OCCRA
Go to Post When we stop asking ourselves the hard questions, whether as team leaders or in life, then we are failing. - Al Skierkiewicz [more]
CD-Media
  #31   Spotlight this post!
Unread 01-10-2018, 05:01 PM
AriMB's Avatar
AriMB AriMB is online now
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Re: Inexplicable Current Draw?
Originally Posted by Jaci View Post
A high resistance limits the current flow, not the inverse. Low resistances are characteristics of a high current-draw system.
V = IR
I = V/R
therefore, as R->inf, I->0. Likewise, as R->0, I->inf.
To think of this better, the voltage drop across a small section of wire is almost 0 since its resistance is negligible (current can flow). Across an air gap, the resistance is almost infinite, so no current can flow.
Sorry, I should have said a large voltage drop instead of voltage to be clearer. The voltage drop (difference between resting 12V and loaded 6V) is much higher than expected for a current draw of 50A. Something in the system is causing a high resistance, causing a large voltage drop.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
  #32   Spotlight this post!
Unread 01-10-2018, 05:10 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Inexplicable Current Draw? [UPDATE]
Originally Posted by cbale2000 View Post
That seems a bit high for free speed, are your gearboxes properly lubricated and belts/chain properly tensioned?
For reference:
https://www.chiefdelphi.com/forums/s...3&postcount=16
Actually a new fully charged 12v battery will generally be closer to 14v (generally around 13.7 or so).
That's surface charge. It will go back down to the normal 12.8 or so level after a couple hours.
http://autorepair.about.com/library/.../aa101604b.htm
"12v" is more of a nominal voltage,
12V is too low for OC 100% charge.
  #33   Spotlight this post!
Unread 01-10-2018, 05:29 PM
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Correct, so if you place a HIGH resistance (NOT a low resistance) in series with the load, in this case a motor or several motors, your voltage at the load will absolutely drop. So the original post was correct.
The power paths between the battery and loads MUST be low in resistance. A bad crimp or loose terminal INCREASE the resistance causing the voltage at the load to drop.
Think of the "BAD" connection as a resistor who's value is higher than ideal therefore causing a voltage drop across the connection.
E/I*R
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
  #34   Spotlight this post!
Unread 01-20-2018, 12:26 PM
Unsung FIRST Hero
Chief Robot Inspector
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
So back to the original post and some real world information.
You cannot determine a battery state of charge with a voltmeter. A dead battery will show ~12 volts with no load. However, a battery showing less than 12 volts with just a light load (robot disabled) is likely discharged.
It is normal for FRC robots to show a drop of several volts when driving or turning. This is due to the current through the internal resistance of the battery and the primary (#6 AWG) wire. All things being equal, 100 amps would drop 1.1 volts across the internal resistance of a fully charged battery.
Remember that the voltage is sensed at the PDP. Any bad connection up to the PDP will drop voltage under load.
Pull on every #6 wire, there should be no movement in the connector and no wiggle in the connectors. Nearly 100% of all electrical failures due to brownouts are related to poor crimps, loose hardware or improperly made terminations. Hardware on the battery, the PDP and the main breaker needs to be tight. I highly recommend adding a #10, external tooth lockwasher, between the battery terminal and the wire terminal to prevent the terminals from moving. Any movement in these connections will loosen the hardware in a short period of time.
If you are using screw clamp terminals that do not specifically state "for stranded wire" the screw may actually cause the strands to spread out and move up the screw threads.
Al
WB9UVJ
www.wildstang.org
________________________
Knowledge is power. Power UP!
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
