-15-2018, 10:57 PM
GeeTwo GeeTwo is offline
In Transition
AKA: Gus Michel II
Re: How hard is it to program a swerve drive train in arcade drive?
Arcade drive only gives you two degrees of input, whereas swerve (or even holonomic) gives you three degrees of freedom of overall robot motion. That is, you can translate in two directions, and rotate around a vertical axis. Doing two-axis arcade drive will leave one of these (or some composite degree of freedom) out of reach.
On the small-scale (about 1/3 FRC scale) swerve I played with a few years ago, I drove it with a three-axis joystick. Joystick position corresponded to translation, and twisting the joystick corresponded to rotation speed. Getting the swerve part right was MUCH harder than mapping the controls to the desired motion.
[Quoting brennonbrimhall]: We design a new robot every year, but we can't forget that we also design a new team every year as folks come and go.
Unread 04-15-2018, 11:19 PM
asid61's Avatar
asid61 asid61 is offline
Design Simple
AKA: Anand Rajamani
FRC #1072 (Harker Robotics)
I would take a long time learning how to properly create PID loops and tune them for a lot of different situations before attempting a swerve drive. Once you understand the concepts involved on an intrinsic level swerve becomes a lot easier.
Swerve isn't hard- if you know exactly what you're doing going in.
Team 1072 2017-present
Team 299 2017
Team 115 2013-2016 (student)
2018 Davis Finalists (w/ 6474 and 3880), 2018 Roebling Winners (w/ 3476, 1323, and 1778)
Unread 04-16-2018, 07:57 AM
Petitioning the UN to ban Lythgoe
And you don't flip the coordinate systems between your wheel modules and your gyro...
Really for me that was the hard part - keeping track of all the moving parts and their directions then keeping that in sync with the math.
Unread 04-16-2018, 10:20 AM
Oblarg Oblarg is offline
AKA: Eli Barnett
This becomes a lot easier if you structure your code in a reasonable way.
"The breakfast of champions!"
FRC Drivetrain Characterization
Unread 04-16-2018, 10:24 AM
It's also a lot easier if you have physical access to the robot and as such have an accurate mental model of the system (Which I didn't have). Hard to catch bugs with a test suite if your test suite is out of sync to the physical model.
Unread 04-16-2018, 10:28 AM
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Why are you testing your robots in sinks? Don't you risk water damage?
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
