Go to Post Cooler robots = Impressed sponsors = More money for FIRST = Easier expansion = Easier culture change. Isn't this what we want? - Karthik [more]
Unread 01-12-2018, 08:40 PM
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld has a spectacular aura aboutpaul.dornfeld has a spectacular aura aboutpaul.dornfeld has a spectacular aura about
Gear Ratios on the ToughBox Mini (KOP): benefits and risks of changing the KOP ratio
This is a similar thread to https://www.chiefdelphi.com/forums/s...d.php?t=161392, but we thought it would be appropriate in the Strategy forum as well.
With the KOP come this gear ratio table: (these values are at 75% free speed according to the published table)
We would like to know from other's experience what the trade-off is to go from the included 10.71:1 which is rated at 10. ft/sec, down to the 5.95:1 rated at 18.0 ft/sec.
How much slower will the 5.95 accelerate off the blocks?
Is there a greater battery amp consumption?
Do the motor controllers get hotter?
Can you "brown out" the bot in a shoving match sooner?
...and any other considerations we haven't yet thought of?
Thank you for your assistance.
We are asking, because we have neither the time nor money to order the interchangeable gears AND try them out sufficiently to be confident that the above and other issues not mentioned might show up.
Unread 01-13-2018, 08:41 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Gear Ratios on the ToughBox Mini (KOP): benefits and risks of changing the KOP ra
Check out the JVN calculator for your specific case.
In general, if you have a light robot, you can get away with gearing faster and still have decent acceleration and acceptable current draw. Heavier robots with the same gearing and wheel size will accelerate more slowly at the same current draw, or draw more current with the same acceleration.
Remember to consider how long you think your average "runs" will be. Last year, gearbots had to cycle gears from one end of the field to the other and had about a 50' run. For STRONGHOLD, the runs were much shorter, and there were ramps and obstacles to overcome. This year, there are short runs and long runs, depending on where you anticipate sourcing and scoring cubes; how to best gear is greatly dependent on how long you think your typical runs will be (short runs should gear low for acceleration, long runs gear a bit higher for top speed)
Edit: OK, what is acceptable current draw? Of course, this depends on what risks you are willing to take. 3946 does our calculations based on 50A current draw on each CIM to minimize the possibility of breaker trip or motor smoking during a match. Battery considerations also suggest a 200-250A max current draw across all the systems in operation at any given time. YMMV
Unread 01-13-2018, 09:04 PM
KingOfDemise's Avatar
KingOfDemise KingOfDemise is offline
Addicted to Robots
AKA: Always Building
FRC #3883 (Data Bits)
Team Role: Driver
Rookie Year: 2015
KingOfDemise is just really niceKingOfDemise is just really niceKingOfDemise is just really niceKingOfDemise is just really niceKingOfDemise is just really nice
Last year we ran the 5.95 gearing with 4" wheels on a 118LB robot. It got off the line extremely fast but the breakers had a tendency to break when in a pushing match. The robot could hold it's ground, but not actually push any other robot back. The speed and handling was great (keep in mind 4" wheels not 6"), but if you want to ever push then don't use them. We didn't notice any battery drain problems even when using four full CIMs on drive and two full CIMs for a cimber winch. Just don't try to push anything.
Unread 01-14-2018, 08:28 AM
Billfred's Avatar
Billfred Billfred is offline
Never look back, no, never say die
AKA: Always attack with the warrior's cry...
FRC #1293 (Pandamaniacs); FTC #11444 (Garnet Squadron)
5402 ran the same setup last year, with black HiGrip wheels, and it worked great once we got through some teething problems that weren't caused by these choices.
That said, I find pushing gets into diminishing returns quite quickly in recent years. Knocking a robot askew, occupying protected zones, and disrupting their flow takes a lot less current.
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Owner/Director of Bricks 4 Kidz in Columbia, SC.
2017: FRC 5402 (Iron Kings) - Mentor, Coach
2018-: FRC 1293 (Pandamaniacs) - Mentor
113 events (more than will fit in a ChiefDelphi signature), 15 seasons, over 74,500 miles, and still on a mission from Bob.
Unread 01-14-2018, 08:42 AM
Chris is me's Avatar
three on the scale
AKA: Pinecone
no team (formerly FRC 3929, 228, 2791)
If you're not sure, the stock ratio is a really good mix of good acceleration and top speed for a divided field game like this. I would stick with it.
Looking for a new team in north Chicago / northwest suburbs
Mentor: 3929 (2018)
Mentor / Drive Coach: 228 (2016-17) - 2016 RIDE Winner &
Consultant: 2170 (2017)
College Mentor: 2791 (2010-15) Build Photos - 2013 WPI Finalists, 2012 BAE Finalists
Student: 1714 (2009) - 2009 MN 10K Lakes Winners
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
