OCCRA
Go to Post At this point I think I've absorbed more aluminum into my blood than the iron that was already there. - hectorcastillo [more]
  #31   Spotlight this post!
Unread 06-11-2018, 02:26 PM
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond reputes-neff has a reputation beyond repute
Re: Reducing Backlash on FRC Robots
Originally Posted by Jared Russell View Post
Make sure that you design your entire mechanism (mechanically, electrically, and software) such that when your feedback controller needs a couple more volts to compensate, they are available.
But how does an inexperienced student design in that headroom? 192 solved it by making students build mechanism prototypes that "must work" off beheaded 12v NiCaD drills. Once the prototypes worked with the small batteries and finger triggers, making them work on the robot was a piece of cake.
So for 841 I picked up 8 of these 12v drills, cut off the heads, and put PowerPoles on them this spring. Looking forward to implementing next season.
Looking back at OP's topic though... this tip definitely falls more under "give your team tools to observe backlash early and often" than "this is how we pull it out of our mechanisms"
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
"Remember why you're doing this." -mrnoble
  #32   Spotlight this post!
Unread 06-11-2018, 03:00 PM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
If you use my calculator to help design your mechanisms, you can set the voltage applied to the motors to 10 or 11 volts. That way if your actual applied load should increase above what you put in the calculator as the expected load, you still have some headroom for the motors to give more power before maxing out.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
  #33   Spotlight this post!
Unread 06-11-2018, 03:27 PM
s-neff's Avatar
AKA: Sam
That's a sweet calculator.
And that right there is the roadblock that I'm getting around by asking students to "make it work" at prototype phase with limited power & control dexterity
One we have a functional prototype, we can measure stuff off it, and refine it with a calculator. But I've found that asking for too much math up front can intimidate my students into inaction I'd rather meet them where they are than act as a mathematical gatekeeper.
We're thoroughly off topic now.
Using spring loads to keep backlash in check is my favorite "FRC-ready" method for manipulators (<360 degree motion / single direction). Surgical tubing is magic, just wrap some on there & trust. Your students will need to experimentally determine what the "right amount of magic" is, you'll probably never put a firm number on it for design, and for four hours (1 season) machine operation? I'm OK with that.
Originally Posted by Rob Stehlik
I put a hex shaft collar next to the gear, drilled though both of them and inserted a roll pin.
Love this. Could probably do it on a drill press?
I'd want to do it with a miniature VEX collar, but not sure how big a roll pin could fit through the "meat" of that shaft collar. What kind of loads were you putting on this?
  #34   Spotlight this post!
Unread 06-12-2018, 01:36 PM
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant futureRob Stehlik has a brilliant future
For sure you could do it on a drill press. I think the roll pin was 3/16", but it might have been even smaller. The loads weren't very high since the arm was very well balanced with a gas spring.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
